Diff Fluid Change - JKowners.com : Jeep Wrangler JK Forum
post #1 of 10 Old 01-23-2012, 06:37 PM Thread Starter
cru9's Avatar
Diff Fluid Change
I have a 2010 JKU Sport with a Dana 30 in the front and 44 in the rear. I also have 80,000 miles on the Jeep. I want to do the diff fluid myself this time. I have been changing them about every 10,000 miles..How hard is it to do and what brand fluid and weight do ya'll recommend? Also I think the rear needs limited slip additivie.
cru9 is offline
post #2 of 10 Old 01-23-2012, 07:39 PM
Look at your manual it'll have the info on what weight to run, think its 75-90. If you have a trak lock in the rear then yes you'll need to pick up the additive from your dealer.
As far as brands go that depends on who you talk to. My personal experience with royal purple is that it doesn't last to long in the JK, I know others that have said the same thing.
I personally run the house brand from my local O'reillys.
HOT_DAMN is offline
post #3 of 10 Old 01-23-2012, 07:44 PM
warhawk's Avatar
Mobil 1 Synthetic 75w90 LS is what I run in my diffs.
warhawk is offline
post #4 of 10 Old 01-23-2012, 07:51 PM
e-jeep's Avatar
Feedback: 12 reviews
4 quarts 75w90
If you use Mobil 1 Synthetic, Royal Purple, etc. you don't need the additive.
Put a catch pan under the diff; remove the plug bolt from the fill hole (a 3/8" ratchet w/o socket will remove the plug bolts); remove the bottom plug bolt and let drain.
Replace the bottom plug bolt and fill the diff; replace the top plug bolt.
Front Differential Capacity: 2.7 pints (1.35 quarts)
Rear Differential Capacity: 4.75 pints (2.375 quarts)
Easy job.
My Build Thread ~
NE Trail Ride Thread ~
Adrenaline Offroad
e-jeep is offline
post #5 of 10 Old 01-23-2012, 07:52 PM
OH9JK's Avatar
I stick with good old Valvoline conventional gear oil. It comes with the limited slip modifier already in it if you have a LS rear end. If not no worries can use the same stuff.
There is a drain plug and a fill plug. No need to pull the covers unless you want to inspect the gears.
75W90
OH9JK is offline
post #6 of 10 Old 01-23-2012, 08:24 PM Thread Starter
cru9's Avatar
Thanks. I got a new project to try this weekend. And correct me if I am wrong but you fill it up thrill is spills out top plug hole
cru9 is offline
post #7 of 10 Old 01-23-2012, 08:31 PM
Yes if you have stock covers. But don't try to "keep more in it" by tossing the fill plug in it. It'll likely puke it out of the breather on your first highway run.
post #8 of 10 Old 01-23-2012, 08:33 PM
snowbilt's Avatar
No you're thinking of your wife,gf and/or booty call
Sent from my iPad on the toilet...
snowbilt is offline
post #9 of 10 Old 01-23-2012, 08:39 PM Thread Starter
cru9's Avatar
Lol!!!!!!:thumbup:
cru9 is offline
post #10 of 10 Old 01-24-2012, 02:52 PM
Correct and on the rear I usually jack up the passenger side so you can add a little bit more, It allows some fluid to run down the axle tube. Ive never had any fluid puke out of my breather tube.
HOT_DAMN is offline
