knocking/vibration in front end - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 02-26-2012, 10:23 AM Thread Starter
Went out driving my jeep today and started getting a vibration and knocking noise in the front end. When i turn left or right it gets more intense and sounds like something is binding. Anybody got any ideas?
sshifflett is offline
post #2 of 8 Old 02-26-2012, 10:26 AM
THECHAD's Avatar
Check the ujoint on your axles? They love to throw caps
18 BRAVO
panama
kuwait
somalia
bosnia
cuba
now just kicking it as a civilian
I served so your lazy ass didnt have to
THECHAD is offline
post #3 of 8 Old 02-26-2012, 10:27 AM
RGJK's Avatar
How many miles? Could be U-Joints if its high mileage. Could also be ball joints.
Give us a little more info about your vehicle and the conditions when this this happens. On pavement? Full wheel lock or just a slight turn? On level ground or is one tire raised? What tire size are you running?
Things like that.
2008 Rescue Green JKU Sahara
RGJK is offline
post #4 of 8 Old 02-26-2012, 10:40 AM Thread Starter
Its got 40k miles and the ball joints have been going bad for awhile. Have them sitting in the garage just havnt put them in yet. I havnt been off road in awhile and this just started today. Happens on pavement and level ground. The harder the turn the more intense knocking. 3 inch lift (shocks/springs) and front lca's with 35's.
post #5 of 8 Old 02-26-2012, 06:56 PM
Just a shot in the dark but check the lug nuts while you are at it.
post #6 of 8 Old 02-26-2012, 07:26 PM
RGJK's Avatar
That sure sounds like U-Joints to me, but since you know the ball joints are going bad I'd replace those and see if it continues.
I destroyed my factory ball joints at 6000 miles with 33s. If you have 35s and have made it to 40000 miles, thats pretty good.
RGJK is offline
post #7 of 8 Old 02-26-2012, 07:31 PM
I've been 10k on a 3.5 inch lift and stock gearing. Am i over due for joint failure
sent using the dark side of the force
check my site out
ms5490renegade is offline
post #8 of 8 Old 02-26-2012, 07:34 PM
rdlynch2's Avatar
What the best method to check the integrity of your ball joints anyways? Pry bar in between the axle C and the ujoint and pull upwards and check for up and down play?
2008 Black 2Dr 6spd D30/44
rdlynch2 is offline
