RK 3.5 sway bar link hitting spring - JKowners.com : Jeep Wrangler JK Forum
post #1 of 63 Old 02-12-2012, 01:48 PM Thread Starter
cajun01's Avatar
Hey guys,
I installed the RK 3.5 flex system. The RK sway bar links could not be removed from the passenger side lower without hitting the lower front spring perch and the RK link is hitting my driver side front spring. So I installed my JKS sway bar links back on.
Now I can remove the links. My issue with the driver side sway bar link is still present as there is maybe 1/32 " from contacting the spring. It will contact the spring under normal driving conditions. I can not for the life of me resolve this issue.
Any help or input is greatly appreciated.
Rock Krawler 3.5
8 RK flex arms
Front and Rear RK Trac bars
Tera flex 2.5 bump stops
Procomp 17x9
315/70/17 Duratracs
Bilstein 5100s
XRC 10 winch
Homemade front and rear bumpers
jks disconnects
cajun01 is offline
post #2 of 63 Old 02-12-2012, 02:02 PM
fourplyn's Avatar
do you have flex arms installed? if so, your front axle is possibly pushed forward just a smudge.
I switched to Curries Anti Rock sway bar ...and it won't hit now.
Past jeep:
- 40" Pro Comp X-Terrain
fourplyn is offline
post #3 of 63 Old 02-12-2012, 02:07 PM Thread Starter
cajun01's Avatar
Yes, I have all 8 arms installed. I have checked the lengths about 6 times. I am also running aftermarket drive shafts front and rear. I shortened the lowers about an 1/8 to help the front pinion. I just don't want to pull this bitch apart again
Rock Krawler 3.5
8 RK flex arms
Procomp 17x9
315/70/17 Duratracs
Bilstein 5100s
XRC 10 winch
jks disconnects
cajun01 is offline
post #4 of 63 Old 02-12-2012, 02:49 PM
Grim jeeper's Avatar
Mine was the same I switched springs and it gave me about 1/2in of clearance I'm thinking about sliding the axle back a 1/2 inch also
88 Ford kingpin D60 front axle(35 spline inners and outter Eaton E locker 5.38 gears)
14 bolt rear axle
37/13.50 Mud Grapplers
Thx JKO for the build help
Grim jeeper is offline
post #5 of 63 Old 02-12-2012, 02:59 PM Thread Starter
cajun01's Avatar
Well crap, looks like I will be pulling the front end apart again. I'm not a happy camper
Rock Krawler 3.5
8 RK flex arms
Procomp 17x9
315/70/17 Duratracs
Bilstein 5100s
XRC 10 winch
jks disconnects
cajun01 is offline
post #6 of 63 Old 02-12-2012, 03:18 PM
StepsRide's Avatar
Did you get it aligned yet. This made a difference for me. I have and inch of clearance which is all you need.
Obama's EPA just shut down your favorite ORV trail.
StepsRide is offline
post #7 of 63 Old 02-12-2012, 03:42 PM Thread Starter
cajun01's Avatar
I have centered the front/rear axles and set the pinion angle. I will probably shorten the front control arms (upper n lower) sometime this week. I am just really tired of working on this Jeep right now. When I get frustrated I start breaking sh!t
Rock Krawler 3.5
8 RK flex arms
Procomp 17x9
315/70/17 Duratracs
Bilstein 5100s
XRC 10 winch
jks disconnects
cajun01 is offline
post #8 of 63 Old 02-12-2012, 03:46 PM
pluke the 2's Avatar
lol. id call rk on monday and send them the picture.
Cali Crew
My Youtube Channel:
pluke the 2 is offline
post #9 of 63 Old 02-12-2012, 04:49 PM
My drivers side came out very close, maybe a 1/4" clearance. I was unsure about it till I flexed it and nothing hit. The passenger side has over 1/2" clearance.
Like others have said, shorten your arms a smidge maybe?
DrHolliday is offline
post #10 of 63 Old 02-13-2012, 02:36 PM
That is definitely not right, but the wierd thing is, from what little we are seeing from your picture, the coil appears to be centered on the stem pretty well...
Give us a shout...
RK
post #11 of 63 Old 02-13-2012, 06:14 PM
gfe jeep's Avatar
this has happened to me. the front right has about a 1/4" and the driver side touches. the rear track bar contacts the passenger side spring.......
i will put a currie on the front. have not been able to correct the rear issue...
2008 Jeep Wrangler Sahara 2 Door
Treks Rear Shock Relocators
MOPAR Extended Rubicon Rock Rails
Expedition One Front Skid
Kilby Muffler Skid
Rockhard 4x4 Belly Skid & Evap Skid
Olympic Receiver Hitch Front Bumper
Tuffy Stereo Lock
Cobra 75 CB
Cooltech CB Antenna & Mount
Kilby Switch Panel
1500 Watt Power Inverter
Glow Lights Footwell Lights
OK Offroad Fuse Box
Front & Rear ARB Lockers
5.13 Gears
gfe jeep is offline
post #12 of 63 Old 02-13-2012, 07:32 PM Thread Starter
cajun01's Avatar
Looks like I have the uppers 1/8" longer than the recommended length. I'll just run it without the sway bar hooked up. I should have time Friday a.m. to pull all 4 arms again.
Sent from my SAMSUNG-SGH-I997 using Tapatalk
Rock Krawler 3.5
8 RK flex arms
Procomp 17x9
315/70/17 Duratracs
Bilstein 5100s
XRC 10 winch
jks disconnects
cajun01 is offline
post #13 of 63 Old 02-13-2012, 07:40 PM
smalcomson's Avatar
Sway Bar
Originally Posted by cajun01 View Post
Hey guys,
Had the same problem...took it to 4wheel Parts and they couldn't figure it out. Now running Rubicon Exp and Currie Anti Rock in the front and all is good.
sm
smalcomson is offline
post #14 of 63 Old 02-13-2012, 07:53 PM
smalcomson's Avatar
Note: Nothing wrong with RK I just couldn't get them to work with my set-up. Hopefully you'll get it worked out.
Cheers
sm
post #15 of 63 Old 02-14-2012, 07:06 AM
To be honest with you, it could be the sway bar links you are running. I think our links are much longer and put the sway bar up and out of the way further.... We are not sure, but it is food for thought!
RK
post #16 of 63 Old 02-14-2012, 07:53 AM
ShortBus's Avatar
Wouldn't the coil spring wedges help alleviate this issue? They took care of my driver rear spring rubbing the lower track bar bolt.
ShortBus is offline
post #17 of 63 Old 02-14-2012, 08:17 AM
e-jeep's Avatar
Feedback: 12 reviews
Did you relocate the bar? The instructions with my RK said to move the bar forward about an inch. Came with the screws to do it.
My Build Thread ~
NE Trail Ride Thread ~
Adrenaline Offroad
e-jeep is offline
post #18 of 63 Old 02-14-2012, 08:25 AM
ShortBus's Avatar
If it's a Rubicon, I think that may be a little harder to do.
ShortBus is offline
post #19 of 63 Old 02-14-2012, 09:24 AM
e-jeep's Avatar
Good point.
Hit up RK on PM. They answered all my questions fast, quick and in a hurry.
My Build Thread ~
Adrenaline Offroad
e-jeep is offline
post #20 of 63 Old 02-14-2012, 09:35 AM Thread Starter
cajun01's Avatar
This is the front sway bar.
RK; Your links are longer, but this will have me more than the +/- 5 degrees from level.
Because I have the uppers 1/8 longer than is recommended, this will effect the sway bar contact to a larger degree than an 1/8. So for the most part, when I shorten the upper arms to the correct length supplied by RK it should alleviate the issue
Rock Krawler 3.5
8 RK flex arms
Procomp 17x9
315/70/17 Duratracs
Bilstein 5100s
XRC 10 winch
jks disconnects
cajun01 is offline
post #21 of 63 Old 02-14-2012, 02:36 PM
+/- 5 degrees from level won't hurt you. It is a sway bar and it really only cares about it's relative position side to side within reason!
Check out some of the KOH rigs and how jacked their sway bars are! Hope that helps.
RK
post #22 of 63 Old 02-14-2012, 06:21 PM
I had the issue in the rear as well. I loosened the jam nuts on both sides and rotated the track bar more to the rear. No problem after that.
post #23 of 63 Old 02-14-2012, 06:37 PM
owtdorz's Avatar
You'll have no problem using the RK links. Mine fit perfect and have never hit the spring.
'09 4dr Rubi Detonator Yellow
3.5 Mid arm Rock Krawler
Finally 5.13s
owtdorz is offline
post #24 of 63 Old 02-14-2012, 09:35 PM
Mine clears by 1/2 inch - no prob.
post #25 of 63 Old 02-15-2012, 06:48 AM
ShortBus's Avatar
From the picture, it didn't look like the JKS discos were making contact. Looked like the swaybar itself was what would make contact.
I'd still suggest getting a set of RK's coil spring correction wedges. Cheap fix and very easy install.
ShortBus is offline
