Question for those will full float rear D60's - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 02-28-2012, 08:05 AM Thread Starter
Did you have any issues with the brakes when installing a dynatrac rear full float? Any other issues that I should be aware of? Did your driveshaft fit or did it need adjustment?
Thanks.
post #2 of 6 Old 02-28-2012, 05:22 PM
I bought my Jeep with the axle already installed. Let me know what you want me to look at and I'll be happy to do so. My rotors look bigger than the factory and my drive shaft is aftermarket.
2007 JKU, 6.1L HEMI, ProRock 60 front, full floater Dynatrac 60 rear, and 40's.
Needajk is offline
post #3 of 6 Old 02-28-2012, 05:32 PM
jeepnick's Avatar
I have currie 60's but I had to have my tatton shafts shortened to fit
No clue on the brakes, give dynatrac a call or pm them, they are good people
jeepnick is offline
post #4 of 6 Old 02-28-2012, 06:14 PM
Can you take some close up pics of ur full floater? Especially i would like see how is the sensor installed on them.
JK07 is offline
post #5 of 6 Old 02-28-2012, 06:55 PM
Rubiinthecreek's Avatar
I'm installing a Dynatrac D-60 FF axle shortly - in a week or two. I have the bigger brakes and I can shoot some pics during the install, if you're interested. I expect to have to modify the driveshaft, as Dynatrac told me the pinion nose is longer than the stock D-44 and the D-60 has a different style yoke. I'll take measurements for the driveshaft after it's installed in the JK and on the ground.
Rubiinthecreek is offline
post #6 of 6 Old 02-29-2012, 06:56 AM Thread Starter
Thanks for the responses, I have a full float coming and was just double checking what all will need to be done in order to make it work. I was hoping with the new brakes that a new master cylinder is not needed. I have rubi 44's now and figured that I would have to shorten the ds or I could move the axle back if I have room.
