Gear change - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 01-30-2012, 08:10 PM Thread Starter
Muddevil's Avatar
Gear change
I'm looking to upgrade my stock 4:10's to 4:88's using what's left of my tax return. First priority is to payoff the Rubi. Then I'm looking at Or-Fab's rear tire carrier and a spare tire to match my shoes BFG MT KM2's.
My ? Is can I install the rear gears to save on gas now then upgrade the front? And what brand or distributor should look at?
Orlando
Muddevil is offline
post #2 of 7 Old 01-30-2012, 08:11 PM
SoK66's Avatar
Only if you disconnect the front axle. Pull the front driveshaft.
SoK66 is offline
post #3 of 7 Old 01-30-2012, 08:18 PM
leman's Avatar
why not go 5.13? what size tires are you running? IMO i dont think you notice a big enough difference to justify the cost. i went from 3.73 to 5.13 and wish i had waited for the 5.38s to come out.
2008 steel blue sahara
with some doo-dads
leman is offline
post #4 of 7 Old 01-30-2012, 08:37 PM
Fklein6768's Avatar
Stick or auto? What size sneaks? Not enough info to say what ratio would best suit what u want to do.
Is this thing on?.....
www.4x4s-pod.com
Fklein6768 is offline
post #5 of 7 Old 01-30-2012, 09:02 PM
Northernmedic's Avatar
Yes you can run different gear front to back BUT, don't use 4wd. In fact take your front driveshaft right out just to be safe!
Northernmedic is offline
post #6 of 7 Old 01-30-2012, 09:28 PM
Ken Jong Il's Avatar
It all depends on what tranny you have. I run 37's with Yukon 5.38's. My RPM's at 70mph is right below 2400 RPM. If you have a manual, I'd run 5.13's with 37's. You have to take into consideration what tire size you ultimately want to run. I personally wouldn't go above 37's on a factory Dana 44 with seriously beefing up your axle. You can run a different gear set I'm the rear, but like the peeps above have said, DO NOT ENGAGE 4 WHEEL DRIVE!!!
07 Rescue Green Unlimited
Upcoming projects - Much needed TLC
Ken Jong Il is offline
post #7 of 7 Old 01-31-2012, 07:49 AM
WXman's Avatar
Also, don't expect to save on gas if you run 4.88s with stock tires. It ain't gonna' happen. I just did that swap myself and so far my mileage is down about 0.5 MPGs from what it was before on the same tires.
2012 Dozer JKU Sport
ACE rock rails
3/4" Daystar spacers/extra OE spacers up front
Airaid MXP intake kit
33x12.50 GY Duratracs on MB 72s
WXman is offline
