Lower on passenger side - JKowners.com : Jeep Wrangler JK Forum
post #1 of 13 Old 01-07-2012, 09:52 AM Thread Starter
I put a 2.5" Teraflex spring kit on a few months ago. Ever since then I've sit lower on the right (passenger) side by maybe .5".
Does anybody else have this? I'm thinking of adding a .5" spacer just on the passenger side to maybe level it out.
And yes, the springs seem to be all sitting properly in their "groove", etc.
rubi3 is offline
post #2 of 13 Old 01-07-2012, 02:51 PM
MoridinTX's Avatar
That is the characteristic Jeep lean. Lots of Jeeps do that with / with out lifts.
My Jeep from factory had the lean.
That being said, I also have the Tereflex 2.5" coil lift with their shocks. I too have the lean. It is not just the TF lift that does this.
09 BLACK Sahara 4 Door - Auto, G2 4.88s
TF 2.5" Coil Lift w/shocks, TF Frnt Adj Trac, TF FLCA, JKS Discos, JKS Rear Adj Trac, LOD Full Rear GEN2,
A.C.E. Rock Rails, Viper TB: Check the Garage for more.
MoridinTX is offline
post #3 of 13 Old 01-07-2012, 02:54 PM Thread Starter
I guess it just wasn't as noticeable when it was stock, or it wasn't there b/c of the stock springs.
Either way I'm going to level it out.
I just wonder do I put .5" spacer on the front and back passenger, just front, etc. Makes sense that I would do both front and back on that side, right?
rubi3 is offline
post #4 of 13 Old 01-07-2012, 02:55 PM
Hello
Hey did you check, springs are equal? may be there's some problem.
Galvinee is offline
post #5 of 13 Old 01-07-2012, 03:00 PM
MoridinTX's Avatar
I thought about leveling mine as well. If I do it, I will add a spacer to both the front and rear.
When I installed my lift I did check. The rear springs were the same and the fronts were the same.
post #6 of 13 Old 01-07-2012, 03:00 PM
08rubicon's Avatar
Do you have a full tank of gas? Does it still lean when you are on or close to empty?
2012 Unlimited Rubicon
08rubicon is offline
post #7 of 13 Old 01-07-2012, 03:17 PM
MoridinTX's Avatar
For me, the lean is always present, but yes, much more noticeable with a full tank of gas. I am used to it now so probably won't do anything about it.
post #8 of 13 Old 01-07-2012, 04:13 PM
Southern Girl's Avatar
Switch your springs. They make one side a lil longer to compensate for the gas tank. Switch em' and you should be good to go!
American by Birth! Southern by the Grace of God!
Southern Girl is offline
post #9 of 13 Old 01-07-2012, 04:15 PM
SoK66's Avatar
Welcome to the JK Lean! TF uses a 1/2 spacer on the upper spring seats, plus the factory spring isolator which is about 1/2" by itself. So, you can try just removing the isolator on the left side, or add 1/2 of spacer to the right rear upper spring seat by swapping out the 1/2 one for a 1". Done.
Moving springs side to side didn't work for me, in fact it made it worse by about 1/8".
SoK66 is offline
post #10 of 13 Old 01-07-2012, 04:26 PM
nlgrav182's Avatar
Adjustable sway bar end links can be turned out a little more on the low side to balance things out.
OKAY FUCKMOUTH.
nlgrav182 is offline
post #11 of 13 Old 01-07-2012, 06:22 PM Thread Starter
Yeah, mine is there all the time, regardless of gas level.
My TF springs were the same size, and had the same part number before installation. I would think if they were different they would have said "use XXX on the left, YYY on the right."
I think I may get 4 spacers, 1" for the right and .5" for the left
I had heard that the sway bar links could fix it, but somehow the spacers seem more like the way to go.
I guess I need to determine if I had another .5" on the left and 1" on the right, if I have to worry about anything else (brake lines, etc)
rubi3 is offline
post #12 of 13 Old 01-27-2012, 10:18 AM
pcmasten's Avatar
Just put a LoD bumper and tire carrier on and the lean looks a bit more noticeable. I have a 2 1/2 lift, but was thinking maybe going to 3" springs anyway so a 1/2 spacer on the passenger side would take care of it.
Semper Fi USMC 1968 -1971
09 Sahara 4dr Unlimited
D44 Front w/ elocker, TF C braces, Currie HD Tie rod, ARB rear locker, 5.13's
2 1/2" teraflex lift + 1" spacers
JKS Adj front/rear trackbar and quick disco's
ACE Mfg Rock Sliders
pcmasten is offline
post #13 of 13 Old 01-27-2012, 11:16 AM Thread Starter
I got my spacers but am going to wait a bit to put them in. I think if anything it's more of an annoyance than anything else. I don't think it impacts the drivability, etc.
2008 Rubicon - Stone White - Automatic
Gibson Stainless Dual Exhaust - K&N Performance Intake Kit - Superchips Flashpaq
AEV Black Pintlers - 35" x 12.5 Nitto Trail Grapplers
Teraflex 2.5" Springs - Bilstein 5100 shocks - Teraflex adj front & rear track bars - Teraflex adj control arms
Poison Spyder Brawler Lite Bumper w/ Bar
Coast 1310 front & rear driveshafts (pending install)
rubi3 is offline
