Fuel cell in daily driver - JKowners.com : Jeep Wrangler JK Forum
post #1 of 44 Old 02-13-2012, 09:26 PM Thread Starter
terrahawk's Avatar
OK vatos, I keep kicking crap around and may be 4 linking instead of the 3 link stretch. Question is, can a fuel cell work in a daily driver. Thinking of the Genright $600.00 unit run behind my b-pillar cage-work.
Serious responses please, it's newb territory for me.
terrahawk is offline
post #2 of 44 Old 02-13-2012, 09:39 PM
Topgun863's Avatar
Don't see why it wouldn't work. Sadly this is something I'll never be able to do due to California's Laws Be curious to see someone do it though! GL!
07 X 2dr- 6spd
Topgun863 is offline
post #3 of 44 Old 02-14-2012, 01:07 AM
I don't think I would want all the fule (evein in a fulecell) in the cab of the DD Jeep. And they have a lot of hoses coming out of them that I don't understadn. So I'll be watching this thread for the reply of the Experts
Sent by Monkey Flinging Poo
post #4 of 44 Old 02-14-2012, 05:13 AM
blownJK's Avatar
We do it all the time. Its no problem and it wont smell as long as you have everything sealed up and mounted properly.
Like us on
blownJK is offline
post #5 of 44 Old 02-14-2012, 05:39 AM
usmcdoc14's Avatar
Depending on your state's level of anal retention come inspection time is the only issue I see. Otherwise the fittings and hoses are pretty simple on a JK, I have no idea on the level sender though.
usmcdoc14 is offline
post #6 of 44 Old 02-14-2012, 08:22 AM
I've got the same Genright cell. You have to modify the pump yourself which they don't tell you.
The pump sits to high in the cell. I would order a tank from Carolina Truggies. Their tank has a recess so the pump sits on the bottom like its designed to. May cost a bit more but worth it.
Cell will be fine in a daily driver. Fill ups will just take a little longer.
jeff76 is offline
post #7 of 44 Old 02-14-2012, 08:42 AM
I run an RCI 2162 with GenRight ring and stock fuel pump assembly in my TJ daily driver with absolutely zero issues. As long as the seal between the ring and cell is good and you use good lines (I recommend Aeroquip), you'll have no fumes at all. The JK evaporative/emissions system is very similar to the late model TJ's and I can tell you that it's not at all difficult. Use a little common sense and you can have the thing plumbed, bolted in and running in a few hours. If you go this route, go with a cell that will allow your fuel pump to sit on the bottom.
Imped is offline
post #8 of 44 Old 02-14-2012, 10:04 AM Thread Starter
terrahawk's Avatar
Thanks for the help guys, I'd really like to ditch the trracbar if I can, it will make stretching this beyotch that much easier.
post #9 of 44 Old 02-14-2012, 01:40 PM
If u get rid off the tank you will have room for a single or double triangulated 4 link in the rear and won't need a Trackbar
jeff76 is offline
post #10 of 44 Old 02-14-2012, 02:17 PM
I think he knows that.......
Imped is offline
post #11 of 44 Old 02-14-2012, 04:46 PM
Obviously he didn't know that u fucktard. He said he would like to get rid of the Trackbar if he can. He wasn't sure if he could or not. By triangulating the Trackbar can be eliminated.
jeff76 is offline
post #12 of 44 Old 02-14-2012, 05:57 PM
It never ends...
LeftHandRubi's Avatar
TNT customs is doing one like this now: fuel cell in bac, moved to make room for suspension. Should be done in another month. (new suspension, armor, etc).
T-REX
Meet Rex Thread:
Adventures of Rex Thread:
LeftHandRubi is offline
post #13 of 44 Old 02-14-2012, 07:15 PM
cjcraig7's Avatar
Trading the track bar for a fuel tank ain't going to make anything easier.
I had a fuel cell in a daily driver before and I hated the smell in the enclosed cab. I am sure the fuel cell folks will come on and say otherwise though.
Loosing inside cargo in a 2-door is iffy too.
cjcraig7 is offline
post #14 of 44 Old 02-14-2012, 07:17 PM
cjcraig7's Avatar
You are kidding, right?
cjcraig7 is offline
post #15 of 44 Old 02-14-2012, 08:26 PM
Bad day?
Summit lines and fittings = fumes up the wazoo. Aeroquip lines and fittings = zero fumes. I can let the Jeep sit for a week fully enclosed and get in without a hint of fumes. True story.
Imped is offline
post #16 of 44 Old 02-14-2012, 08:34 PM
"True Story"
Jeepmods is offline
post #17 of 44 Old 02-14-2012, 08:47 PM
O2BDrty's Avatar
Give us some pictures please
I'm sure I'll think of something
O2BDrty is offline
post #18 of 44 Old 02-14-2012, 09:02 PM
I'd imagine you could run a tuffy security deck, or the Mopar version of the same thing, and hide everything back there on a 4 dr.
Sent from my iPhone 4 using Tapatalk
Semper Fi
highoctane is offline
post #19 of 44 Old 02-14-2012, 09:47 PM
andrelopez99's Avatar
Is there a diagram of some sort.
I dropped the fuel tank, have disconnected everything, wondering about the Evan canister if its reused, on my CT fuel cell you drop the sending unit reconnect the fuel line and connector but wondering what in guessing is the return line that run along the pass. frame..
andrelopez99 is offline
post #20 of 44 Old 02-14-2012, 11:37 PM Thread Starter
terrahawk's Avatar
I was just expressing that I was warming to the idea of losing the tracbar and do realize that can be done by tringulating. The three link / panhard route was how I had planned all this out, but my buddy has gotten in my ear about how the 4 link would ultimately be better knowing that it's something I'll end up doing eventually anyway. The fuel cell issue is my hurdle I need to get over to buy into the 4 link. Some say it would be no issues, a few others the opposite. GenRight makes a Comp tank that I think could be recessed in the rear and sealed off from the cabin, going to talk to those guys tomorrow and get their opinion.
post #21 of 44 Old 02-14-2012, 11:41 PM Thread Starter
terrahawk's Avatar
I can see how Jeff thought I was a little more lost than I actually am hahaha.
post #22 of 44 Old 02-15-2012, 12:11 AM
HA! This didn't seem to be a thread that would cause a fight! Looking forward to seeing some pics of an install.
post #23 of 44 Old 02-15-2012, 05:12 AM
blownJK's Avatar
For a quick example look at RK's Victim, Co4Lo's JK, and andrelopez99's JK. They have my fuel cell. Current pictures of the Victim won't have it cause they had to have a bladder to race but the all aluminum one is mine. Also click on the link at the bottom of my signature(page 15), that's the first JK to get a fuel cell before we had the fuel system figured out. If you need some more let me know.
Like us on
blownJK is offline
post #24 of 44 Old 02-15-2012, 05:16 AM
Do you ever plan to stretch the rear? If so make sure that Genright comp tank won't be in the way.
You can get any shape cell, have a Jk pump ring welded in and be done for alot less money. The tank just needs to be shallow enough so that the factory pump sits on the bottom of tank.
jeff76 is offline
post #25 of 44 Old 02-15-2012, 05:23 AM
blownJK's Avatar
http://www.carolinatruggies.com/inde...t_detail&p=196
Here's the link to our tank. The picture shown is RK's Victim
Like us on
blownJK is offline
