2012, 6" Teraflex LCG w/ 37s Critque - JKowners.com : Jeep Wrangler JK Forum
post #1 of 52 Old 02-15-2012, 12:29 PM Thread Starter
pluke the 2's Avatar
So we're getting rid of our 2011 to get a new 2012 4 door rubicon.
The reason is because we want the new engine.
Old Jeep:
With that said...
Our intention for the 2012 Rubicon is going to be similar to the old jeep.
We will be buying the Elite LCG JK 6" Long Arm Suspension System by Teraflex and will be running 37" General Tires with 4.5" wheels.
We will also be getting the front and rear drive shafts with Fox shocks.
The question is:
What else would you buy at the same time with this suspension package to compliment the way it drives?
I remember installing our current 4" Long arm kit to realize it didn't come with a flip kit or anything like that and it ended up costing a few more dollars and our time to receive the additional parts and it was inconvenient, to say the least.
This is a DD and we will be using it for camping maybe once every few months.
Thanks in advance.
Cali Crew
My Youtube Channel:
pluke the 2 is offline
post #2 of 52 Old 02-15-2012, 12:31 PM
ALASHA's Avatar
Since LCG stands for Low Center of Gravity, can you really still call the 6" kit that?
Are you doing anything in terms of gearing? Beef up the front axle...
ALASHA is offline
post #3 of 52 Old 02-15-2012, 12:40 PM Thread Starter
yeah. 538s and strengthening the axle will be addressed.
Cali Crew
My Youtube Channel:
post #4 of 52 Old 02-15-2012, 12:40 PM Thread Starter
i woudlnt call it lcg if it wasnt on their website.
we got a 2" kit on our 2 door with 37s
Cali Crew
My Youtube Channel:
post #5 of 52 Old 02-15-2012, 01:35 PM
highwayman's Avatar
Its only money I guess, didnt u just dump the cash on a SC on it too?
highwayman is offline
post #6 of 52 Old 02-15-2012, 01:36 PM
Do those Generals come in a 37" now?
Alaska-HWY JK is offline
post #7 of 52 Old 02-15-2012, 01:50 PM Thread Starter
ya we put a rips super charger in it and its disappointing.
general makes 37" tires but not for the public. only special people who have access can buy them.
Cali Crew
My Youtube Channel:
post #8 of 52 Old 02-15-2012, 02:05 PM
highwayman's Avatar
6" w/37s???
post #9 of 52 Old 02-15-2012, 02:08 PM
ugh i would kill for some grabber 37" tires with the red letters............
-Marc
Coming up:
14 Bolt rear ARB w/ 5.38
EVO Long Arm
40/42 MTR's
17" Spyderlock Beadlocks
post #10 of 52 Old 02-15-2012, 02:27 PM Thread Starter
the plan is to run 37's without modifying the fenders. so 6" shouldhelp
Cali Crew
My Youtube Channel:
post #11 of 52 Old 02-15-2012, 03:26 PM
axsys's Avatar
Is there a specific reason you don't want to modify the fenders? I would say the positives of staying with a shorter lift outweigh the cons on aftermarket fenders.
If you do decide to stay at 6", you might want to consider a PR44 in front to address the pinion angle/caster issue. We are hearing about more transfer case failures do to driveshaft angles and it would be best to start it right from the beginning.
Aside from that, it looks like their 6" kit comes with a flipped drag link as well as their trackbar bracket and brace setup, so you should be covered for steering, unless you want to go with hydro-assist, which is mainly personal preference.
axsys is offline
post #12 of 52 Old 02-15-2012, 04:32 PM
TeraFlex's Avatar
Here's mine with 37" MTR's and a 4" LA with the stock flares. You'll have alot of space with the 6" kit.
801-713-3314
TeraFlex is offline
post #13 of 52 Old 02-15-2012, 04:47 PM
20JK10's Avatar
New driveshafts
Wrangler Mountain Edition
Rock Krawler Synergy JKS LoD Goodyear
20JK10 is offline
post #14 of 52 Old 02-15-2012, 05:42 PM
ORWJK's Avatar
One of our guys has a JK running 35's on a 4" LCG kit, and there's definitely room to spare with the 35's. A 6" lifted JK is a TALL beasty....
and by the way, good choice on tires. I'm running the General's too...
1-800-341-7757 Ext. 123
Ask for Justin
ORWJK is offline
post #15 of 52 Old 02-15-2012, 05:46 PM
nlgrav182's Avatar
Example of 6" with 37's:
OKAY FUCKMOUTH.
nlgrav182 is offline
post #16 of 52 Old 02-15-2012, 06:38 PM
Just like axsys recommended, PR44 to correct your caster and pinion angle.
You may want to reconsider those 5.38 gears with 37's! (2012)
With an auto I'm turning 2750 rpm's with 4.56 325/75/17 (35in) @ 70 mph
These 12's do not require gear like the 11's and down...
I spend a lot of time @ 70 mph, I may stick a set of 4.10's in mine.
I would say 4.88 max with 37's
2012 JKU
Under Construction....always!
2012 GT500 Fast...er!
GT500 is offline
post #17 of 52 Old 02-15-2012, 06:52 PM
Here's mine on a Teraflex 3" LCG longarm system on 37" tires. 6" is alot for 37" tires. You could run 40" or even 42" on 6" of lift.
Semper Fi
highoctane is offline
post #18 of 52 Old 02-15-2012, 07:15 PM
dont forget the exhaust extensions needed for the crossover issue! only a 50$ fix
2012 JK, 3.6L Pentastar, 4" Suspension Lift, 35" Kelly Safari TSR's, Raceline Raptors 17x9, Rampage Side Steps
Maybe they just corrected your ridiculous mistake. Who the fuck orders chrome anything?
xvcrysisxv is offline
post #19 of 52 Old 02-15-2012, 07:15 PM
Too much lift, them calling it lcg is laughable unless they intend on you running 42's with it.
Rescue green 07 2-door on 35's
viperbluelx is offline
post #20 of 52 Old 02-16-2012, 09:20 AM
TeraFlex's Avatar
Skip the PR axle and get a TeraFlex JK 44 axle instead. Also keep in mind that you will need to replace the front driveshaft also.
801-713-3314
TeraFlex is offline
post #21 of 52 Old 02-16-2012, 09:30 AM
ChrisW's Avatar
The difference being?...
ChrisW is offline
post #22 of 52 Old 02-16-2012, 11:10 AM
The Teraflex 44 is a few hundred cheaper. You have to get the PR44 Unlimited which costs more than a standard PR44, to get the caster correction you need. The Teraflex 44 comes with that at no extra charge.
PR44
http://www.quadratec.com/products/52442_3000.htm
Teraflex 44
http://www.teraflex.biz/jk-front-ter...-0-3-1504.html
The Dynatrac can be had elsewhere for cheaper than qtec I'm sure, and I'd bet vendors will give better than Teraflex's list price on the Tera44, putting it under the $2k mark. I'm planning on a CRD 60 in the rear and a Tear 44 up front.
Sent from my iPhone 4 using Tapatalk
Semper Fi
post #23 of 52 Old 02-16-2012, 12:09 PM
frankie945's Avatar
4" lift would be perfect for 37s and room to grow.
Here is 5.5 springs and 1.25bl on 37s with flats and without flats.
[IMG][/IMG]
[IMG][/IMG]
frankie945 is offline
post #24 of 52 Old 02-16-2012, 12:15 PM
ADDICTION II build begins....
TXROCK's Avatar
sent you a PM with another recommendation. But for the axle, don't forget to include regear, axle sleeves, C-Gussets, possibly truss it, etc. depending on what you do with the current axles or what comes with the upgraded axles if you buy them. Strengthen the axle is highly recommended as everyone has said!
U.S. Army
TXROCK is offline
post #25 of 52 Old 02-16-2012, 12:22 PM
10jk's Avatar
I run a 4" with 3/4" spacer in front and metal cut for 40's, I think 37's and a 4" is about right and your CG will be better for wheelin. That's why I went 4", for lower CG. (see my album)
2010 JKUR, 4" Pro C., 3/4" f Daystar spacer, 5.38's, EVO sleeve/gusset/custom trussed, Rear Ten Factory axle shafts, 1.5" wheel spacers, Pro C. 17 x 9 wheels, 38 x 14.50 x 17 MTR's, SuperChip FP, no fenders, B&M Tranny cooler, Magnaflow, Fr./ Rr. frame hacked off, HD Balls
29,000 miles as of 12/13/14
10jk is offline
