dana 44front upgrade - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 02-03-2012, 06:32 PM Thread Starter
van7559's Avatar
Looking to replace my bent 30, found a bare housing, what else am I gonna need to get this thing under my jeep and rolling? I know axle shafts and gears? What els am I missing> will the brakes on my 30 be a direct swap?
07' Unlimited X
PSC Bumpers F/R
8k Warn winch
2.5" RK Max Travel
35" MTR's
5:13 yukons
Sleeved/Gusseted front
Dynomax pre-axle exhaust
van7559 is offline
post #2 of 7 Old 02-03-2012, 06:57 PM
SoK66's Avatar
What kind of D44 housing is it? If it's from a JK you can swap over the outers intact (knuckles & brakes, etc.). You'll need a differential, axle shafts inner & outer and a ring & pinion. Get some Poly or Dynatrac ball joints, too.
SoK66 is offline
post #3 of 7 Old 02-03-2012, 07:51 PM
They use the same 32sp outer shafts, so you can re-use everything from the outer shafts outward. You will need new joints to connect the outers to the new 30sp inners, r&p, locker, seals, etc. If you don't want to buy the $1400 factory e-locker, look at a 35sp arb or 35sp ected, along with 35sp shafts.
GreenJK is offline
post #4 of 7 Old 02-03-2012, 08:48 PM Thread Starter
van7559's Avatar
jk housing
07' Unlimited X
PSC Bumpers F/R
8k Warn winch
2.5" RK Max Travel
35" MTR's
5:13 yukons
van7559 is offline
post #5 of 7 Old 02-03-2012, 08:49 PM Thread Starter
van7559's Avatar
Is that the only options as far as lockers? If so I probably need to pony up to the 35spline shafts huh
07' Unlimited X
PSC Bumpers F/R
8k Warn winch
2.5" RK Max Travel
35" MTR's
5:13 yukons
van7559 is offline
post #6 of 7 Old 02-03-2012, 08:55 PM
SCOUT37JK's Avatar
You could go big with the 35 spline ARB air locker and RCV shafts.
You will need gears R&P, bearings, shims, seals, gear oil... And while you're building it go ahead and truss it and support the inner C's too.
homebuilt JK - blood, sweat, lemonade. renamed LOOSE NUTS
SCOUT37JK is offline
post #7 of 7 Old 02-03-2012, 11:45 PM
Berserker's Avatar
I'm doing the same thing.
Since you are starting from scratch just go all out:
CV's
ARB
Synergy outer shell kit
Reid knuckles
master overhaul kit
Damn the cannons, full speed ahead! |
Berserker is offline
