Rock Krawler front track bar - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 02-24-2012, 06:54 AM Thread Starter
mgoony's Avatar
I ordered the RK heavy duty front track bar by itself.
Is there weight on the trackbar as the jeep sits there?
Do I need to lift the Jeep to take the weight off in order to remove the old OEM and replace it with the new one?
2011 Jeep Green JKUR
Cincinnati JKOs join our Facebook group
CJKC
Cincy JK Crew - rides only, no BS
mgoony is offline
post #2 of 12 Old 02-24-2012, 06:57 AM
You can remove it at ride height. Since you did buy an adjustable you will want to make sure the axle is centered. I use a ratchet strap at a angle from the axle to the frame to move things around, then adjust the track bar to the holes.
Be certain to torque the jam nuts and track bar bolts well.
post #3 of 12 Old 02-24-2012, 06:57 AM
spedly's Avatar
no.
Take the old one off. Shake the jeep to center the body over the axle. Measure and adjust. Install.
You can turn the steering wheel one way or the other to pull the body back and forth over the axle.
spedly is offline
post #4 of 12 Old 02-24-2012, 07:22 AM Thread Starter
mgoony's Avatar
Thanks fellas
CJKC
mgoony is offline
post #5 of 12 Old 02-24-2012, 08:33 AM
Sir
In the directions we supply (hopefully you got them), there are various measurements for different lift heights. That should be really close for starting purposes. Give us a shout if you have any questions...
Thanks for chosing RK...
RK
post #6 of 12 Old 02-24-2012, 09:47 AM
Slow and Low
Co4Lo's Avatar
Originally Posted by spedly View Post
no.
Of course you DON'T want to do this if you have a lift with long arms. It really sucks when the whole Jeep flops over on it's axle. Can really damage shocks and is a bitch to flop it back straight. Learned that lesson the hard way, many years ago.
Co4Lo is offline
post #7 of 12 Old 02-24-2012, 09:53 AM
jeepnick's Avatar
I almost learned this lesson the hard way this week
Pulled the track bar, tires were under load, whole jeep shifted right several inches, a tiny drop of pee came out...
jeepnick is offline
post #8 of 12 Old 02-24-2012, 09:54 AM
2k2wranglerx's Avatar
don't bother with the ratchet straps. seriously. it's way more headache than it's worth.
with the jeep sitting on the ground, adjust it to the length that you think will be close (maybe per rk's suggested length) and then attach it (hand tight) on the axle. then have a buddy/wife/girlfriend jump in the jeep and start it. have them turn the steering wheel slowly while you guide the upper flex joint into the trac bar bracket. literally as they turn the wheel the jeep will shift laterally (a different direction for either way they turn the wheel).
once it lines up slide the bolt in. have the person straighten the wheels and then take your measurements to be sure it's centered. i usually measure off the top of the spring bucket to the outside of a lug on the tire. if it's off pull the bolt and adjust the trac bar accordingly.
it's the quickest and easiest way to do it. no grunting or pushing or anything required.
on the rear the ratchet strap is a good technique though.
2k2wranglerx is offline
post #9 of 12 Old 02-24-2012, 12:55 PM
It's not more of a headache when by yourself. One ratchet strap takes all of a minute of my time to deal with. I am usually not in that big of a hurry to worry about it. Works out just fine.
Sent via paper airplane
post #10 of 12 Old 02-24-2012, 01:34 PM
set some beer outside the garage... some "new friends" will wander in lol
post #11 of 12 Old 02-24-2012, 01:40 PM
And the only thing holding your Jeep up if your Steering Wheel did not lock was the Coil Overs on your rig! That must have been exciting...
RK
post #12 of 12 Old 02-24-2012, 02:02 PM
jeepnick's Avatar
RK
Id Imagin exciting would be used if someone was watching me lol
I was scared to death
Reason the wheels were under load was cause I had to turn the wheel to move the hydro to get to the lower track bar bolt
jeepnick is offline
