Low Profile / "Small" Trackbar - JKowners.com : Jeep Wrangler JK Forum
post #1 of 24 Old 02-29-2012, 10:16 AM Thread Starter
quaylefarmer's Avatar
I'm having trouble with my front Teraflex "Monster" trackbar hitting my pitman arm (@ full compression and steering to the right).
The Tera track bar is HUGE and angle forward in the vehicle quite a bit.
Looking at some other designs.....most others look to be better than what I have relative to this issue.
Anyone have any experience or feedback.
This is what mine looks like now:
[IMG][/IMG]
[IMG][/IMG]
Build thread and additional details:
https://www.jkowners.com/forum/showth...t=63674&page=6
Build Thread:
ACE Engineering
586-806-6641
[B]
quaylefarmer is offline
post #2 of 24 Old 02-29-2012, 10:19 AM
Breaker of nice things
merlin4979's Avatar
I don't know if its any smaller, but doesn't the RK track bar have a different style bend to it? Would that help you?
Rock Krawler
Teraflex
merlin4979 is offline
post #3 of 24 Old 02-29-2012, 10:31 AM Thread Starter
[QUOTE=merlin4979;1083706]I don't know if its any smaller, but doesn't the RK track bar have a different style bend to it? Would that help you?
/QUOTE]
Thanks. Which end of the RK attached to the frame side?
Build Thread:
ACE Engineering
586-806-6641
[B]
post #4 of 24 Old 02-29-2012, 10:34 AM
[QUOTE=quaylefarmer;1083720]
/QUOTE]
Bushing end.
post #5 of 24 Old 02-29-2012, 10:36 AM Thread Starter
Anyone have a pic of the RK installed?
Curious if it comes straight off the frame mount (ie: parallel to the axle) or if it angles up at all??
Build Thread:
ACE Engineering
586-806-6641
[B]
post #6 of 24 Old 02-29-2012, 10:40 AM
Suspension is drooped out a bit
post #7 of 24 Old 02-29-2012, 10:47 AM Thread Starter
Thanks!
Does it angle towards the front of the vehicle at all?
Build Thread:
ACE Engineering
586-806-6641
[B]
post #8 of 24 Old 02-29-2012, 10:49 AM
Thanks!
You have some room to play with that due to it having jam nuts on each end of the track bar. Mine is perpendicular to the ground when installed.
post #9 of 24 Old 02-29-2012, 12:50 PM
EMG006's Avatar
I am having this same issue too. I just looked under my jeep the other day and noticed it.
EMG006 is offline
post #10 of 24 Old 02-29-2012, 01:21 PM Thread Starter
Running the Tera?
Build Thread:
ACE Engineering
586-806-6641
[B]
post #11 of 24 Old 02-29-2012, 01:54 PM
VKS Fab
JK Vick's Avatar
What size bump stops are you running? I'm running 2.5 with that same TB, however, with the old style "hockey stick" TF TB it did hit the pitman arm. Tera did swap it out to the newest style free of charge but that's the style you're running now.
Handmade One At A Time
GIVE US A CALL 559-392-3145
JK Vick is offline
post #12 of 24 Old 02-29-2012, 02:00 PM
EMG006's Avatar
Running the Tera?
Yes I am. I was just poking around and noticed it. I think mine is rubbing during articulation and not turning. My tires were getting into my CA so I added washers to my steer stops. Plus I think it started after I raised my TB on the axle side with the poly kit. Never noticed it before at the stock location.
Edit- I need look at it more closely, as I havent had time. Vick- I ran it with my 2.5" TF and RK coils with no issues.
EMG006 is offline
post #13 of 24 Old 02-29-2012, 02:18 PM
You guys have me now doubting whether or not to put my TF one on my Jeep.
I mean, do I really need it excluding rock damage?
07 Rubicon Unlimited - Teraflex 3" prerunner lift, 35's, 5.7 Hemi using AEV kit, Teraflex CRD60 rear with 5:13 gears all around.
pnut is offline
post #14 of 24 Old 02-29-2012, 02:39 PM Thread Starter
It's a good part, I just have a lot of aftermarket stuff going on at once.
It more about forces than rocks (I don't see how a rock could ever get to mine).
The track bar sees nearly 100% of the lateral loads.
Build Thread:
ACE Engineering
586-806-6641
[B]
post #15 of 24 Old 03-01-2012, 06:45 AM
usmcdoc14's Avatar
That is a irritating design for the TF track/panhard bar
Are those bushings even servicable?
usmcdoc14 is offline
post #16 of 24 Old 03-01-2012, 07:36 AM
militaryman4455's Avatar
Whose drag link are you running Goody?
Mod..Wheel..Break..Repeat
Criminals prefer unarmed victims:Μολὼν λαβέ
Originally Posted by cjcraig7 View Post
I think I understand your question - but I am a two door guy.
militaryman4455 is offline
post #17 of 24 Old 03-01-2012, 07:50 AM
Rock Krawler front track bar, drag link and tie rod. You'll also notice that drag link doesn't leave much room for a flipped steering stabilizer, which is why mine is on the driver's side now.
post #18 of 24 Old 03-01-2012, 08:17 AM
Check out RSE's track bar. Super low pro to clear their sector shaft brace. Beefy and a very hefty heim at one end and a bushing at the axle end. Good price too.
I can get you pics of mine installed, let me know if you want them and at what angle.
xmikedentx is offline
post #19 of 24 Old 03-01-2012, 08:28 AM
Well I have Polys Chromo tie rod and I just got a new stock track bar, just went out and checked the bolts and they are tight as shit! I think my shimmy must be coming from my drag link. Will that draglink work with the stock stabil location? Mine hasnt been moved. I'd like to get it to where I can run without one.
What do you think about my control arm question?
post #20 of 24 Old 03-01-2012, 08:56 AM Thread Starter
Thanks - I saw your posts in the sector shaft thread.
Is the sector shaft brace the first thing that hits when you compress the suspension?
A front view and a side view would be great. - Thanks again
Build Thread:
ACE Engineering
586-806-6641
[B]
post #21 of 24 Old 03-01-2012, 09:47 AM
highwayman's Avatar
Ran the TF TB, had no issues w/Pitman arm clearance, mine would contact the steering stabilizer, though.
highwayman is offline
post #22 of 24 Old 03-01-2012, 04:54 PM
SoK66's Avatar
TF uses stock style clevite bushings. No muss, no fuss, no DW, no wear, and easy to adj. Never seen that contact before, I assume it's a stack-up of tolerances due to the axle housing and control arm lenghts.
FWIW, I was concerned about the TF bar hitting the frame on full flex so I tried running the Poly track bar. It's OK, but uses a heim at the axle & small urethane bushing at the frame. Difficult to adj compared to the TF. Shortened by front control arms and put the TF bar back on. No issues.
SoK66 is offline
post #23 of 24 Old 03-01-2012, 08:35 PM
The track bar will never hit the brace. The first metal to metal point that would hit on my setup (If I removed my bump stops) would be the track bar axle mount hitting the frame on the passenger side.
post #24 of 24 Old 03-01-2012, 08:39 PM Thread Starter
I agree that adjusting the arms could be a logical solution.
Unfortunately my axle is already as far rearward as possible (it actually needs to go forward ~ .5".
Build Thread:
ACE Engineering
586-806-6641
[B]
