GenRight JK crawler tank? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 22 Old 02-20-2012, 05:44 PM Thread Starter
terrahawk's Avatar
Has anybody installed on of these? I need pics to see how much axle clearance there is...thanks.
terrahawk is offline
post #2 of 22 Old 02-20-2012, 07:34 PM
Rafic's Avatar
Send a message via MSN to Rafic
HEMI 6.1L - 4.88 Gears - OME HD Lift - OME Steering Stab - Front & Rear RK Trackbar + Relocation Bracket - ARB Deluxe Front Bumper - Warn 9.5cti - IPF XS900 - 35" Cooper STT - 17" Ruged Ridge Wheels - ARB Diff Covers - AEV Rear Corner Guards - Mopar Rear Light Guards - Rugged Ridge Hi Lift Mount - Daystar Dash Top - Daystar Switch Panel - Pioneer AVH 4100 - 2x MB Quart Component Sets - 1x R.F. AMP - 1x Pioneer AMP - 1x Pioneer Small Sub Enclosure
Rafic is offline
post #3 of 22 Old 02-20-2012, 09:06 PM Thread Starter
terrahawk's Avatar
I've seen that one, doesn't show what I need to see. i need a pic from the sode to chack diff clearance.
post #4 of 22 Old 02-21-2012, 01:08 PM
md_rubi's Avatar
Hopefully I can send you some pics soon. What shots are you looking for?
md_rubi is offline
post #5 of 22 Old 02-21-2012, 01:18 PM Thread Starter
terrahawk's Avatar
Awsome, side view to gauge distance between the diff and the tank skid plate.
post #6 of 22 Old 02-21-2012, 03:03 PM
We are working with one right now!
post #7 of 22 Old 02-21-2012, 03:29 PM Thread Starter
terrahawk's Avatar
Jeremy, I'm trying to get 4" out of your 3+ stretch and am trying to avoid using a fuel cell in the back to conserve space. It's getting 4 linked, only from the diff to the frame vs using the bridge you guys make.
post #8 of 22 Old 02-21-2012, 04:32 PM
Give us a shout and we will try to figure out what is best for you!
RK
post #9 of 22 Old 02-21-2012, 04:36 PM Thread Starter
terrahawk's Avatar
Dave Watts says I have 3.5" to work with, since I have no rear cross member, i think I can push it back another inch or so and modify my PSC bumper as the rear cross memebr / mounting point. Headed to the shop now for fun with measuring tape!
post #10 of 22 Old 02-21-2012, 06:33 PM
I wouldn't let a tank be the limiting factor in your build. More wheelbase will make your rig wheel so much better that it's worth sacrificing space for a fuel cell in the tub.
What size tire are you planning to run?
Just my 2cents
jeff76 is offline
post #11 of 22 Old 02-21-2012, 06:39 PM
Mr.RonGilbert's Avatar
A fuel cell may be perfect for Terrorchicken...
After wheeling with Jody a few times I have come to realize that he is ultra-conservative when it comes to fuel. He even turns his Jeep off mid-climb just to save some.
Mr.RonGilbert is offline
post #12 of 22 Old 02-22-2012, 08:47 AM Thread Starter
terrahawk's Avatar
Just my 2cents
I run 37's, have no plans to go any bigger. Thats all a 2 door really needs and I don't have any manhood issues requiring 44's to compensate hahahaha. The target wheel base is 100" and I need to get right at 4 in the rear to get there, so if I can run the tank in the rear like this Genright set up, I'll be happy. The other factor in all this is that I drive the damn thing everyday, so crawling up into the tub every time I need to fill up just isn't appealing.
Now I still have the cell you have on the list, think I could mount it in the rear by the tail gate and fueling wouldn't be a big deal.
post #13 of 22 Old 02-22-2012, 09:32 AM
So you plan to keep it at 100" wb and 37's forever, even after its no longer Ur dd?
jeff76 is offline
post #14 of 22 Old 02-22-2012, 09:43 AM Thread Starter
terrahawk's Avatar
I figured I'd get this Jeff, and I'm still thnking it through. Definitely will not be comp cutting it though. 103" would be max.
post #15 of 22 Old 02-22-2012, 09:42 PM
Here is a shot right below the gap you're asking about with a Dana 60.
Let me know if you need any more shots.
DE
2007 JKU, 6.1L HEMI, ProRock 60 front, full floater Dynatrac 60 rear, and 40's.
Needajk is offline
post #16 of 22 Old 02-22-2012, 09:44 PM
One more.
Needajk is offline
post #17 of 22 Old 02-22-2012, 10:34 PM Thread Starter
terrahawk's Avatar
Thanks! It definitely won't work for me.
post #18 of 22 Old 02-22-2012, 11:43 PM
ADDICTION II build begins....
TXROCK's Avatar
I was going to say to give Dave a buzz and he could send you some pictures!
Trying to catch up as I just finished 16 hours of flying and waiting on the last 8 hour flight leg to go home!
U.S. Army
TXROCK is offline
post #19 of 22 Old 02-23-2012, 08:34 AM
cjcraig7's Avatar
If you ever want more WB - there is always the other end.
cjcraig7 is offline
post #20 of 22 Old 02-23-2012, 08:39 AM
jss
jss's Avatar
LS in a JK
We use a TJ gas tank from a 2005/2006 Jeep and we are getting four inches. Are Jeep the GuineaPig the wheel base is about 104, we pushed the front out 6 inches.
I will get some pics of are Jeep.
jss is offline
post #21 of 22 Old 02-23-2012, 04:15 PM
gfe jeep's Avatar
I was hoping you might offer that as a kit of some sort......
2008 Jeep Wrangler Sahara 2 Door
Treks Rear Shock Relocators
MOPAR Extended Rubicon Rock Rails
Expedition One Front Skid
Kilby Muffler Skid
Rockhard 4x4 Belly Skid & Evap Skid
Olympic Receiver Hitch Front Bumper
Tuffy Stereo Lock
Cobra 75 CB
Cooltech CB Antenna & Mount
Kilby Switch Panel
1500 Watt Power Inverter
Glow Lights Footwell Lights
OK Offroad Fuse Box
Front & Rear ARB Lockers
5.13 Gears
gfe jeep is offline
post #22 of 22 Old 02-23-2012, 09:35 PM
jss
jss's Avatar
LS in a JK
It is very easy to install and very cheap, but it does not work for every one. We have not yet found an angel for a kit, like what would some one like to see for a kit.
jss is offline
