Hemi JK Steering pump whine? Video inside - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 02-15-2012, 06:04 PM Thread Starter
Rafic's Avatar
Send a message via MSN to Rafic
Unhappy Hemi JK Steering pump whine? Video inside
So I took a a video of what seems to be the steering pump whining. Mind you, the unit is a brand new one from the dealership. Could it be defective? Or it needs more bleeding? I used the mopar power steering fluid as per the dealership's tech manager's recommendation. He advised against using ATF+4 fluid. Here's the vid:
Hemi JK Steering Pump Whine - YouTube
HEMI 6.1L - 4.88 Gears - OME HD Lift - OME Steering Stab - Front & Rear RK Trackbar + Relocation Bracket - ARB Deluxe Front Bumper - Warn 9.5cti - IPF XS900 - 35" Cooper STT - 17" Ruged Ridge Wheels - ARB Diff Covers - AEV Rear Corner Guards - Mopar Rear Light Guards - Rugged Ridge Hi Lift Mount - Daystar Dash Top - Daystar Switch Panel - Pioneer AVH 4100 - 2x MB Quart Component Sets - 1x R.F. AMP - 1x Pioneer AMP - 1x Pioneer Small Sub Enclosure
Rafic is offline
post #2 of 6 Old 02-15-2012, 06:07 PM
CeeeJaySeven+JKU's Avatar
Sounds like air. If the pump were bad it wouldn't wine differently when wheel is turned.
Big B.
2011 4Dr Unlimited... Rubi springs & shocks, Rubi tires, JKS QD's, CoverKing Seat covers, Rugged Ridge trail doors, A.C.E. stubby bumper, A.C.E. Rock Rails, A.C.E. Hi-lift jack mounts, Superwinch LP8500.
1983 CJ7 LAREDO, AMC 360, 5" lift, 33's
CeeeJaySeven+JKU is offline
post #3 of 6 Old 02-15-2012, 06:38 PM
jss
jss's Avatar
LS in a JK
What pump did you use and did you use the old trans cooler for a power steering cooler.
It might be over heating.
www.jeepspeedshop.com
jss is offline
post #4 of 6 Old 02-15-2012, 07:26 PM Thread Starter
Rafic's Avatar
I used pump with part number 5290778AA. Its an 07 WK SRT8 pump. And no i did not use the old tranny cooler as PS cooler. Its kinda cold outside and im only doing highway driving.
Rafic is offline
post #5 of 6 Old 02-16-2012, 11:47 PM
cloud is offline
post #6 of 6 Old 04-16-2013, 03:23 PM
power steering whine
i have tried everything to get rid of that whine, i even changed the pump but it does the same thing any tips would be great. my swap will finally be done after this. thanks
08 JKU 5.7 6spd
06 Dodge 2500 Cummins
yanktank0906 is offline
