Rubi Electric Disco finally quit... good options for replacement? - JKowners.com : Jeep Wrangler JK Forum
View Poll Results: Swaybar system to replace Rubi Smartbar
Stock non-Rubi w/ quick discos 3 20.00%
Teraflex S/T single rate 0 0%
Antirock 3 20.00%
other options non listed (please list) 3 20.00%
bacon 6 40.00%
Voters: 15. You may not vote on this poll
post #1 of 9 Old 02-03-2012, 07:10 AM Thread Starter
mbjeepxj's Avatar
My electonic swaybar disconnect finally took a dump... still won't reconnect after my last wheelin' trip... it's been like 3 weeks... i've tried unhooking the battery, unhooking the harness, flexing, countless tries in and out of 4WD and trying the button random times... i can hear the motor actuate, but it just won't reconnect and the damn dash light keeps flashing...
so, if I were to replace the swaybar... what are the best options?
stock (non-rubicon) replacement with quick disco's? (cheapest)
Teraflex S/T single rate?
Antirock? (most expensive)
any other options out there that I'm missing?
☀lllllll☀ 2014 Cherokee Trailhawk
☀lllllll☀ 2009 Unlimited X
☀lllllll☀ 1985 CJ-7
mbjeepxj is offline
post #2 of 9 Old 02-03-2012, 07:16 AM
bigb's Avatar
Off road evolution has a device that is installed onto the elec disco and allows you to manually disconnect with a turn of a knob. And it's fairly inexpensive.
bigb is offline
post #3 of 9 Old 02-03-2012, 07:19 AM
bigb's Avatar
Here's a link. I know this is what I'll be doing when mine craps out.
http://www.offroadevolution.com/stor...d=EVO-NOLIMITS
bigb is offline
post #4 of 9 Old 02-03-2012, 07:21 AM Thread Starter
mbjeepxj's Avatar
and we have a winner!!! i've not seen that before!!!
perfect...
* please vote bacon from now on as i've found my solution after the first reply .
☀lllllll☀ 1985 CJ-7
mbjeepxj is offline
post #5 of 9 Old 02-03-2012, 07:22 AM
10jk's Avatar
/\ X 2 Ya beat me to it,,,,, that's what I'm gonna do when it shits the bed
2010 JKUR, 4" Pro C., 3/4" f Daystar spacer, 5.38's, EVO sleeve/gusset/custom trussed, Rear Ten Factory axle shafts, 1.5" wheel spacers, Pro C. 17 x 9 wheels, 38 x 14.50 x 17 MTR's, SuperChip FP, no fenders, B&M Tranny cooler, Magnaflow, Fr./ Rr. frame hacked off, HD Balls
29,000 miles as of 12/13/14
10jk is offline
post #6 of 9 Old 02-04-2012, 10:02 AM
I have been told that if water gets in the unit the pin will corrode a bit and will not engage. You simply need to take it apart, clean the pin, and apply some lube to it. Might be worth a try.
post #7 of 9 Old 02-05-2012, 02:56 AM
mrsig's Avatar
EVO is what I am using now. Cheap and easy.
CEO of Black Sheep 4x4s
mrsig is offline
post #8 of 9 Old 02-05-2012, 07:03 AM
mhaines's Avatar
Once my wiring harness corroded out, I replaced the motor with the evo and like it
08 X Unlimited.Jeep Green. 4.5" AEV Nth Degree. Rubi rock sliders, LineX'd nerf bars. MotoMetal 909's. 35x12.5x17 Nitto. Billet grille. Daystar Dash, Hood Wranglers and tire bumpstops. Rugged Ridge liners,front XHD bumper. Recon 10.5, neoprene covers. sPOD. KC Daylighters windshield lights. Pocket flares by TAG. JKS front and rear adjustable trac bars. Expedition One Trail Series rear bumper, Rock Krawler arms, Evo sleeves, RCVs, 4.88s, ARBs
mhaines is offline
post #9 of 9 Old 02-05-2012, 08:26 AM
TJDukit's Avatar
How is the steering? I couple weeks ago I bent the shit out of my steering stabilizer and mine would not reconnect. Once I pulled the stabilizer it worked just fine. I figure the computer couldn't tell if my wheels were straight or not.
'09 JKUR. Metal Cloak overlines, TF 3" LA, 35" Nitto Trail Grapplers, Home built winch bumper, custom built sliders, RK Drag Link and HD Pro Tie rod, Adams front shaft, TF Big Brakes, Speed Bumps, Warn M8000
I.Y.A.A.Y.A.S.
TJDukit is offline
