Rubicrawler owners- I'd like some info please! - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 01-11-2012, 07:22 PM Thread Starter
VADERJKU's Avatar
I'm contemplating a Rubicrawler as well! Couple questions:
1. With my eventual planned 5.13 gears, my crawl ratio would be approx 158.5:1, is this excessive for an auto? (I've had a manual rig with 117:1 crawl ratio and loved it but, no experience with an ultra low slush box) Do those of y'all that have a Rubicrawler find yourselves utilizing the full low range very often? Or the 2.72:1 low very often? (in lieu of stock 4:1)
2. How tough is the install? (I'd like to be able to put it in myself, if possible)
3. To be quite frank, have you found it to be a worthwhile addition?
4. To those with stock Rubi lockers, what have you done toward getting the Jeep to allow locker engagement when the Rubicrawler is in low but the stock t-case is not? The total control locker bypass wiring or...?
Thanks!
:whiskey:
VADERJKU is offline
post #2 of 6 Old 01-11-2012, 09:22 PM
One of the best mods I put in my Jeep. I had Teraflex in SLC install mine because of the release date and a planned trip to Moab. 5:13s and 37s works great. I don't have the 4:1 transfercase but 7.4 to one is lots of reduction IMO.
Alaska-HWY JK is offline
post #3 of 6 Old 01-11-2012, 09:52 PM
My friend has one in his LJ and loves it, he is on 42" tires with the stock transfer case, automatic trans and I believe 5.13's.
HOT_DAMN is offline
post #4 of 6 Old 01-12-2012, 05:33 PM
if your finding that with bigger tires the engine doesnt have the nuts or likes to run hot when low is to low & high is to high, id look into it.
Ive got one in a TJ & running them both in low is pretty much pointless.
So if your running a 4/1 case & need wheel speed for sand, mud whatever, Id say go for it.
Click the sig for everything you need to build a JEEP... 805-706-0232
NEW PRODUCTS ADDED DAILY !!!
----> Click and download the new catalog!!!
Thean is offline
post #5 of 6 Old 01-16-2012, 09:56 AM
PEEJ's Avatar
Thanks!
:whiskey:
I have one in my JK Rubicon and I think it is my favorite mod so far. It is nice to have the option of 2.72:1 , 4.0:1 and 10.88:1 I have 5.13 gearing in mine also. I use all of the options on a regular basis you can select the ratio you need for the terrain you are in.
07 Unlimited Rubicon, 4 link rear, 3-link front, 37x12.50x17 BFG KM2's, Dana 60 rear, Warn Powerplant, Icon Perfromance coilovers w/ res in front Icon shocks w/res in back, 5.13Gears, Rubicrawler, RCV axles, WTO hydro assist, Anitrocks front and rear, Black Rock Bead Locks, TF speed bumps on all corners.
PEEJ is offline
post #6 of 6 Old 03-12-2012, 08:58 PM
Munday's Avatar
I just had one installed. I have not had a chance to test it out yet but it is really low. I shifted it in and drove down the back ally , I'm running 37's and 5:13's as well. I will be testing it out at EJS this year. It sounds kinda loud when engaged ,but thinking it is just because of the 6 extra gears working, or at least hoping that is the reason,I always over think / trip out a little to much,It also slips out a little, I'm not sure if the cables just need to work in a bit.I may need to get in there and play with the cables again if it slips any more.
Munday is offline
