Rear LCA Skids - JKowners.com : Jeep Wrangler JK Forum
post #1 of 16 Old 01-29-2012, 01:58 PM Thread Starter
Danny4652's Avatar
Rear LCA Skids
Looking for any input on rear LCA skids, i.e., easy install - one over the other etc. Any input would be appreciated.
EVO Rock Stars
http://www.offroadevolution.com/stor...?prod=EVO-1038
or
Synergy Suspension Jeep JK Rear Lower Control Arm Skids w/ Integrated Shock Mounts
http://www.synergysuspension.com/Syn...s-p-26606.html
"Courage is being scared to death ... and saddling up anyway" - John Wayne"
Danny4652 is offline
post #2 of 16 Old 01-29-2012, 02:07 PM
EMG006's Avatar
I like the poly stuff myself.
I went with the cheaper shock relocation mounts and welded the skids on. Easy to do on a lift, probably a little more tough just on jack stands cutting the shock mounts off and trimming the mounts up. If I wasnt have g some other welding down, I would have gone with the poly ones you posted.
River City Offroad
Metal Cloak
EMG006 is offline
post #3 of 16 Old 01-29-2012, 07:50 PM
SofaKing's Avatar
I installed the Evo's. The install was pretty straight forward and easy -- I used an angle grinder, several cut-off disks and a few grinding wheels. It took me about half a day but I took my time. I didn't have a lift, just used jack stands and rolled around on my garage floor.
2009 Silver Unlimited Rubicon -- Not really stock, anymore.
SofaKing is offline
post #4 of 16 Old 01-29-2012, 08:20 PM
evdog's Avatar
I got the poly one's install went good had to cut 1/4 " off plate was a little long but it went good
VE7 ESH
evdog is offline
post #5 of 16 Old 01-29-2012, 10:38 PM
PIG
PIG's Avatar
I'd vote but I think my response would be a little biased.
PIG is offline
post #6 of 16 Old 01-29-2012, 10:49 PM
CUOFFRDGA's Avatar
I'll put a vote in for ya PIG!
I've bought enough poly products to give 2 thumbs up here 😊
2008 RUBICON 2DR
TERAFLEX 3" Full FlexArm Lift
JKS ACOS Adjustable Coil Spacers (5.5" Total)
FOX 2.0 Resivour Shocks
20"x10" Rockathon Beadlocks
39.5x16.50R20 Pitbull Rocker Bias Ply
Total Height 83.25"
CUOFFRDGA is offline
post #7 of 16 Old 01-29-2012, 11:06 PM
toymaster's Avatar
Both products are great quality, it comes down to what vendor you want to support.
JK 2dr rubi
toymaster is offline
post #8 of 16 Old 01-29-2012, 11:36 PM
lunneborgc's Avatar
I'm also looking for a set. I had already planned on the EVO's but I didn't know Poly made a set as well.
Here's a couple pictures I was comparing for reference..
Poly
Evo
It appears the shock is a little bit lower in the Poly setup, and the rear sway bar is moved up with the EVO setup. I'd be surprised if there was a difference in the reliability or strength between the two. Anyone seen both in person that can list differences?
2011 Green JK Rubicon Unlimited Purchased 10/18/2011
Previous Jeeps include a 99 TJ Rock Crawler, 74 CJ-5, 06 TJ Rubicon, and a 2001 TJ
lunneborgc is offline
post #9 of 16 Old 01-30-2012, 08:45 AM
CUOFFRDGA's Avatar
I'm gonna have to look again, but if I remember correctly, the Poly actually picked it up higher than the EVO from its factory location.
I also want to say the Poly was thicker material as well.
It's been a minute since I compared them.
2008 RUBICON 2DR
Total Height 83.25"
post #10 of 16 Old 01-30-2012, 10:21 AM
Jboss's Avatar
Don't forget about Poly's upper mount too. That way you don't lose up travel.
http://www.polyperformance.com/shop/...t-p-29226.html
Also there is a coupon right now
2008 JKU Rubicon, AEV, Rock Krawler, Poly Performance, Poison Spyder
Jboss is offline
post #11 of 16 Old 01-30-2012, 01:18 PM
20JK10's Avatar
I have the Rugged Ridge rear lca skids. They don't relocate the shock so there is not grinding/cutting required.
http://www.quadratec.com/products/16138_1001.htm
Random internet picture
Wrangler Mountain Edition
Rock Krawler Synergy JKS LoD Goodyear
20JK10 is offline
post #12 of 16 Old 01-30-2012, 01:24 PM
toymaster's Avatar
Of course it depends on your set-up but, if you do that you will loose any travel gained. In my case I had more than 2" of up travel of the shock not being used. So, after moving the lower shock mount up 2" with the poly relocation kit I gained 2" of drop. If I had raised the top mount the entire set-up would have only gave me more ground clearance. As is I gained ground clearance and 2" of drop.
JK 2dr rubi
post #13 of 16 Old 01-30-2012, 10:04 PM
^^^^good point^^^
As long as the shock doesn't bottom out before your bump stops do, win-win!
xmikedentx is offline
post #14 of 16 Old 01-31-2012, 10:14 PM
ChuckMRN's Avatar
I installed Poly's upper & lower kits and kept same shocks and bumps. Went with out the sway for a while, then put it back with their drop down blocks. Very happy..
16 JKU Sport
RK 3.5 X Factor, UD 60's, Atlas T Case 4.3:1,
TR Bead locks with Toyo Open Country MT's,
VKS Bumpers and Sliders. EVO Skins,
PSC Hydro on Synergy Steering,
Fox Shocks and Bumps
"40's Baby!"
2011 JKU RUBI "SOLD"
ChuckMRN is offline
post #15 of 16 Old 02-01-2012, 12:45 AM
Polly or Evo, 2 great products.
post #16 of 16 Old 02-01-2012, 05:29 AM
rdlynch2's Avatar
Pure jeep here
2008 Black 2Dr 6spd D30/44
rdlynch2 is offline
