Project: GREEN MACHINE - JKowners.com : Jeep Wrangler JK Forum
post #1 of 142 Old 01-30-2012, 09:15 AM Thread Starter
Black Lady's Avatar
I've had this done for a little while now but thought I would post a build thread for you guys to check it out.
Started with this a 2012 2 door sport 6 speed 3.21 gears.
It took me a while to figure out which way I wanted to go with my build but I finally decided on 37s.
Parts ordered: Rock krawler 3.5in x factor with drag link flip kit and HD tie rod.
PR 44 with ARB 5.13s chromoly shafts and synergy ball joints. It's the unlimited housing.
ARB compressor kit.
Detroit locker 5.13s chromoly shafts for the rear D44.
Coast 1310 F/R drive shafts.
Bilstein 5100s
Teraflex bumpstops
37/1350/17 toyo mts
17x9 cragers
Teraflex exhast spacers
Ruggid ridge a pillar switch pod
Crown ext brake lines
This is all I can think of at the moment.
Parts started showing up
Sent from my HERO200 using Tapatalk
Black Lady is offline
post #2 of 142 Old 01-30-2012, 09:22 AM
jeepchic55's Avatar
LOL, I love how you keep the parts in the comfort of a bedroom instead of the garage! Your JK is going to be awesome
jeepchic55 is offline
post #3 of 142 Old 01-30-2012, 09:22 AM Thread Starter
Black Lady's Avatar
I don't have a whole lot of pictures of the lift install but it went fairly smooth.
Here are a few pictures of the PR44 installed and the front suspension pretty much done.
post #4 of 142 Old 01-30-2012, 09:24 AM Thread Starter
Black Lady's Avatar
Mocking things up.
post #5 of 142 Old 01-30-2012, 09:28 AM Thread Starter
Black Lady's Avatar
Little welding on the front and rear trac bar brackets
post #6 of 142 Old 01-30-2012, 09:30 AM Thread Starter
Black Lady's Avatar
And this is how it sits now
post #7 of 142 Old 01-30-2012, 09:35 AM Thread Starter
Black Lady's Avatar
Few more pictures of the ext brake lines going in, my ARB setup, and some switches
post #8 of 142 Old 01-30-2012, 09:39 AM Thread Starter
Black Lady's Avatar
And for any of you guys considering Rockkrawler just do it. This is my jeep sitting level with over 400lbs in the back.
post #9 of 142 Old 01-30-2012, 09:44 AM Thread Starter
Black Lady's Avatar
Got everything dialed in yesterday and actually got to take it out and do some mild wheeling
post #10 of 142 Old 01-30-2012, 09:54 AM Thread Starter
Black Lady's Avatar
Gotta look after the parts. Thanks Man
post #11 of 142 Old 01-30-2012, 04:54 PM
SlvrJK's Avatar
Nice work dude, looks great.
SlvrJK is offline
post #12 of 142 Old 01-30-2012, 05:10 PM
Dr.Dirty's Avatar
Feedback: 21 reviews
Might want to give this another look
Dr.Dirty is offline
post #13 of 142 Old 01-30-2012, 05:17 PM
Sweet looking rig and nice build! As far as the sway bar links go a slight angle is ok thats what the heims are there for, but you may want to double check the centering of the front axle and make sure its dead on.
RK
post #14 of 142 Old 01-30-2012, 05:19 PM Thread Starter
Black Lady's Avatar
Are you talking about the slack in the sway bar link?
What do you see wrong this is my first jeep so I'm learning as I go
post #15 of 142 Old 01-30-2012, 05:20 PM
Dr.Dirty's Avatar
Most people choose to put the bolt thru followed by the nut then followed by the nylon waser then end link then nylon washer then cotter pin
Dr.Dirty is offline
post #16 of 142 Old 01-30-2012, 05:21 PM
RIP Brad
abendx's Avatar
Whoa.... all those questions lead to this!?!?
Nice job.... rig looks sweet.
abendx is offline
post #17 of 142 Old 01-30-2012, 05:27 PM Thread Starter
Black Lady's Avatar
Thanks man this will fix the damn rattling noise its making.
Do you no where I could get a pic of the correct way its supposed to be?
post #18 of 142 Old 01-30-2012, 05:31 PM Thread Starter
Black Lady's Avatar
I got to give guys like you a big thank you on this forum I've blew up a lot of guys inboxes on here asking questions. Without the help I never would have been able to do this for me doing all this by myself I think I did pretty good.
post #19 of 142 Old 01-30-2012, 05:36 PM Thread Starter
Black Lady's Avatar
RK
RK I took it to a alinment shop and they said everythings good it drives great. I've also checked it with a tape measure and it come out same on both sides. How do you guys check for centering of the axle? I set everything to specs in the instructions.
post #20 of 142 Old 01-30-2012, 05:41 PM
snksknr94's Avatar
I have a pic, having an issue loading it right now. I'll get it posted as soon as tapatalk wants to agree with my phone.
Aaron
2008 JK Unlimited Rubicon
snksknr94 is offline
post #21 of 142 Old 01-30-2012, 05:44 PM Thread Starter
Black Lady's Avatar
Thanks a lot man
post #22 of 142 Old 01-30-2012, 05:52 PM
snksknr94's Avatar
Thanks a lot man
No problem, still doesnt want to load. I'll keep trying it tonight, but basically you want the bolt through the bracket on the axle then the lock washer and nut, basically making the bolt into a fixed stud off the axle. Then the nylon washer followed by the link, another nylon washer and finally the pin.
Aaron
post #23 of 142 Old 01-30-2012, 06:21 PM
lunneborgc's Avatar
Thanks a lot man
Coming up.. Hold on a sec, let me go snap it..
2011 Green JK Rubicon Unlimited Purchased 10/18/2011
Previous Jeeps include a 99 TJ Rock Crawler, 74 CJ-5, 06 TJ Rubicon, and a 2001 TJ
lunneborgc is offline
post #24 of 142 Old 01-30-2012, 06:27 PM
lunneborgc's Avatar
Here's my interepretation of the image provided in the RK Install instructions.
Front Drivers side...
Bolt through axle bracket/lock washer/nut/plastic washer/sway bar/plastic washer/cotter pin.
Front Passenger side...
Lookin good dude! I have a 2011 JKU green same color, same lift, and waiting on my 37's to arrive,
Man I need to wash the Jeep!
post #25 of 142 Old 01-30-2012, 06:43 PM
snksknr94's Avatar
This is how mine are set-up. Still can't get the pic to load but they look similar to these.
Aaron
