Coilover questions: resi mounting/spring rates
Just got my 12" King coilovers for the front of my 2dr JK and had a few questions before I go to install sometime in the next couple weeks.
1.) This may be a stupid question, but do the shocks ship already filled with oil and charged with nitrogen? I know sometimes shipping companies are weird about stuff like that and some won't allow you to ship items that contain oil or whatever. Id hate to ruin a shock by assuming it was already filled.
2.) I need to get reservoir mounts for the front as I got the remote ones. Where and how did you guys mount them? Who's brackets did you get? Maybe post some pics??
3.) I know this may be a bit of a subjective question, but what spring rates should I be running? The came with 250/250 on both, and I know I could run dual rates if I wanted. I run a lot of varying terrain from high speed to some good rock crawling so I need them to be versatile. Plus my Jeep is my DD so a good ride on the road would be nice as well. I'm not against running them and seeing how they feel but I was curious what you guys recommended.
Thanks in advance!
Thanks in advance!
07 X 2dr- 6spd
Sponsored Links | |||
Advertisement |
You need to get the c/o on the jeep. See where it sits. You can change spring weights if it's not want you want. Using the 250/250 may be perfect, if not you will have a baseline to go from.
King will exchange springs with you if you keep them in like new shape. King does alot of jks do they should be fairly close on the springs.
search as there is already a very extensive thread on here on spring rates and what works for our JK's
You shock should be oil filled but may not be nitro charged. Charging is easy as finding a dirt bike or good race shop if you have no desire for your own kit. You are in CA, you should have no issues.
Mounting your res is as simple as "Where does this fit?"
simple hose clamps and something either purchased or made like this:
http://www.polyperformance.com/shop/...unt-p-783.html
Advertisement |
Using the search function, you will find lots of info on coilover rates that have been hashed out regularly over the years.
Any off-road shop can charge your shocks, but make sure they do it correctly; with the weight off the shocks and with the correct fitting so you don't lose the pressure when they disconnect. I have and use the poly kit to charge my own shocks.
If you can compress the shock easy and the piston does not come back out, it has no nitrogen in it. They usually ship them that way so you can cycle them. If you need a guy, I have a number. He's in Yucaipa.
LOL I should have known there would be an impending
for posting a question about what rate springs to run on coilovers. But I figured the rates might be more specific to each jeep/driving style and since I was already asking a few other questions i figured why not ask. I guess I'll go do some digging though the search feature and see what I can find
Yeah thats kind of what I was thinking of doing, just running the 250/250 springs and see where its at. Thats good to know that King will exchange springs. Thanks for the tip! I did get the Evo spec coilovers so they should be set up pretty well. I was just thinking maybe a dual rate would be better?? Not too sure though so I guess Ill have to do some research.
Kind of hard to compress the shocks right now as the coils and everything are tight on the shocks and they're not on the jeep now, so the shocks would extend anyways due to the springs. I just wanted to see if anyone had an idea as I didn't want to go to do the install and then drive the jeep and go "damn this rides like sh*t" then realize the shocks weren't charged or damage them or something lol. Better to cover my bases.
I wouldn't mind getting my own charging kit so I can fine tune them in the future but for now it would be nice to just get them charged and on the Jeep. I think we might have a nitrogen regulator at work that should work for this. I think it has the end on it that has the shrader valve remover so it removes the valve when you charge the nitrogen. Not sure if there is a specific type of regulator for shocks??
Hmm hose clamps might be a good idea. Just not sure if I'm going to have enough hose on the resi's. I like the Poly bracket. That might be the way to go. Thanks for the input guys
Originally Posted by jeff76
View Post
Originally Posted by usmcdoc14
View Post
Originally Posted by desert dog
View Post
Originally Posted by xmikedentx
View Post
07 X 2dr- 6spd
The only way to figure out the correct springs is by using the jeep, then changing springs to fine tune for what you're looking for.
Different springs rates will raise or lower your ride height depending on a heavier/lighter spring. Everbody has different bumpers, gear, armor, spares, etc.
How much uptravel are you trying to acheive?
View Post
Basically, I'm looking to be setting at about 3" of lift. I have PSC flat fenders and will be going to 37's hopefully in the next month or so if all goes as planned, so I should be able to get a decent amount of up travel without rubbing. I just have the front coilovers at this point, the rear I'll be running the King adjustable remote resi's. As far as driving style, I DD my Jeep and hit everything from a lot of off camber stuff and big rocks to hauling ass down washes and stuff, so I'm thinking maybe the 250/250's are a bit light? Should be good for flex in rock crawling though.
Anyone know what you have to do to switch out springs with King? I still DD my Jeep so its kind of hard to have it down more than a couple days if I have to send springs in and wait for them to ship the new ones back.
07 X 2dr- 6spd
Alright well after looking through some of the coilover threads I still haven't really found the answer I'm looking for. It's possible I may have just not found the right thread but I've searched for an hour so maybe someone can help me out. This is the best thread I've found: https://www.jkowners.com/forum/showth...r+spring+rates
I still am curious if I should run a stiffer rate maybe like a 250/350 in the front for some of the faster driving I do on occasion. I suppose I could contact King or another company that deals with coilovers a lot, but I'd like to hear from you guys as well. As I said, I'm not afraid to try the 250/250 rate and see where its at but since I don't have much experience with coilovers in Jeeps I don't really have anything to compare the ride to..basically I wouldn't know if it was soft or stiff unless the ride was one extreme or another. Maybe you guys have a recommendation of someone who can help me dial them in once I get them installed?? Thanks guys.
07 X 2dr- 6spd
Alot of guys run 250/300 in front, also starts changing with the more weight you add to the front, ie bumper, winch. I'm running 14" coilovers on the tribe 4x4 mounts
18 BRAVO
panama
kuwait
somalia
bosnia
cuba
now just kicking it as a civilian
I served so your lazy ass didnt have to
Originally Posted by THECHAD
View Post
07 X 2dr- 6spd
My coilover spring rate is 350/250. Flexes great and has a nice road ride.
Originally Posted by TEXASKEV
View Post
07 X 2dr- 6spd
All you have to do is unscrew the upper collar and slide the retainer out and pull the coils off to see if you can compress the shock. Takes 3 minutes. As far as changing the coils out, just call ahead and bum a ride down to their shop. Only an hour away from you.
View Post
07 X 2dr- 6spd
King will do testing with you on the shocks by appointment. Not sure how much it costs but might be worth it to have them right there helping you tune them in.
http://www.kingshocks.com/support/service/#tabs
Advertisement |
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Posting Rules | |
