Front end specs - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 02-10-2012, 04:03 PM Thread Starter
Joneszj's Avatar
Front end specs
I'm installing the rock krawler tie rod, a new drag link flip, high steer, and new balljoints.
What should I be aiming for with my toe in?
Also, I'm going to take the heep in for an alignment...what do i need to know for setting the caster?
Any other specs front-end-wise that I need to know?
1972 Commando on Tons & 40s
Joneszj is offline
post #2 of 3 Old 02-10-2012, 04:13 PM
ronjenx's Avatar
Are you lifted?
Do you have adjustable control arms?
Do you have aftermarket drive shafts?
The alignment shop will know the stock specs.
Here they are for your reading enjoyment:
Front Axle
CASTER + 4.2 0.5 (+3.7 to +4.7)
MAX LT/RT DIFFERENCE 0.65
CAMBER − 0.25 0.37 (-0.62 to +0.12)
MAX LT/RT DIFFERENCE 0.5
TOTAL TOE-IN + 0.20 (0.10 each front wheel) 0.03
MAX LT/RT DIFFERENCE 0.04
Rear Axle
Rear Camber: 0 to -0.50
Rear Total Toe In: 0 to 0.5
Rear Thrust Angle: 0 0.25
ronjenx is offline
post #3 of 3 Old 02-10-2012, 10:14 PM Thread Starter
Joneszj's Avatar
yes to all of the above.
4" of lift, 35s
full set of adjustable control arms
tom woods driveshafts
I had heard that you want negative toe in running the larger tires. do i fo with the stock specs above or something different?
Thanks for the info above.
Joneszj is offline
