Teraflex shock issues? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 21 Old 02-08-2012, 03:33 PM Thread Starter
osiris1741's Avatar
Theres been a teraflex 2.5 coil spring lift on my jku for about 15,000 miles. The steering stabilizer was leaking very bad, and now I found out that I have just blown out a shock. It's mainly a daily driver and seen very little trail use as of yet.
Has anybody else had these issues? I'm debating if I want to replace it with the same or go with a different brand.
Thanks!
osiris1741 is offline
post #2 of 21 Old 02-08-2012, 03:40 PM
FireTrail741's Avatar
I had the same issue with a front shock. Call or email them, they replaced mine without question. Suspension wasn even 6 months old.
FireTrail741 is offline
post #3 of 21 Old 02-08-2012, 03:46 PM
ESP123's Avatar
No problems with mine and I have the same lift as you. I'm running the stock SS because I've read many post about theirs doing this. How do you tell if your shock is busted or toast? My lift has about 4,000 miles on it.
ESP123 is offline
post #4 of 21 Old 02-08-2012, 03:57 PM Thread Starter
osiris1741's Avatar
I was getting death wobble. Jeff and Eric at Adrenaline put it on the lift and there was a LOT of play in it.
post #5 of 21 Old 02-08-2012, 04:36 PM
SoK66's Avatar
The TF ss that came with my lift leaked and was repaled under warranty. The second seemed to be OK. I replaced it with a Bilstein. I'm told the best one out there is the stocker post '10, the one with the outer sleeve. I had no issues with TF shocks but swapped them out for Billy 5100s.
SoK66 is offline
post #6 of 21 Old 02-08-2012, 04:44 PM
My front shock was spitting oil out of the seal an down the shock slightly. My stock SS works great. No need to change. Waste of money unless a PSC a needed.
post #7 of 21 Old 02-08-2012, 05:13 PM
My TF SS crapped out pretty quick too, They did replace it, but I did not put it back on my Jeep, instead I too got the Bilstein, and it is well worth it.
boboborino is offline
post #8 of 21 Old 02-08-2012, 08:38 PM
Gotlime?'s Avatar
I had a rear TF shock leak and they replaced it. I just paid $10 for shipping.
My SS leaked as well. I replaced it with a Monroe unit from a Ford F250. $35 from Vatozone.
08 Jeep Wrangler Unlimited Rubicon: lift, wheels/tires, bumpers, skids, sliders, winch, lights, cb. All the normal stuff, plus some.......
Build thread:
Gotlime? is offline
post #9 of 21 Old 02-08-2012, 09:12 PM
RODICON's Avatar
Talk to Teraflex!
2014 Rubicon on the build!
RODICON is offline
post #10 of 21 Old 02-09-2012, 03:19 AM
mrsig's Avatar
Over 30,000 on my TF 9550 Shocks and not one problem.
CEO of Black Sheep 4x4s
mrsig is offline
post #11 of 21 Old 02-09-2012, 07:41 AM Thread Starter
osiris1741's Avatar
Originally Posted by RODICON View Post
Talk to Teraflex!
I will eventually. I wanted to make sure it was even worth getting new Teraflex shocks or if I'd be better off in the long run going with something else
post #12 of 21 Old 02-09-2012, 07:55 AM
enigmaverse's Avatar
My TF 9550's were destroyed after 2 years (about 20K miles) When I replaced them, 3 were leaking, and one of those three had no positive charge whatsoever, pushed it in and it stayed in.
I only wheel a few times a year, but its not easy stuff, so I kind of expected it. I found after the first year the ride quality started to dissipate as well.
Joe -
enigmaverse is offline
post #13 of 21 Old 02-09-2012, 08:00 AM Thread Starter
osiris1741's Avatar
Thats what is making me think I should just fork out the cash for a different set of shocks.
post #14 of 21 Old 02-09-2012, 09:59 AM
Definitely talk with Tera, but make sure the stabilizer is set correctly so you are not bottoming or topping it out as well as their shocks. Set up is critical for that!
RK
post #15 of 21 Old 02-09-2012, 11:03 AM Thread Starter
osiris1741's Avatar
I just sent them a message.
Also, I just realized how that first post read. I am NOT the original purchaser of the lift. A good friend of mine had it and after he passed, I bought the JK from his widow. This thread was mainly to see if it'd be worth it to get new Teraflex shocks or if I'd be better off just going with something else.
post #16 of 21 Old 02-09-2012, 11:39 AM
ORWJK's Avatar
teraflex is pretty good about taking care of their customers....though
maybe a good time to upgrade to some bilsteins? imo, the 5100's are possibly the best all around off road shock out there.
1-800-341-7757 Ext. 123
Ask for Justin
ORWJK is offline
post #17 of 21 Old 02-09-2012, 03:18 PM
Glad I'm reading this.. I've had my TF lift on for a year and a half. Recently started thinking "man this is a rough ride" PM TF and sent a pic as they thought my bumpstops were bottoming out. Sure enough they were.. What caused this?? ALL 4 SHOCKS WERE BLOWN!!! after 15k miles. TF just sent me new shocks last night and I'll be putting them on. Although I would prefer to upgrade to Fox if TF is paying for it, I'll keep putting these on. Really disappointed so far with TF. So far on my lift I've had my rear Sway Bar links rust over "bad coat of paint they said" and now the shocks. they've replaced both, but still...
rdubb1031 is offline
post #18 of 21 Old 02-09-2012, 06:13 PM
Shocks do NOT lift/lower a rig.(less they are coil over/air lift)
So if you bumpstops are hitting they are 1. too large, or 2. the coils have sagged.
beedle4 is offline
post #19 of 21 Old 02-10-2012, 12:21 PM Thread Starter
osiris1741's Avatar
I was in contact with Joe over at Teraflex. Awesome guy and they're send me replacements. Huge on their customer service
post #20 of 21 Old 02-10-2012, 05:14 PM
TeraFlex's Avatar
Thanks!
Just a note a HD TeraFlex stabilizer will be coming out soon.
801-713-3314
TeraFlex is offline
post #21 of 21 Old 02-10-2012, 06:51 PM
HighTower's Avatar
So what would be different between the 2?
Sent from my imagination.
2010 JKU Sahara
Teraflex 2.5 Coil Lift w/ 9550 Shocks
Teraflex Quick Disconnects
Moto Metal 17" 950s
Nitto Trail Grapplers 35x12.5x17
Superchips Flashpaq
HighTower is offline
