Scrambler84s - 2012 Unlimited Red Rubi Build - Big Red - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 02-24-2012, 11:47 AM Thread Starter
Scrambler84's Avatar
Scrambler84s - 2012 Unlimited Red Rubi build
Big Red
Bought 2012 Unlimited Rubicon at Waldorf Chrysler Jeep after searching for a red 6spd with out lots of crap on it for 3 months. Left the lot with 17 miles on it.
1st JK, Old 2010 Unlimited Rubicon build - Great White
Current Build Picture
Planned
Front Drive shaft
Poison Spyder Customs - JK 4-Door Trail Cage C-Pillar Kit - p/n 18-18-030
Poison Spyder Customs - 3/16" evap can skid ( stock one is like 1/16th maybe really like sheetmetal )
Poly Performance / Synergy Suspension Jeep JK Rear Long Travel Upper Shock Mount
On Order
River Raider Off Road - 3/16" Steel skid plates full set
On hand and needs installed
Installed
AEV - 3.5" Dual Sport lift (same as was on my 2010)
Bestop - soft top disconnects (remove soft top with out removing rear roll cage brackets)
BFGoodrich - 35x15x12.5 KM2s
Cragger - Steel 15x10s on 5x5
Crown - 7" brake line extenstions (red)
MOPAR - black plastic door sill guards (keeps kids from destroying the door sill when lifted)
MOPAR - hitch and Y cable and 4 pin harness
MOPAR - 2010 Hardtop - no leaks no wind, noise, no wiring harness yet for wiper and defrost
Poison Spyder Customs - Brawler Lite Front Bumper with Brawler Bar
Poison Spyder Customs - JK RockBrawler Rear Bumper with Tire Carrier
Poly Performance / Synergy Suspension - rear lower control arm (LCA) skid and shock relocation bracket
Poly Performance - heavy duty tie rod
Rigid Industries - Rigid dually 2x2 LED Lights
Skid Row - front lower control arm (LCA) skids
SPIDERWEBSHADE - JK4D TrailMesh
Superwinch - 12.5k Talon with poly line
Tera Flex - Exhaust Extensions
Wilson's Jeep Shop - Heavy Duty CB Mount
On Hand Spares
Front and Rear drive shafts, front LCA, rear LCA
Day 1 - Good bye to an old friend
Day 1 - At home
Day 2 - Taking bumper off removing fog light housings and disconnected wiring for install in new bumper
Day 2 - Poison Spyder Brawler Light Bumper installed - Pic at OCC meeting at Kilroy's
Day 3 - Superwinch 12.5k Install - winch sitting on bumper picture a little blurry sry
Day 3 - Superwinch 12.5k Install - Engine compartment and routing, used some liquid tight to run the cables in to prevent abrasion. I had to notch the battery holder shell to run cable into the battery and they turned battery 90 degrees so the cable is short and has to run across top of battery
Day 3 - Superwinch 12.5k Install - Complete, used some RTV around the liquid tight plastic conduit and the battery cables to seal them up, dont want water inside.
Day 5 - SPIDERWEBSHADE JK4D TrailMesh
Day 7 - Rigid Industries - dually 2x2 light install
I installed my 2010 JKU Hard top on my 2012, everything fits well and is pretty tight, no wind noise and passed the hose spray test shot directly in the seals for good 5 mins all around, gonna leave it on until it rains a few times for a good real world test. All holes line up, 2 bolts front and 6 bolts rear, the last 2 rear bolt holes are a bit different in that one side of the notch is missing on the tub and you have to hold the clip/nut piece up until it threads, when removed the can be stored in the hardtop storage bin the back of the Jeep. I'll update this when it rains. I had this top left from my 2010 and hoping to save about $2400 for a new one or the 1600 for dual top group. I don't have the wiring in the 2012 to run the wiper or the hose for the fluid squirter in the back (yes its a technical term lol)
Disclaimer: I'm not recommending this to any and can't be held responsible when yours leaks or flies off going down the road ect. if you do the same thing. Just passing along information as found for the new 2012s.
Day 11 - 2010 MOPAR Hardtop installed on the 2012, no wiper power or squirty fluid(technical term)
2012 Red JK Unlimited Rubicon, 1984 Black CJ Scrambler
2010 White JK Unlimited Rubicon - Traded, 2008 Burgundy XK Overland - Traded
Scrambler84 is offline
post #2 of 12 Old 02-24-2012, 11:48 AM Thread Starter
Happy Veterans Day 34 - Lift AEV 3.5 Dualsport lift going on this weekend along with Crown brake lines, and poly rear LCA shock and skid/relocate brackets
Stripped down and new 7 inch longer Crown Brack lines going on.
Teraflex exhaust spacers installed driver side
Teraflex exhaust spacers installed passenger side
Drilled holes for the bump stops, installed bump stops and springs, installed shock doubler brackets along with reinstalling the LCA skids and installed the shocks. Tomorrow I start the high steer kit set up. I already have the drag link removed. Still have to drill out the knuckle though for the 7/8 drop in piece, so I can install the flipped drag link.
Spring and shocks on drivers side
Spring and shocks on passengers side
Installed heavy duty tie rod from Poly Performance
drilled out hole for drag link and put in insert and installed new drag link
removed rear swaybar links and installed them in the front
aligned and reconnected the track bar
Mahaha looks like its done? I wish
Told yah its not quite there yet
Rear brake lines installed
Rear track bar bracket and new rear track bar installed
Well took 2.5 days and alot of work till 1am 2 nights in a row but BIG RED is done.
I even put my tags back on it today, registration showed up Thursday in the mail, just in time for the lift.
post #3 of 12 Old 02-24-2012, 11:49 AM Thread Starter
Day 50 - Put on these Rear Lower Control Arm Skids with Shock Mount
http://www.quadratec.com/products/16315_6408.htm
They bring the shock mounts up about 1.5 inches and have built 3/16 skid to make smaller strong rock targets
Shock mounts cut off and painted to stop the rust
Driver Side
Passenger side
This morning both sides little better light
post #4 of 12 Old 02-24-2012, 11:49 AM Thread Starter
Got the Bumper painted up and did the install on it tonight, still need to put the swing out arm on maybe tomorrow or on Xmas eve.
primered bumper and swing out arm
primered all the little pieces too
painted the bumper Tuesday and Wednesday and installed it today
Rigged up temp tag and light holder till I get the PSC stuff installed
Morning pic
and rigged up plate holder / Light holder. Back is rubbermaid container lid(I have about 100 from moving last time) and zip ties
Didn't leave the 3rd brake light like that but the pics shows the spider web in lower passenger side well.
moved brake light for now, wiring and all and rerouted CB antenna cable too
Gotta fix up the tag now, im sure some pooolice love to yell at me cause its partially blocked
post #5 of 12 Old 02-24-2012, 11:50 AM Thread Starter
3rd Brake Light Plate
I cut a plate to mount to the PSC high lift jack mount and I cut the OEM stock 3rd brake light loose from OEM mount and rerouted wiring so I could mount it in semi stock location above tire. hole in center allows for stock wiring connector to fit through bracket, making light removable.
Rear Tag light center of tire plate fabbed up with light hooked to hitch wiring
post #6 of 12 Old 02-24-2012, 11:54 AM Thread Starter
Fabricated CB Mount
Wilson's Jeep Shop - Heavy Duty CB Mount for 2007 - 2012 JK
Fully adjust able and short enough to keep the metal off the plastic of the center console. Very solid made from 1/8 plate for seat bracket and 3/16 channel for the swing arm. All made from scrap metal I had laying around.
Mount Drawing
Mount, straight on above
Mount, on angle to show bolts ect.
Mount, from door
Mount, straight on.
Added plate across the front to help hold CB case together
post #7 of 12 Old 02-24-2012, 06:29 PM
Ryanralston07's Avatar
Looks great! Congrats on the great looking JK! How is drivability with the 35's and 6-speed (guessing you have 4.10 gears in the D44s)?
Ryanralston07 is offline
post #8 of 12 Old 02-24-2012, 07:50 PM
captaindean's Avatar
Hey scrambler nice build I am waiting for PSC to ship my rear bumper and front also front and rear fenders what was your process in painting you rear bumper thx for the info I can't wait till my PSC stuff gets here. What brand paint and primer did you use and would you use bedliner ??
captaindean is offline
post #9 of 12 Old 02-24-2012, 09:16 PM
Sweet rig! I cracked up at your temp tag bracket with the zip ties
post #10 of 12 Old 03-01-2012, 08:34 AM Thread Starter
35s and 6-speed will still break the tires lose and make a chirp and don't have to downshift to pass above 60 Mph, drives fine on highway MPG around 19-20, can't complain. Beats the 2010 I had with 15-16 mpg.
I used rustoleum paint and their self etching primer. Works great, used it on my skids from my 2010.
The Zip tie bracket worked till I got the other one made up inside the spare tire.
post #11 of 12 Old 03-03-2012, 12:34 PM
How far away are you from Lynchburg? My wife and I will be moving there this summer for graduate school at LU.
SOLD:
2012 Flame Red JKUR- Manual w/ 4.10s & Nav
JCR Front Pre-runner & Rear Dagger, RK 2.5" Flex System, Bilstein 5100s, Teraflex Exhaust Spacers, Nitto Trail Grappler 35x12.5x17 Tires, Black ATX Slot 17x9 Wheels
post #12 of 12 Old 03-03-2012, 02:39 PM
rdlynch2's Avatar
The poly kits dont come with a front adjustable track bar or front disconnects?
2008 Black 2Dr 6spd D30/44
rdlynch2 is offline
