What to cut..... - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 02-08-2012, 07:39 AM Thread Starter
JKO Dickhead
Asmmns's Avatar
What to cut.....
I will finally be doing my rear lower shock relocation this saturday and geting rid of those anchors that drag and get caught on everthing...
I will be doing it a buddy's shop with a plasma ... so i figured I might as well take advantage of that...
already figured I will cut of the stock steering stabalizer bracket while I am under thing....
andything else under there i should take the plasma cutter too in an attempt to clean up the belly and get rid of any lower hanging garbage ?
__________________
CURE SMA !
Asmmns is offline
post #2 of 6 Old 02-08-2012, 08:20 AM
jeeperjkj's Avatar
Cut off the control ARM mounts and bolt on some long ARM brackets!
jeeperjkj is offline
post #3 of 6 Old 02-08-2012, 08:25 AM Thread Starter
JKO Dickhead
Asmmns's Avatar
In due time my friend ....... in due time !
__________________
CURE SMA !
Asmmns is offline
post #4 of 6 Old 02-08-2012, 11:20 AM
Are you using upper shock mount relocation brackets also, poly performance makes them. Or you just running the lower mounts?
monkers is offline
post #5 of 6 Old 02-08-2012, 12:03 PM
paramaniac's Avatar
cut the pinch seam that sticks out into the rear wheel well while youre hacking on the jeep
paramaniac is offline
post #6 of 6 Old 02-10-2012, 12:11 PM Thread Starter
JKO Dickhead
Asmmns's Avatar
just going with the lowers for now....
the pinch seam was gone on the night I brought it home from the dealer.... the rear frame was about two weeks later for the BFH...
i love cutting stuff off... lol. thats why i am looking for more ideas !!
__________________
CURE SMA !
Asmmns is offline
