37's, automatic, and 4.10's - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 02-09-2012, 07:35 PM Thread Starter
I'll be installing 5.38's within the next month but my tires wheels and lift are here and ready to go on and I cant wait any longer! I'm assuming this thing will be drive able just sluggish with the 4.10's? Just turn the OD off on the interstate?
Rescue green 07 2-door on 35's
viperbluelx is offline
post #2 of 12 Old 02-09-2012, 07:39 PM
coilrod's Avatar
Your shift points and speedo will be off if you don't have a programmer, but otherwise you will be fine. I found the od off button was always good before 5.38's.
coilrod is offline
post #3 of 12 Old 02-09-2012, 07:40 PM
block's Avatar
yeah you will be fine .. no problem. once you get the 5:38s you will love them even more just hit that overdrive button every time you get in the jeep
block is offline
post #4 of 12 Old 02-09-2012, 08:08 PM
Ran that way for about 9 months till I got my regear. You'll downshift on the hwy more since it can't hold OD on small hills but its not a prob. And you can fix that with a programmer. Aev has a low cost one that is only about 140.00.
post #5 of 12 Old 02-10-2012, 09:42 AM
pluke the 2's Avatar
our 4 door with heaviest 37's money can buy and with 538s is still a slug. and it has a ripp supercharger.
Cali Crew
My Youtube Channel:
pluke the 2 is offline
post #6 of 12 Old 02-10-2012, 10:50 AM
jeep2007's Avatar
Yep. Get the Procal to calibrate for speedo and shift points. Around town is fine, but interstate OD off. I am running 4:10 and will for a bit longer.
jeep2007 is offline
post #7 of 12 Old 02-10-2012, 10:47 PM
manuel's Avatar
You be fine with out the overdrive but the biggest change well be gas mileage if it sucks with small tires its gonna suck even more.
manuel is offline
post #8 of 12 Old 02-17-2012, 12:42 AM
cloud is offline
post #9 of 12 Old 02-17-2012, 05:33 AM
rdlynch2's Avatar
You guys and your automatics. Tsssshh. You think your SOO cool with your OD. Hahhha. JK.
2008 Black 2Dr 6spd D30/44
rdlynch2 is offline
post #10 of 12 Old 02-19-2012, 09:02 AM
SoK66's Avatar
The 4.10s will give you a real incentive to re-gear sooner rather than later.
SoK66 is offline
post #11 of 12 Old 02-19-2012, 09:09 AM
Your six speed has one overdrive gears. Anything less than 1:1 is an overdrive gear...The auto's have a cog gear for overdrive however, 0.64:1 4th compared to 0.84:1 6th.
post #12 of 12 Old 02-19-2012, 09:37 AM
Originally Posted by ronjenx View Post
Why do you think the 6 speed has two O/D gears?
What it the cog gear you speak of? Isn't it just a certain combination of planetary gears?
Bah, I meant to edit that as one overdrive gear. As far as "cog" it was a exaggeration of a steep gear. Really too steep of a gear split which is why kicking in and out of OD is such a big deal in the autos.
