Question on ABS lines under flex - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 02-12-2012, 06:23 PM Thread Starter
cru9's Avatar
What are ya'll doing about your ABS lines when flexing? Is there away to extend them?
cru9 is offline
post #2 of 8 Old 02-13-2012, 09:13 AM
pluke the 2's Avatar
nothing i do about them but they are [email protected]#*ing tight.
Cali Crew
My Youtube Channel:
pluke the 2 is offline
post #3 of 8 Old 02-13-2012, 09:23 AM
jloman77's Avatar
they can be rerouted to gain some length out of them. I rerouted mine and they are fine for my RK 2.5" lift and extended brake lines.
jloman77 is offline
post #4 of 8 Old 02-13-2012, 03:13 PM
coilrod's Avatar
Mine (2.5" lift) are also rerouted, but very tight under full droop. I am looking into crown extended lines, also local hydraulic shops are reportedly able to fab up longer stainless hose types.
coilrod is offline
post #5 of 8 Old 02-13-2012, 06:07 PM
If you pull the slack on the rubber grommets that hold the front ones in you can gain a couple inches. On the rear, I've soldered extra wire and have them routed and ziptied directly to the extended brake lines. All good.
2008 JK X 2DR NSG370
Time to build the TONS!
Long Island Off Road Club
NOVA4x4
Suffolk JK is offline
post #6 of 8 Old 02-13-2012, 06:29 PM Thread Starter
cru9's Avatar
Good idea on the extensions
cru9 is offline
post #7 of 8 Old 02-13-2012, 08:05 PM
usmcdoc14's Avatar
cut, add 6", solder, adhesive lined heat shrink, done.
usmcdoc14 is offline
post #8 of 8 Old 02-17-2012, 12:13 AM
cloud is offline
