Drivers Side Thunk on Potholes - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 02-23-2012, 11:03 AM Thread Starter
RUCKDOG's Avatar
Ok, I'm slowly getting all the bugs worked out from my install and DW episodes (which has been resolved) and am now left with only one thing to fix.
Every time I hit a pothole or a rough spot with the front driver side tire, I get a pretty solid thunk from the driver's side. This does not happen if I hit a pothole with the passenger side tires. I can feel the thunk on the floor board but nothing through the steering wheel. The smaller the bigger bump, the less the thunk, but still there. It is almost like the spring is catching up to the mounts that is creating the thunk - but that doesn't make a whole lot of sense.
I've spent more time than I care to admit in trying to track this down.
Here is my setup:
- 2.5 RK Max Travel System, everything is tight and has been checked for proper torque
- Still running stock wheels and tires while waiting for the GY MTR/K replacements.
- Skid row engine/transmission plate - I originally thought the exhaust was banging on the plate, but it was not happening before the install and I have adjusted the hanger bracket upward since the install.
- replaced the ball joints while waiting for the GY MTR/Ks - what the hell, the JK has almost 35K on it and I had several episodes of DW. Thought it was a good idea. Turned out to be a good call as the lower drivers side BJ was not looking to good. Certainly got rid of the shimmy when I hit bumps.
Any ideas or thoughts would be greatly appreciated.
Thanks,
RUCKDOG is offline
post #2 of 7 Old 02-23-2012, 11:23 AM
I think I have a similar thunk as well in mine but haven't bothered to track it down. It's either my aftermarket muffler slapping the floor, the crap in my rear cubby moving or hell about to break loose.
post #3 of 7 Old 02-23-2012, 11:26 AM
Not sure if this is it, but after my lift, the front sway bar would hit the protruding framing crossmember tube on the drivers side. You'll see scratch marks on the tube end if this is what you are experiencing (see pic). Easy to fix by grinding back the tube a bit or pushing the sway bar back to the other side a it.
Vince1 is offline
post #4 of 7 Old 02-23-2012, 01:08 PM
Butkus34's Avatar
Ditto on the electrical tape around the door latches, cured mine
2007 JK Unlimited Sahara, Blacked Out
3.5 inch lift sitting on 35's
Poly Performance/Synergy Suspension Ball Joints
Smittybilt Oversized Tire Carrier
Butkus34 is offline
post #5 of 7 Old 02-23-2012, 01:23 PM
frankie945's Avatar
Loose sway link or lower shock mount. Tighten the crap out of the lower shock mount.
frankie945 is offline
post #6 of 7 Old 02-23-2012, 02:07 PM
RIP Brad
abendx's Avatar
I had the same thing (or similar)..... narrowed it down to the springs moving around. Tack welded that shit up and haven't heard it since!
abendx is offline
post #7 of 7 Old 02-23-2012, 04:33 PM Thread Starter
RUCKDOG's Avatar
Originally Posted by PKDailey4 View Post
Wrap some electric tape around the door latch in the driver side door jamb and see if it goes away.
Thanks, I'll give this a shot.
I pulled everthing out of the jeep and taped down the front shackles. No joy. Might pull the skid plate off this weekend and see if that resolves the issue. I'm afraid that all hell is about to break loose.
Great idea...had high hopes this was it! But nope, not so easy....damn!
I've already looked at both and tightened the lower shock mount. Once again no joy!
Going try this over the weekend! Maybe it will work.
Because weekends are made to work on Jeeps!
thanks all
RUCKDOG is offline
