Tack weld rear axle shaft, retainer plate stud, now or wait?
When installing a new pair of chromoly rear axle shafts in my D44, I over-torqued one of the studs of the driver rear retainer plate.
It is plenty tight to drive as is.
However, in the future, when I need to remove the nut, I'm going to have to tack weld the stud to the plate from inside or cut the stud off from the nut side from the back.
I could reach in to stick weld it, or I could use my MIG with the wire spooled out far enough.
I am concerned about over-heating the seal and/or splattering in there while doing a tack weld. This leads me to want to wait until I have to pull the shaft.
I am also concerned about being on the trail, busting an axle, and not being able to pull and replace it until I return to somewhere I have access to a welder. This leads me to want to tack weld it now.
Up until now, I have only bent rear chromoly shafts and blown rear ring teeth. I'm thinking that it is less likely that I break a rear shaft on the trail. If I blow ring teeth, I'd pull my rear driveshaft and drive/winch/pull off the trail in front wheel drive. I could then find access to a stick welder to tack it so I could pull the shaft.
Certainly, I'm not the only one who has spun a retainer plate stud.
Who has an opinion other than "bacon" or to just carry some welding sticks and link batteries?
