REGEAR ASSISTANCE PLEASE!!!! - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 02-19-2012, 10:25 AM Thread Starter
NascarRubicon's Avatar
so otnoc and i spent all day regearing his front 30 with superior 5.13s and we ran into a problem...we cant get the pattern right and were binding in one spot...were using all new bearings and races, stock pinion shim plus .015, stock carrier shims, backlash is at .0085...we torqued the ring gear properly but now im thinking the ring gear isnt set correctly cause its binding in just one spot...pinion is set to 30 in/lbs turning
here are some pics of the pattern we have with with the stock shim plus .015...we have the tiniest bit of binding in one spot...no binding with .010 but need to move the pattern...we were at it for 12 hours and started second guessing every move we made so some more expert help would be appreciated
"Eat Liquid Gold"
NascarRubicon is offline
post #2 of 12 Old 02-19-2012, 10:45 AM
Broncojohn's Avatar
Less shim. Go thinner then factory.
Broncojohn is offline
post #3 of 12 Old 02-19-2012, 10:49 AM
Broncojohn's Avatar
in case you didn't have one.
http://www2.dana.com/pdf/5717.pdf
post #4 of 12 Old 02-19-2012, 10:51 AM Thread Starter
thats what i started thinking at the end of the night...is it a general rule when working with jk rears when going bigger youre gonna have to loose pinion shim?
"Eat Liquid Gold"
post #5 of 12 Old 02-19-2012, 11:08 AM
Broncojohn's Avatar
Not sure about a general rule.
My front stayed the same and the rear I had to start from 0. I think I ended up with .012.
post #6 of 12 Old 02-19-2012, 01:18 PM
Otnoc311's Avatar
Thanks for the info bronco.
aka- Brian
08' JKU on 38's... parted out and SOLD
13' JKU Rubi... On HOLD, 04' LJ to suppliment
Rise and Rise Again Until Lambs Become Lions
Otnoc311 is offline
post #7 of 12 Old 02-19-2012, 01:31 PM
pixeldzn's Avatar
Just went thru this last weekend. Hours and hours of second guessing the shims, only to go back to stock on the carrier shims, and close to stock on the pinion shim. When we originally tried the stock shims only, the pattern wasn't right, but when we went back to it magically things fell into place. Same thing might have happened to you.
If that doesn't work, the pattern says you need to adjust the pinion shim. That pattern should be more toward the middle of the gear, not out on the edges. We had the exact same symptom when setting up the rear as well, took out .003 when the pattern looked close, but it was binding and everything was perfect thereafter.
- offroad inspired decals for your jeep
2008 Unlimited Rubicon - Silver (Locked and Loaded)
2014 Unlimited Sport - Billet Silver (Mall Crawler)
pixeldzn is offline
post #8 of 12 Old 02-19-2012, 04:57 PM
On these dozens of JKs I've done, adding .002 to the rear D44 pinion shim, keeping the stock carrier shims makes a perfect pattern ONLY if it's a 0 gear.
On the front, keeping the stock pinion shim and adding .003 to the driver's side of the carrier makes it tighter (ALL JKs I've done the D30 carrier/ring LITERALLY falls right out once bearing caps are removed) and makes a perfect pattern. ONLY if it's a 0 gear.
This is using Yukon's gear sets and have yet to see a variation, +/- .001. I keep my backlash a little tighter, .005-.006.
Your pinion shim is WAY big.
2008 JK X 2DR NSG370
Time to build the TONS!
Long Island Off Road Club
NOVA4x4
Suffolk JK is offline
post #9 of 12 Old 02-19-2012, 05:54 PM Thread Starter
thanks...i think we came to that conclusion at the 12 hour...well take another crack at it soon
"Eat Liquid Gold"
post #10 of 12 Old 02-19-2012, 06:48 PM
Otnoc311's Avatar
I'll get it back apart hopefully tomorrow and we'll go from there.
Sent from the Island of Misfit Toys
aka- Brian
Otnoc311 is offline
post #11 of 12 Old 02-20-2012, 09:16 AM
Yep, way to deep. Pull that 015 back out....back to stock...055...?
Make sure your B/S is close, snap a pic and post it back here.
FWIW I had rear gear from the same company with a tight spot.
2012 JKU
Under Construction....always!
2012 GT500 Fast...er!
GT500 is offline
post #12 of 12 Old 02-20-2012, 11:42 PM Thread Starter
ok cool...i was thinking the ring was off...but couldnt get .001 feeler in anywhere around the rim...were gonna get back on it wed morning... got new bearings coming...dont remember the stock pinion shim size but when we ran the pattern with all stock it was off, no binding either...it was my fault ultimately for this shit cause i was reading the coast side for adjustment and all but disregarding the drive side... dumbass
"Eat Liquid Gold"
