ABS Sensor extensions? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 01-21-2012, 12:47 AM Thread Starter
JaminJ's Avatar
Does anyone make these?? I have a 2007 JK I extended the brake lines but I think I still need to extend ABS sensors. Any help/advice would be appreciated
BDS 4 1/2" Lift 1" DayStar Body lift, 1 3/4" Rusty's Offroad Front & Rear Adjustable Trac Bar
ATLAS 5:1 Twin Stick Transfer Case
37" Cooper STT Tires
Moto Metal 17" Wheels
Rugged Ridge Front Bumper
LOD Stubby Rear Bumper
Warn Winch
Hella Offraod Lights/ PIAA Offroad LIghts
Gen Right Fenders
Poison Spyder Rockergaurds
AirRaid Intake
Superchip
Evo Front Sleeves & Gussets
EVO High Steer
HD Tie Rod
5.38 Yukon Gears
Solid Dana 44 Front & Rear Covers
Adams Front & Rear Drivelines
JaminJ is offline
post #2 of 6 Old 01-21-2012, 01:10 AM
bthomas's Avatar
just cut the factory zip-ties and re-route them
bthomas is offline
post #3 of 6 Old 01-21-2012, 01:32 AM
That's what I did. They are pretty long so I ziptied them to my extended break lines. No issues at full droup on my very flexi suspension.
post #4 of 6 Old 01-21-2012, 01:39 AM Thread Starter
JaminJ's Avatar
I did that to one but I think it still looks tight I might have to re look at it as if you both are not having issues maybe I am just thinking I will and there might not be a issue there.
Warn Winch
Gen Right Fenders
AirRaid Intake
Superchip
EVO High Steer
HD Tie Rod
5.38 Yukon Gears
JaminJ is offline
post #5 of 6 Old 01-21-2012, 01:48 AM
I have the RK 5.5 long arm suspension and have yet to install bump stops. With the long legs I can still stuff the tires into the fender wells. I just disconnected the stock mounting bracket and fixed them to my extended break lines. At full stuff, the extended side still has an inch or so of play. Been running this setup for almost 3 years.
post #6 of 6 Old 01-21-2012, 11:45 PM
carbonunit's Avatar
There is a ton of spun up wire. Here is how I extended my fronts.
www.jkowners.com/forum/showthread.php?t=49247
2K8 Rubicon SWB
4" Terraflex with uppers and lowers / MX6 shocks /37" BFG KM2's /17x9.5 4" BS Raceline Monster Beadlocks / Dynatrac Front housing / 4:88's / RCV Shafts /Superior Evolution Rear Shafts / Genright ALUM Front bumper and Fenders / LoD Rear with Racks / OffRoad Evo Sliders /Or-Fab Cage
carbonunit is offline
