Pro Rock 44/60 re-gear break in??? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 01-26-2012, 08:50 PM Thread Starter
RGJK's Avatar
I will be getting my Jeep back this weekend. It now has a Pro Rock 44 up front with 5.13s, ARB, RCV shafts and ProSteer ball joints. In the Rear it has a Pro Rock 60 with 5.13s, ARB and chromoly shafts.
My questions is around the break in process and for how many miles?
What is the proper break in period for the gears? Do the lockers need a break in period?
For the gears I have heard everything from just drive easy for the first 500 miles to drive 15-20 miles and let the gears cool for 15 minutes and do this for 500 miles.
What have you all done and what has worked and what has not?
Dom
2008 Rescue Green JKU Sahara
RGJK is offline
post #2 of 5 Old 01-26-2012, 08:53 PM
BenFoo's Avatar
15-20mins drive then let them cool a bit. Then drive easy for the next 500mi. Lockers don't need any break in process, just test them for functionality and air leaks.
Drain, refill. Have fun.
BenFoo is offline
post #3 of 5 Old 01-27-2012, 12:47 AM
^that is what I found doing my regear research and it was backed up by the cat who did the work. Only I did several short 10 - 20 minute drives to put the new gears through heat cycles. I followed the advice and things worked out great
post #4 of 5 Old 01-27-2012, 08:11 PM Thread Starter
RGJK's Avatar
Thanks guys. I've got 34 miles so far. Thats been about 3 trips out this evening. I'm planning A LOT of city driving this weekend.
RGJK is offline
post #5 of 5 Old 01-27-2012, 09:20 PM
usmcdoc14's Avatar
at 500 drain the oil, open the covers, brake clean everything out and put fresh oil in.
usmcdoc14 is offline
