Axle Flange Run Out - How Much is too Much? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 02-01-2012, 07:50 PM Thread Starter
JPK
My Jeep took a shot to the passenger side rear tire. F--ked her car up, but no body damage to my Jeep. However, the rear axle flange now has ~.005" (could be .05" ?) run out. Do I need to replace the shaft?
The wobble is visible.
Thanks,
JPK
JPK is offline
post #2 of 9 Old 02-01-2012, 09:29 PM
thebigtman's Avatar
If you can visibly see the wobble, yes. Put the tire/wheel back on and obviously it'll be magnified. If the new shaft doesn't cure the wobble, time to check the housing. Usually if the housing is bent, it'll dog track.
V8 YJ/TJ hybrid on tons
thebigtman is offline
post #3 of 9 Old 02-01-2012, 10:23 PM
If I understand correctly, you got hit? Then I'd do an insurance claim and get it replaced.
post #4 of 9 Old 02-02-2012, 05:30 AM
blownJK's Avatar
^This
Like us on
blownJK is offline
post #5 of 9 Old 02-02-2012, 06:32 AM Thread Starter
JPK
Thanks for you replies. I should have phrased my question better. The shaft will be replaced, and yes the insurance company is involved. The real question is how critical is the bent axle flange with that much run out and how soon do I need to change the shaft before either excessively wearing the tire, risk breaking the shaft, ect, ect.
Can I wait a week, or a month? My shcedule sucks right now.
JPK
JPK is offline
post #6 of 9 Old 02-02-2012, 09:02 PM Thread Starter
JPK
Still looking for advice...
JPK is offline
post #7 of 9 Old 02-03-2012, 06:37 AM
thebigtman's Avatar
Without seeing it in person I would do this:
Put the rear on jack stands with the tires still on the Jeep.
Have someone put it in drive while you observe the wobble.
How bad does it look? I don't have a hard and fast figure to give you to judge what's good/bad. I know people who have driven on slightly bent shafts for months. When they did change the shafts new bearings/seals were installed on the outers.
Have you pulled the shaft to see if it's cracked or visibly bent? A visible bend strays into the "too bad to drive it" in my opinion.
Pulling the shaft is pretty easy. Two bolts for the caliper (18mm), then 4 nuts for the flange (18mm), and then an 8mm bolt for the wheel speed sensor (just push it back, not out).
Hopefully that helps. If you got hit on the side be sure to check the control arm mounts to ensure they are not bent.
Good luck,
Tim
post #8 of 9 Old 02-03-2012, 06:49 AM
10jk's Avatar
I have bent a few axle shafts/flanges from wheelin. What ya need to do as mentioned, is jack up the rear axle. Block the front tires so it don't roll fwd, then I put it in N so the drive shaft will spin free. Then spin the rear tires and look at the rear brake caliper. If they run true, I leave it alone. If you can see the caliper wobble then your bent. It will eventually eat out a rear wheel bearing, yes I did that also, it will make a grinding howling noise that radiates throughout the jeep.
If you can see it, get it replaced under insurance or it might be time for Chromo axle shaft. Also keep in mind the housing might have gotten bent also. Time for insurance and have the dealership check it out.
2010 JKUR, 4" Pro C., 3/4" f Daystar spacer, 5.38's, EVO sleeve/gusset/custom trussed, Rear Ten Factory axle shafts, 1.5" wheel spacers, Pro C. 17 x 9 wheels, 38 x 14.50 x 17 MTR's, SuperChip FP, no fenders, B&M Tranny cooler, Magnaflow, Fr./ Rr. frame hacked off, HD Balls
29,000 miles as of 12/13/14
10jk is offline
post #9 of 9 Old 02-03-2012, 06:51 AM
JPK
I'd personally take the check, order the parts and get to it when you had time. The bent axle will promote uneven pad wear as well on that axle.
