installing axle shafts - JKowners.com : Jeep Wrangler JK Forum
post #1 of 17 Old 02-21-2012, 05:09 PM Thread Starter
Nwapache's Avatar
So, i'm planning on upgrading to RCV fronts and CM rears on my 08 rubi and i'm curious if its technically challenging? Or is it a straightforward R&R job?
2010 JK Rubicon- meh 2dr sold
2012 JKU Rubicon- bored sold
2015 JKU Rubicon- 3rd times a charm?
Nwapache is offline
post #2 of 17 Old 02-21-2012, 05:11 PM
steve79's Avatar
Simple, just take your time and you'll be G2G!
WORK HARD... PLAY HARDER!
steve79 is offline
post #3 of 17 Old 02-21-2012, 05:14 PM
You'll need a 35mm[?] socket, which most people don't have, and certainly a 13mm 12point socket for the unit bearings. Other than that, it's basic tools to get the job done.
post #4 of 17 Old 02-21-2012, 05:31 PM
Fklein6768's Avatar
There are some good write ups on both ends. Easy job!
Is this thing on?.....
www.4x4s-pod.com
Fklein6768 is offline
post #5 of 17 Old 02-21-2012, 05:44 PM
You MIGHT need a slide hammer if your shafts haven't been out and you have lots of miles on them.
Other than that, shouldn't be more than a 30 minute job for all 4.
2008 JK X 2DR NSG370
Time to build the TONS!
Long Island Off Road Club
NOVA4x4
Suffolk JK is offline
post #6 of 17 Old 02-21-2012, 05:48 PM
VKS Fab
JK Vick's Avatar
36er
Handmade One At A Time
GIVE US A CALL 559-392-3145
JK Vick is offline
post #7 of 17 Old 02-21-2012, 06:37 PM
Fronts are super easy. Check out the write up section
post #8 of 17 Old 02-21-2012, 06:45 PM Thread Starter
Nwapache's Avatar
Sweet, thanks for all the positive replies
Nwapache is offline
post #9 of 17 Old 02-21-2012, 06:47 PM
Originally Posted by JK Vick View Post
36er
My 36mm works, but isn't the correct size.
post #10 of 17 Old 02-21-2012, 07:58 PM
VKS Fab
JK Vick's Avatar
Well a 35mm you gotta beat on with a hammer, but it'll work. IMHO its a 36mm. That, or an american equivalent.
https://www.jkowners.com/forum/showthread.php?t=2879
JK Vick is offline
post #11 of 17 Old 02-21-2012, 08:16 PM
After looking into it, it'd seem that is the case. It's some magical size.
1-3/8 = 1.375"
35mm = 1.378"
36mm = 1.4173"
1-7/16 = 1.4375"
There isn't much for a common SAE size between 7/16" and 3/8"!
post #12 of 17 Old 02-21-2012, 08:28 PM
Fklein6768's Avatar
35mm will work on most but not all-if ur gonna buy one get a 36mm. I had three the 35 mm fit and one that wouldn't...:what:
www.4x4s-pod.com
post #13 of 17 Old 02-21-2012, 08:36 PM
VKS Fab
JK Vick's Avatar
1-3/8 = 1.375"
35mm = 1.378"
36mm = 1.4173"
1-7/16 = 1.4375"
Haha... yup! Well when i do it i use my super sercet 1 13/32 socket. It's only available from your Snap-on guy for $1300.00
JK Vick is offline
post #14 of 17 Old 02-22-2012, 09:47 AM
highwayman's Avatar
Had no issues w/my metrics. Dont forget to jack up one side at a time when doing the job. Itll force the fluid to the other side of the diff & save the hassle of diff fluid coming out if you do it level, the mess & having to top off.
highwayman is offline
post #15 of 17 Old 02-22-2012, 09:55 AM
just in case you can't find the write ups.
front rcv https://www.jkowners.com/forum/showthread.php?t=11217
rears https://www.jkowners.com/forum/showthread.php?t=3761
post #16 of 17 Old 02-23-2012, 07:39 AM
jkdrone's Avatar
For the fronts, you can get them out quickly using a socket or bolt wedged in there blocking the short half's ability to turn, and then use the power steering to turn into it. It's how I pop my fronts out in 5 seconds flat.
!c
jkdrone is offline
post #17 of 17 Old 02-23-2012, 06:35 PM
Great shafts and they are easy to install but let it be known that if you were ever to blow your front locker you will have to replace it with another factory e-locker because arb does not make one that will work with the rubi splines. You can however get the rcv in a 35 spline that will work with the arb. Just thought I would throw that out to you in case you didn't know.
