At first glance Ram 1500 calipers & rotors look very similar to the TF BBK, however I learned the rotor hat on the Ram is taller. The only way you'd know would be to buy a set for the Ram and roll the dice. The pads do work, however.
FWIW, I've had the TF kit on my '09 for quite some time now and its the fix, works great and is getting reasonable pad & rotor wear. Just get it and be happy. Get the master cyl, too, if you have one earlier than '10.
