Driveshaft angles ? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 01-31-2012, 01:02 PM Thread Starter
cajun01's Avatar
Driveshaft angles ?
I have a stupid question. I will be installing my double cardigan drive shafts front and rear. My pinion angle should be at zero in front and rear at the differentials correct. By zero I mean taking into account the pinion angle and slope of the drive shaft.
Rock Krawler 3.5
8 RK flex arms
Front and Rear RK Trac bars
Tera flex 2.5 bump stops
Procomp 17x9
315/70/17 Duratracs
Bilstein 5100s
XRC 10 winch
Homemade front and rear bumpers
jks disconnects
cajun01 is offline
post #2 of 12 Old 01-31-2012, 01:44 PM
The rear pinion should be pointed up at the tcase output, in-line with the driveshaft. Up front, you have to tilt the pinion down a bit so you have enough caster to make it driveable. There is no correct angle that will work for everyone, but I would go for better driveline angles and low caster (which will give a bit of flighty handling) over more caster (better handling) and vibes. You may need to adjust it a few times to see what works for you.
GreenJK is offline
post #3 of 12 Old 01-31-2012, 01:49 PM
bdeanjr86's Avatar
Sounds like the same advice WayOfLife was trying to give you?!
bdeanjr86 is offline
post #4 of 12 Old 01-31-2012, 01:50 PM
Wow really? OP can you have a Mod move this over to Chit Chat? Please there are a few things I would like to respond too but this is in tech.
post #5 of 12 Old 01-31-2012, 02:11 PM Thread Starter
cajun01's Avatar
Greenjk, Thanks thats what I was thinking.
bdean, I couldn't quite understand what he was trying to tell me and it was starting to feel like a pissing contest.
Misguided, First thanks for your service, truly. Second let me know how to move this thread and I'll make it happen for you
Rock Krawler 3.5
8 RK flex arms
Procomp 17x9
315/70/17 Duratracs
Bilstein 5100s
XRC 10 winch
jks disconnects
cajun01 is offline
post #6 of 12 Old 01-31-2012, 02:18 PM
SoK66's Avatar
Your rear angle should be about 1 - 2 degrees less at the pinion than the shaft. This allows for torque influence on the differential during acceleration. That is, the pinion nose will lift a it under acceleration, so you compensate at rest 1 to 2 degrees.
In front there is a 6 degree offset between the pinion and caster angles. SO, if you have 4 degrees caster, you have two degrees pinion angle, 3 caster = 3 pinion, etc. It's ok up to about 3" lift, after which it's an utter fools errand trying to get it sorted. Requires either a compensated housing like the Dynatrac PR44 or manual hubs.
SoK66 is offline
post #7 of 12 Old 01-31-2012, 02:18 PM
bdeanjr86's Avatar
Roger that, I can see where you would've gotten that from reading his posts!
post #8 of 12 Old 01-31-2012, 02:27 PM
V8 dreams
jvandy50's Avatar
So does everybody over 4in lift with aftermarket shafts just have flighty steering?
Vandy
2010 Silver JKU
jvandy50 is offline
post #9 of 12 Old 01-31-2012, 02:34 PM Thread Starter
cajun01's Avatar
Good info.
I have read that the rear pinion will rotate up 1 degree under load. Also the front pinion will rotate down under load. I was a little confused because some people say to set it at zero.
I will be running the RK 3.5. My plan is to set the rear pinion at or very near 0 degrees.
Then set the front pinion at 3 degrees that should give me 3 degrees camber, then adjust it by putting miles on it and feeling for vibes.
Rock Krawler 3.5
8 RK flex arms
Procomp 17x9
315/70/17 Duratracs
Bilstein 5100s
XRC 10 winch
jks disconnects
cajun01 is offline
post #10 of 12 Old 01-31-2012, 02:52 PM
thanks but it can stay here.
post #11 of 12 Old 01-31-2012, 04:17 PM
You didn't get your drama fix over on that site, so you need to start it here too?
Cajun, when you get a chance, there is some good info and diagrams in the tech info area on Tom Woods website.
http://www.4xshaft.com/
GreenJK is offline
post #12 of 12 Old 01-31-2012, 04:30 PM
toymaster's Avatar
Vandy
Nope, they just deal with a less than great pinion angle. It is best to remove as much as possible without causing bad handling. In the old days it did not matter much because we just unlocked the hubs when going highway speeds.
JK 2dr rubi
toymaster is offline
