lift install question - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 02-19-2012, 03:04 PM Thread Starter
So i installed a TF 2.5" coil lift this weekend. All went well despite being new to suspension upgrades. My question is why do u have to loosen up the control arms and then tighten them again when the jeep is sitting back on the ground again. The control arms seem to all be on pivot points anyways at each end, so i dont see what it matters. I did it as instructed, and it rides great after all is done, just hoping to understand why i did it, lol...
jeep#4 is offline
post #2 of 6 Old 02-19-2012, 03:09 PM
Broncojohn's Avatar
Some control arms have fixed rubber that stays in place when you tighten them in the bracket. If you put a lift on and don't loosen the bolt, the arm will be preloaded and cause the Jeep to sit different.
Broncojohn is offline
post #3 of 6 Old 02-19-2012, 03:15 PM
^this and prematurely wear the bushings.
post #4 of 6 Old 02-19-2012, 03:16 PM
HighTower's Avatar
Would it make it ride stiffer?
Sent from my iPad using Tapatalk
2010 JKU Sahara
Teraflex 2.5 Coil Lift w/ 9550 Shocks
Teraflex Quick Disconnects
Moto Metal 17" 950s
Nitto Trail Grapplers 35x12.5x17
Superchips Flashpaq
HighTower is offline
post #5 of 6 Old 02-19-2012, 03:30 PM
I'd say so, however a pretty negligible amount. Probably won't be able to tell much of a difference before and after.
post #6 of 6 Old 02-19-2012, 04:34 PM Thread Starter
Thanks guys!
jeep#4 is offline
