what to know about a Tubing bender - JKowners.com : Jeep Wrangler JK Forum
post #1 of 26 Old 02-23-2012, 10:19 PM Thread Starter
red_man22's Avatar
Im looking into buying a tube bender. I have about 3K to spend on it and Im wondering who has what and what they say about it. I want the hole stand/ram/die setup. something I order and its ready to use when it hits my door step. As for Dies I want a 1.75 at least but I will be getting a 1.5 and a 2" also befor its all said and done.
So what have to got out there? What do I need to know when Im looking at one?
Build it! Run it! Break it! Repeat!
red_man22 is offline
post #2 of 26 Old 02-24-2012, 05:22 AM
Go to pirate and look under tools/supplies. They have several different vendors that sell benders etc.
Air over hydraulic?
Air over electric?
Max tubing size you will bend?
Max wall thickness tube you want to bend?
90 or 180 degree dies?
Vertical or horizontal orientation?
You can get in to a nice bender for 1k.
jeff76 is offline
post #3 of 26 Old 02-24-2012, 06:49 AM Thread Starter
red_man22's Avatar
ok Ill check it out. Thanks
post #4 of 26 Old 02-24-2012, 09:49 AM
Sahara Tan Rubicon's Avatar
http://www.ebay.com/itm/NEW-Hossfeld...ht_1053wt_1180
These are the way to go in my opinion. Adding a Ram kit is easy and they make dies to bend everything! If you look locally sometimes you can find a deal on one. I bought one a couple of years ago for $200, it had about $2000 worth of dies.
Sahara Tan Rubicon is offline
post #5 of 26 Old 02-24-2012, 10:06 AM
Slow and Low
Co4Lo's Avatar
I bought a Pro Tools 105 HD and made my own stand and Hydro setup.
I was going to buy the Pro Bender one, but decided I could make one better for less money...
I prefer the vertical because it takes up less space and is easy to wheel around.
Pro Bender:
http://www.probender.com/probender/d...ic-tube-bender
My Pro Tools/Home made:
Co4Lo is offline
post #6 of 26 Old 02-24-2012, 10:35 AM
Thisguyhasadd42's Avatar
Ya I'd take a look over on pirate lot of good info over there, but Co4Lo's looks nice
2010 Mango 2dr 6spd Rubicon
Thisguyhasadd42 is offline
post #7 of 26 Old 02-24-2012, 10:15 PM Thread Starter
red_man22's Avatar
The pro bender looks like a hell of a deal but all their dies only go to 110deg.
Here are the 2 I was looking at and leaning in the direction of
JD Squared, Inc.
Deluxe Model 32 Air / Hydraulic Tube Bender Kit
Model 32 Hydraulic Bender with air/hydraulic pump plus rolling floor pedestal,
magnetic base pointer, and sample bottle of bending lube.
Bender $1,900
1-5" $265
1-3/4" $300
2" $345
Notcher $220
Total $3030
Tube shark
Commercial electric/hydraulic power unit
Bender $2,100.00
1-5" $440
1-3/4" $481
2" $508
Notcher $220
Total $3750
post #8 of 26 Old 02-24-2012, 10:24 PM
quaylefarmer's Avatar
I have had a Pro Tools 105 for ~ 10 years with no problems.
My experience:
- I bought the following dies when it was new (1.75", 1.25", .75")
* The .75" has never been taken out of the box
** Having a 1.5" and a 1.75" is a waste of $ IMO
- How much tube do you plan to bend?
* We manually bend 1.75" x .120 wall without a ton of trouble. It's a workout but it's it's not too hard.
** If this is only for recreation use I would save the $
- Add a digital angle finder to your list of tools for the bender -very helpful
http://http://www.google.com/m/produ...ed=0CDQQ8wIwAA
Build Thread:
ACE Engineering
586-806-6641
[B]
quaylefarmer is offline
post #9 of 26 Old 02-24-2012, 10:26 PM
SIKJEEP's Avatar
I have a model 32 and love it
2015 JK Unlimited Anvil
SOLD -2009 JK Unlimited Rubicon Deep Water Blue
1987 YJ Stretched 60/14 40" LTB's
SIKJEEP is offline
post #10 of 26 Old 02-24-2012, 11:16 PM
My experience:
So why would having both 1.5 and 1.75" dies be a waste of money? Is it because you can bend 1.5" with the 1.75" die? I ask because I plan on building my stock of dies and don't want to waste money if I don't have to.
jimmyjammoto is offline
post #11 of 26 Old 02-25-2012, 08:33 AM
Slow and Low
Co4Lo's Avatar
Not sure if that's true. You can use any Pro Tools die. Same as mine. You just have to pull the pin at about 100*, run the ram back down, re-insert the pin, and keep bending.
Do they only spec it to 110* ??
The thing that sucks about the Pro Bender Hydraulic setup is that when you have to pull the pin, it can be a PITA because there is always a little tension due to springback. So guys tend to hammer the pins out and they get all banged up over time.
That's why I used a 2-way ram on mine. I can run it back a skosh to release the tension, and pull the pin with no effort. Works great!
Co4Lo is offline
post #12 of 26 Old 02-25-2012, 09:23 AM Thread Starter
red_man22's Avatar
I apolagize about that. I looked at it again now that Im not so tired and they do offer a 240deg die
post #13 of 26 Old 02-25-2012, 09:32 AM Thread Starter
red_man22's Avatar
Here is the price breakdown for that one
Pro Bender
Bender $2143
1-5" $260
1-3/4" $310
2" $310
Notcher$220
Total $3243
post #14 of 26 Old 02-25-2012, 03:44 PM
jd2 model 3 tube bender is the way to go
brady1929 is offline
post #15 of 26 Old 02-25-2012, 10:17 PM Thread Starter
red_man22's Avatar
Thats what Im leaning into I think
post #16 of 26 Old 02-25-2012, 10:28 PM
I do all cage and bumper work out of 1.75"
I have never had a need for 1.5"
The dies are exclusive.
Build Thread:
ACE Engineering
586-806-6641
[B]
post #17 of 26 Old 02-25-2012, 10:42 PM
VKS Fab
JK Vick's Avatar
I've had a pro tools 105HD for about 7-8 years with1.25-1.75 240deg. dies. A couple years back I converted it to air over hydro with the swag brackets and the harbor freight cherry picker ram. It bends everything I've thrown at it. The thickest/meanest material I've bent was some 1.5 188 wall dom. I've never had an issue with it, still works flawlessly, I've ran hundreds of feet thru mine. Main thing is, get yourself a good notched, it'll make life a lot easier.
Handmade One At A Time
GIVE US A CALL 559-392-3145
JK Vick is offline
post #18 of 26 Old 02-26-2012, 07:46 AM Thread Starter
red_man22's Avatar
[QUOTE=Main thing is, get yourself a good notched, it'll make life a lot easier.[/QUOTE]
Good to know. I will use the hell out of it so I planned on that in the bender price also. otherwise it would be like Mac with out the cheese
Im getting things together to build a 3-4 seater buggy. I have the axles Dana60/14bolt Seats with 4pt harness Still need the back seat. I have Nice guages, race fuel cell. Im still looking for the powerplant but it will be Fuel injected an auto tranny, and shocks. Then all the little joints and such
post #19 of 26 Old 02-26-2012, 07:47 AM
Obsessed
Extreme454's Avatar
You can find used manual Pro Tools with dies for under $1000. We built many cages for years with one. But if you're looking to do a lot of bending, a hydraulic bender is the only way to go. We've had a JD Squared Model 4, since 2007. It's amazing.
check out the 'albums' page, for a few jeep builds
Extreme454 is offline
post #20 of 26 Old 02-26-2012, 07:51 AM Thread Starter
red_man22's Avatar
Im leaning in the direction of the Electric/hydrolic Then I dont have to have my compressor running none stop and I can listen to the radio while working on it. I also build a lot of bumpers and cages. Actually Im not even the one paying for the bander. I have 2 Roll cages in toyota pickups, and 3 front bumpers I have built the people want to add some tube work to so that is whats paying for the bender. so I hope its not something that just sits around like my cutting torch has since I got a plazma haha
post #21 of 26 Old 02-28-2012, 06:02 PM
I have a JD2 model 3 and really like it. You can always add the hydraulic set up to it if you plan on bending a lot of tube which it sounds like you are. I would suggest getting 180* dies, nice to have the ability to bend more then 90* when you need to.
HOT_DAMN is offline
post #22 of 26 Old 03-01-2012, 04:29 PM
tankcj's Avatar
I don't know how to work it but I want one...
tube bending - YouTube
2011 2dr Rubicon, Auto, 3.5 AEV Premium, PS Brawler Lite bumper and skid and Evap skid, 35" KM2s, Raceline Monster Beadlock, 5.13 gears, Trailgater, Expedition One Rear Bumper and Tire Carrier, ACE Rock Sliders, Warn Power Plant, ORW trans cooler
tankcj is offline
post #23 of 26 Old 03-01-2012, 05:01 PM
Slow and Low
Co4Lo's Avatar
I kinda wanna hump that thing! Wow!
Co4Lo is offline
post #24 of 26 Old 03-01-2012, 07:05 PM
usmcdoc14's Avatar
Fitting thread I just won a RDB-050 Tube Bender and a TN-250 notcher from Baileigh Industrial on Pirate4x4
http://www.baileighindustrial.com/be...bender-050.php
Ya, I am bragging
Most people I have seen witha ProTool or a JD style bender have no problems for hobbiest use and the usual upgrade is an air over hydro system just so you are not sweating your butt off in the summer.
usmcdoc14 is offline
post #25 of 26 Old 03-01-2012, 08:44 PM Thread Starter
red_man22's Avatar
Ya, I am bragging
You Won? I want to win! I was planning on getting the Electric over hydrolic right off the bat because I hate my compressor running all the time. Its inside the shop and just to damn loud. (32gallon Craftsman)
I dont want to know how much but what you could build is endless!
