Steering arm brace problem WTF - JKowners.com : Jeep Wrangler JK Forum
post #1 of 25 Old 01-09-2012, 06:11 PM Thread Starter
May have to replace my steering box because of this dam thing! All I was doing was installing a new track bar and the slick steering arm brace. The brace sounded like a good idea because of all the Steering box problems I have seen on-line. Now I have a major problem.
This is what I was trying to install:
The nut/bearing surface in the left of the picture is what I am having problems with.
While trying to install the Rock Solid steering arm brace I start installing the new nut/bearing surface, it screws on about half way and gets a little tight, I think no big deal and try and get past the tight spot with the wrench, it will not turn so I try and back it off and inspect it and it will not back off either. The nut is stuck half on, broke a 1/2in extension trying to get it to unscrew and nothing, like its welded on! Next, I go get a 1 3/8” impact socket thinking it should be able to take it off, of course this does not work either. I think the impact will not work because the whole assembly can move so the impact really is not having the ability to do its job. At this point I think the only option is to pull the steering box and put the pitman arm in a big ass vice to see if the impact can take it off while the steering shaft is not able to move. Really worried at this point that the threads on the shaft will be messed up when/if I ever get this dam nut off causing me to purchase a whole new steering box for $720.
I called Rock Solid and they did say they had one other problem with the nut not being tapped properly before but not to the extent I am seeing, they are sending me a new one. I would be happy just to be able to get the stock nut back on so I could drive the Jeep. I just can’t understand how this thing is so stuck on there, never seen anything like it, I used little to no force putting it on to the point it is and then BAM, stuck like its welded on. It is not cross threaded either, that would have been evident right after starting it on such a large nut I would not have gotten 1 thread engaged. Anybody seen something like this before?
Does anybody have any tips for taking the steering box out? It looks like I need to remove the coil spring to get at one of the bolts? Other than that it just looks like I just have to remove the drag link, the coolant overflow tank, power steering lines, and disconnect the steering linkage. Is this correct? Any gotchas I need to know about?
This whole thing is about to drive me insane, should have been a simple upgrade and turning out to be a nightmare.
Thank You in advance for any advice you can give me.
moparmad74 is offline
post #2 of 25 Old 01-09-2012, 07:19 PM
20JK10's Avatar
I can't help you with the removal. But it is known that some trackbars don't clear that brace.
Wrangler Mountain Edition
Rock KrawlerSynergyJKSLoDGoodyear
20JK10 is offline
post #3 of 25 Old 01-09-2012, 07:26 PM Thread Starter
I Got RockSolid trackbar with it so I expect it will clear fine. But with the way my luck is going so far I should expect it to mess something completely unrelated up though.
post #4 of 25 Old 01-09-2012, 08:18 PM
Get a bigger/stronger impact
Turn the steering all the way so the impact can work better
If they in fact sent you a bad nut
They should replace the steering box
If the nut caused any damage
Remove the nut do not try and tighten it up any more
The threads still may be good further
Up where it needs to tighten up on
Sent from my iPhone
OutlawJK is offline
post #5 of 25 Old 01-10-2012, 07:08 AM
They should,at the least send you a die to chase the threads with.
2008 JK 4Dr Rubicon
Stone white
Mygig W/Uconnect working.
Hard top/Auto tranny
First mod, dog slobber.
Painted hard top
Spidertraxx 1.5 spacers
Teraflex 3" lift
rob4607 is offline
post #6 of 25 Old 01-10-2012, 07:12 AM Thread Starter
Thanks for the ideas but I already tried turning the wheel all the way and there is still to much play I think. Already used the largest impact I have that should either take the nut off or destroy things in the process. I think my only move now is to take the box out and get the pitman arm in a strong vice so it can't move at all. Then something is going to give.
This is the impact I was using and it just fits up there, can't go any bigger with the box still in the jeep.
post #7 of 25 Old 01-10-2012, 07:24 AM
UGET IT's Avatar
Jeez........seems like it cross threaded...and badly.
Method Motorsports
Email:
UGET IT is offline
post #8 of 25 Old 01-10-2012, 07:40 AM Thread Starter
Its not cross threaded, it went on halfway without an issue then just locked up. Very strange, I have never seen anything like this happen before. Tonight I am pulling the box and will bring it in to work with me. The nut will come off, even if I have to pull out the Jack Hammer sized impact, something will give way.
I may slit one side of the nut with a grinder almost down to the threads, that should let it have a little give.
post #9 of 25 Old 01-10-2012, 07:52 AM
fourplyn's Avatar
If you do take the steering box off. After putting it in a vice, how bout heating the nut up with a small torch..and trying to break it free. Maybe it will expand the nut enough.
Just a thought. Sounds like a bugger of a nut you got there.
Past jeep:
- 40" Pro Comp X-Terrain
fourplyn is offline
post #10 of 25 Old 01-10-2012, 07:54 AM
SoK66's Avatar
If you can get an angle grinder with a cut-off wheel in there you may be able to do this on the rig. A Dremel with a cut-off wheel might work of space won't permit use of an angle grinder.
SoK66 is offline
post #11 of 25 Old 01-10-2012, 07:59 AM Thread Starter
Good point, I don't think I can get the angle grinder in there but a dremel would fit. It may take a very long time with a dremel though. I'll give it a shot and see if I can make any progress with the dremel before pulling the box.
Thanks!
post #12 of 25 Old 01-10-2012, 08:01 AM Thread Starter
That is one of the first things I will try if I pull the Box.
Thanks,
post #13 of 25 Old 01-10-2012, 08:58 AM
TrailDuty.com
PhilD's Avatar
I'm not sure removing the steering box is going to help you much, as you should be able to apply plenty of torque where it is. Definitely sounds like it is galled. I'd step up to a 3/4" drive socket and a 36" or 40" breaker bar. You can also try getting some penetrating oil in there also, sometimes you can tighten it very slightly to help the oil get in, then switch between loosen/tighten often, this works well with a high torque impact.
PhilD is offline
post #14 of 25 Old 01-10-2012, 09:27 AM
Redjk07's Avatar
It looks like you have an adaptor on the impact gun, sometimes that can take away some power to the socket from the impact gun. I know I have used an extension on the socket and gun and then took the extension off and got some more power to the socket. But I would agree if you can get some heat on it and heat the nut up, but becarefull not to get it too hot to damage the seal on your box. Good luck but I have been looking at that brace too but talk my self out of it.
Redjk07 is offline
post #15 of 25 Old 01-10-2012, 09:34 AM Thread Starter
When I tried with a 1/2" drive the extension snapped like a twig using a 36" breaker bar. Problem is, I have to have such a long extension on it to get down to a point that a breaker bar can be used. It takes about 14" to get in good place to use one. Finding 3/4" extensions locally may be tricky as well, and costly if they snap on me.
Certainly putting that in the bag to tricks though. I really hate that I may have to pull the box and don't want to do it.
Thanks,
post #16 of 25 Old 01-10-2012, 09:49 AM Thread Starter
If I could find a 3/4" drive socket 1 3/8" true deep well I would use it but all the ones I find don't have the 6 point going deep into the well. They have the nut stop on them not letting them go over the bearing surface. All I could find was a axle hub socket that worked and they seem to only be in 1/2" drive so I had to use the adapter.
That impact puts out 1700 ft/lbs, I think it has to be all the joints before there is a solid stop letting it move ever so slightly and not breaking loose using the impact?
Thanks for the info.
post #17 of 25 Old 01-10-2012, 07:45 PM Thread Starter
PhilD, You Win the prize!!!! I'd buy you a beer or 12 if you lived near by! I got the dam thing off using the following tools. Kind of back to basics like PhilD suggested.
3/4" Drive breaker bar, 3/4" x 16" extension with a long piece of pipe and was able to find a 3/4" drive 1 3/8" true deep well socket thanks to Farmers Market. Using the a torch and a grinder it finally came loose.
If this ever happens to you this is all you need:
It really messed up the threads on the shaft for about 1/4" and I ended up having to grind the end of the shaft off to get to good threads. The nut still fully engages so I think I'm safe there. Put everything back together (without the steering shaft brace) and took it for a drive...
Glad this is fixed, next weekend I start the ProRock44 install, re-gear, lockers front and back, track bars and control arms. Going to be a fun couple weeks!
Thanks to everyone who made suggestions on how to get this resolved. What a great place, and not one person gave me the duel your number one smiley I see so often around here. May have just set myself up for one huh.
post #18 of 25 Old 02-06-2012, 03:02 PM
Ug! I am in the same exact situation as you were. And I dont have access to the tools you used to remove it. FML.
remborsky is offline
post #19 of 25 Old 02-06-2012, 03:45 PM
Is it the same company?
Jtwilliams is offline
post #20 of 25 Old 02-06-2012, 05:35 PM
Yep. Just got it off but the replacement bearing nut is toast. Also have to try to file threads or cut messed up ones off.
post #21 of 25 Old 02-06-2012, 05:43 PM
venom's Avatar
mine went right on with my fingers and tightened it with a 3/4" drive ratchet/breaker bar
leave the lock washer off to try to thread the nut on by hand, if it doesn't go, figure out if its gunked threads or tapped wrong.
If it goes, then put the washer back on and have at it with the torque monster tool of your choice!
seriously guys - try to thread them by hand BEFORE just going apeshit with an impact or a breaker bar!
now the little impossible to install inside bolt was a different story.....
I started to drill out the threads and put a nut on the back since theres clearance for a nut and it would make life a LOT easier, but I had an allen head replacement bolt and ball tipped allen wrenches to get it started.
If you don't have a wobble socket, its pretty much impossible to install the provided bolt.
Originally Posted by My Wife
venom is offline
post #22 of 25 Old 02-08-2012, 08:09 AM Thread Starter
I used the angle grinder to "Carefully" grind down the treads and get to good ones, it was a pain in the ass but slow and steady it did the job. When I put mine on it when on fine with my fingers and about 2-3 turns in just got stuck and would not go on or off.
I am finding out now that all this trouble was for nothing as I just installed a prorock44 in the front and the Rocksolid track bar will not clear it so I had to put my stock one back on only to find out the stock one will not clear the steering arm brace during flex so I have to remove that until I find a adjustable track bar that will work with the RS brace or remove the brace forever.
Anybody want to buy a trackbar?
post #23 of 25 Old 02-08-2012, 08:14 AM Thread Starter
The treads in the middle of the nut were messed up, not the end so it started to screw on fine then locked up. This is the third one I know of as of now, Rocksolid told me they saw the problem before on another nut.
FYI, The little inside bolt was no problem with a wobble extension.
post #24 of 25 Old 02-10-2012, 12:14 AM
venom's Avatar
Thats why you take the lock washer off and run it all the way on with your fingers first to test the threads.
if it runs all the way on without the lock washer, you have threaded it on farther than it will go with the washer, so you know its good.
Take it back off, put the washer on and torque it down.
its not that hard to check it beforehand is all I'm sayin.
venom is offline
post #25 of 25 Old 05-09-2012, 09:49 PM
My Rock Solid Steering Box Brace Nut will just start and locks up...tried one round with a wrench...no go!...backed it off...put on stock nut no problems!...screw the Rock Solid Nut...emailed them...will have another overnighted to me tomorrow...
Also tried Rock Solid Nut upside down to see if the threads were better/correct size...no go!...
And these guys are building LS1 Jeeps for folks?...wheres the QAQC?...Why wouldn't they check the fit on the nuts/bearings prior to shipping? Also just after having the problems with two other folks?
Somebody is cutting these threads with a lathe and not getting it set up right...
LTZ470 is offline
