Crown or moog tie rod end es3426 - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 02-16-2012, 11:49 AM Thread Starter
Crazecodyk's Avatar
Which is beefier...this is the left inner at pitman arm...tore boot on factory joint so replacing it just on the fence between these brands.
Crazecodyk is offline
post #2 of 9 Old 02-16-2012, 11:57 AM
cru9's Avatar
Moog
cru9 is offline
post #3 of 9 Old 02-16-2012, 12:47 PM
Moog.
My OEM replacement Crowns boots lasted all but 10 months. You can physically see the ball in the joint.
Replaced with greasable Moogs about 6 months ago. So far so good.
2008 JK X 2DR NSG370
Time to build the TONS!
Long Island Off Road Club
NOVA4x4
Suffolk JK is offline
post #4 of 9 Old 02-16-2012, 12:58 PM
JeepingGreen's Avatar
If you're referring to the tie rod end used on the drag link - think it's the ES3624 (http://www.moog-suspension-parts.com...od=MOOG-ES3624). I am using one now.. Only two complaints - the zirk fitting thread was stripped (the thread in the TRE, not the fitting) and I couldn't get the zirk fitting on.. Also, even though it's only a few months old, it looks like it's 4 years old because of the rust/oxidation..
Here's a vid of it in action..
JK Front End - Drivers Side Low - 1.MP4 - YouTube
JeepingGreen is offline
post #5 of 9 Old 02-16-2012, 08:16 PM
I've used the Moog for a long time now and they hold up great. I haven't ever used Crown so I can't comment on them.
post #6 of 9 Old 02-16-2012, 08:44 PM
Joneszj's Avatar
spray the moog end down pretty good with wd 40 and it won't rust. moog for the win.
1972 Commando on Tons & 40s
Joneszj is offline
post #7 of 9 Old 02-17-2012, 09:47 AM Thread Starter
Crazecodyk's Avatar
I got a moog last night..for 27 bucks we'll see how it goes...it's def a part that i know i'll probably need to keep a spare of
post #8 of 9 Old 02-17-2012, 10:15 AM
moog
jkruby is offline
post #9 of 9 Old 02-17-2012, 11:31 AM
rdlynch2's Avatar
When i had to replace my draglink for an RK HD, I went with the crown, as far as I know they are the same as factory. According to RK, thr factory is the way to go. At least for the TRE at the pitman. Apparently suppose to last a while.
2008 Black 2Dr 6spd D30/44
rdlynch2 is offline
