Synergy rear upper shock mount - JKowners.com : Jeep Wrangler JK Forum
post #1 of 30 Old 02-28-2012, 03:36 PM Thread Starter
TCdawg's Avatar
Looking for some feed back on these, the Synergy upper rear shock mounts.
http://www.polyperformance.com/shop/...t-p-29226.html
They say the move the upper shock mount 2' up and 2.5" back. I was looking at using these and the Synergy lower shock relocation mounts.
My issue, other than the rear lower shock mounts hang lower than snakes belly in wagon wheel rut, is that my passenger rear shock is contacting my RK trackbar mount.
TC
TCdawg is offline
post #2 of 30 Old 04-16-2012, 12:45 PM Thread Starter
TCdawg's Avatar
bump for this.
I bashed up my driver rear shock pretty bad this weekend and I'm thinking of doing the relocation that Synergy Suspension offers. It pushes the bottom of the shock up a little. To gain back the travel you lost they also have an upper shock mount that moves the upper up and back.
Anyone installed these?
TC
TCdawg is offline
post #3 of 30 Old 04-16-2012, 07:46 PM
SoK66's Avatar
I run the Synergy lower mounts with Bilstein 5100s, which raised the shock lower mount 1.5" and simply gave me back compression travel I was losing to bump stop. No issues. They've taken a few shots and did a good job of protecting the Billys.
SoK66 is offline
post #4 of 30 Old 04-17-2012, 11:04 AM
Catfish's Avatar
hmm more detail more debate please. I am considering the lower shock relocation (evo or poly) but dont want to lose any flex or for that matter buy a new shock. Without relocating the top as well how is travel not lost? guess I need to go stare at my bumpstops.......
Catfish is offline
post #5 of 30 Old 04-17-2012, 08:27 PM
SoK66's Avatar
Stuff the rear and see how much shock travel you have left. I had 1.75 inches at full stuff, By raising the lower mount 1.5" I got all but 1/4" of that back without bottoming out the shock.
SoK66 is offline
post #6 of 30 Old 04-18-2012, 08:11 AM Thread Starter
TCdawg's Avatar
Good call. I'll bet I have enough now that I won't really loose any when I move the rear's up. I'll check this out.
TC
TCdawg is offline
post #7 of 30 Old 04-18-2012, 10:09 AM
SofaKing's Avatar
Plus, you get 1.5" more droop. I've got the Evo Rockstars -- no complaints.
2009 Silver Unlimited Rubicon -- Not really stock, anymore.
SofaKing is offline
post #8 of 30 Old 04-18-2012, 10:33 AM
Blackr6's Avatar
I'll be installing evo rockstars and synergys upper mounts this weekend. I'll take some before and after pics.
Sent from my iBrick
Blackr6 is offline
post #9 of 30 Old 10-02-2012, 05:59 PM
Neuwirth Motors Parts's Avatar
Did you ever get these on?
Neuwirth Motors Parts is offline
post #10 of 30 Old 10-02-2012, 06:07 PM
Freshmeat's Avatar
He did. With the EVO lowers and Synergy uppers the lower shock bushing is a bit tweaked. I need to do the uppers but I'm thinking about replacing the EVO lowers with Synergy lowers if they line up better.
BlackR6 has some monster flex for how simple his suspension is and with the shocks raised up he won't be nearly as likely to crunch his rear shocks.
1988 Wrangler YJ, Q78-15s, some of this, some of that...
2014 Grand Cherokee Limited, EcoDiesel, RWD...
2013 RAM 1500 4x4, more buttons that I'm usually allowed to touch...
2007 JK X, just getting started...
Freshmeat is offline
post #11 of 30 Old 10-02-2012, 06:09 PM
I'm looking at getting my lift on soon and ran into these when shopping around. So has anybody seen the full Synergy rear upper and lower setup?
post #12 of 30 Old 10-02-2012, 06:32 PM
JKO Dickhead
Asmmns's Avatar
Just went with the poly weld on brackets... Crazy cheap... Just cut off your excess and then weld these on... Still debating the uppers..
__________________
CURE SMA !
Asmmns is offline
post #13 of 30 Old 10-02-2012, 06:33 PM
Blackr6's Avatar
Here's some pics with synergy uppers and evo lowers. I've enjoyed it's I far.
Blackr6 is offline
post #14 of 30 Old 10-02-2012, 06:42 PM
Nukeman's Avatar
Yeah, that's tweaked.
Thinking with the OEM lower mount these would work great.
2008 RUBY UNLIMITED
T&T CUSTOMS
Nukeman is offline
post #15 of 30 Old 10-02-2012, 06:47 PM
Freshmeat's Avatar
Sure, until you crunch the piss out of a shock.
post #16 of 30 Old 10-02-2012, 09:40 PM
But theyll line up if you run Poly/Poly?
post #17 of 30 Old 10-02-2012, 10:18 PM
Westsidejeep's Avatar
Thats like 50 dollars worth of washers on those bump stop extensions!
Jeeps...the cure for a heavy wallet.
Westsidejeep is offline
post #18 of 30 Old 10-02-2012, 11:14 PM
ChuckMRN's Avatar
Poly for sure.. I have banged them pretty hard
16 JKU Sport
RK 3.5 X Factor, UD 60's, Atlas T Case 4.3:1,
TR Bead locks with Toyo Open Country MT's,
VKS Bumpers and Sliders. EVO Skins,
PSC Hydro on Synergy Steering,
Fox Shocks and Bumps
"40's Baby!"
2011 JKU RUBI "SOLD"
ChuckMRN is offline
post #19 of 30 Old 10-03-2012, 07:30 AM
RODICON's Avatar
Poly lowers here!
2014 Rubicon on the build!
RODICON is offline
post #20 of 30 Old 10-03-2012, 07:34 AM
sneck's Avatar
i just had these installed over the weekend, I have rockstars on the bottom, poly on the top. fits just fine, and now I have my uptravel back!
sneck is offline
post #21 of 30 Old 10-03-2012, 07:52 AM
Blackr6's Avatar
Haha yea quick trail fix and never have went back and fixed it out of sight out of mind.
Blackr6 is offline
post #22 of 30 Old 10-03-2012, 07:52 AM
Blackr6's Avatar
Post some pics. I want to see if your lower shock mount is tweaked like mine.
Blackr6 is offline
post #23 of 30 Old 11-09-2012, 05:26 PM
redluve1's Avatar
what kind of modification did you have to do to your exhaust for the poly uppers?
2008 jeep unlimited with goodyear mtr kevlar and teraflex quick disconnects, 4 door, six speed, 2012 hard top
redluve1 is offline
post #24 of 30 Old 11-09-2012, 05:58 PM
ChuckMRN's Avatar
I got rid of mine and went with the MBRP off road cat back. When it dies prob try something else. Tucks up nice and and tight over the axle and trac bar and out the driver rear.
16 JKU Sport
"40's Baby!"
ChuckMRN is offline
post #25 of 30 Old 11-09-2012, 07:58 PM
SoK66's Avatar
Jumping in again, I run the lowers by themselves w/ 5100s and rear SpeedBumps. Work great, no lost shock compression.
SoK66 is offline
