2012 Rubicon with RK lift - JKowners.com : Jeep Wrangler JK Forum
post #1 of 14 Old 01-31-2012, 01:20 PM Thread Starter
Has a RK 2.5" max travel lift with blisteins and a 1.25" rough country body lift.37/12.50/17 cooper stt 17x9 addict wheels. Auto 4:10 gears. The RK lift is amazing
Some flexing pictures before i put the flares on
All cleaned up
Drove to florida put my custom top on.
kgw350 is offline
post #2 of 14 Old 01-31-2012, 01:50 PM
MSUJeep's Avatar
Very nice
"Sweet ain't as sweet without the sour"
MSUJeep is offline
post #3 of 14 Old 01-31-2012, 01:56 PM
Heat'n and a beat'n...
STUPIDFACE's Avatar
Looks good. If you kept what you cut off the front flares, you can make a closure to cover the gap between the front inner finder liner and the sheet metal.
corey d
2008 JEEP...
STUPIDFACE is offline
post #4 of 14 Old 01-31-2012, 03:25 PM
T-Giv's Avatar
Did you do new driveshafts with the RK kit and the body lift? I am about to do the same type of setup and am unsure if the stockers will be okay for a while. Looks awesome.
T-Giv is offline
post #5 of 14 Old 01-31-2012, 04:06 PM
glomb23's Avatar
Rig came out great man, nice work!
Your stock driveshafts will be fine to run for a while. If you're a 2door auto you may want to look into shafts though.
Greg
glomb23 is offline
post #6 of 14 Old 01-31-2012, 04:11 PM
Very nice looking rig. Great choice of mods!
4x4x4 is offline
post #7 of 14 Old 01-31-2012, 04:24 PM
T-Giv's Avatar
I'm 2 door 6 speed. What does a while transfer to exactly? 10k miles? 30k? I've heard both numbers. Lol Thanks for the info.
T-Giv is offline
post #8 of 14 Old 01-31-2012, 05:06 PM Thread Starter
Thanks for the comments.
And yes i changed the drive shaft i had no issue with it rubbing i put the teraflex exhaust spacers and shimmed the skid down a little bit was fine the issue with the 2012s the motor is tilted back so much the boot gets pinched where the drive shaft comes out of the transfer case. I ordered one before i had a problem. I learned from my 09 with a 2.5 lift jku auto ripped the front boot on the tranny.
kgw350 is offline
post #9 of 14 Old 01-31-2012, 05:30 PM
Rig looks great!
How do you like the 4.10 gears and the 37s.
Nattys44 is offline
post #10 of 14 Old 01-31-2012, 05:58 PM Thread Starter
The 4:10s are not bad with the new motor and 5spd tranny. Im going 4:88s this summer.
kgw350 is offline
post #11 of 14 Old 01-31-2012, 06:08 PM
Sweet, love the RK gear
post #12 of 14 Old 01-31-2012, 06:13 PM
RotorHead's Avatar
Looks great.
RotorHead is offline
post #13 of 14 Old 01-31-2012, 06:15 PM
Nice flex! Keep in mind even with the rubi sway bar disco, we recommend disconecting the sway bar links at the axle because you can have it flip your sway bar right around and you will bend the link pin.
RK
post #14 of 14 Old 01-31-2012, 06:41 PM Thread Starter
Thanks for the heads up. I added the disco links later.
You guys make a kick ass suspension. Can't wait till i upgrade to the 3 link front and rear long arm.
kgw350 is offline
