Ahem... customized the rear fenderwell pinch seams... - JKowners.com : Jeep Wrangler JK Forum
post #1 of 15 Old 01-07-2012, 12:19 AM Thread Starter
NoQuarter#121's Avatar
I was fooling around in my field today and running my jeep up a stump.
I have pictures, but do not know how to post them.
With the lockers engaged it was pretty shocking how well it would climb.
The rear wheels (BF 37"s) were hitting a pinch seam that is just under the rubi rock rail in the rear fender well.
I pulled the wheels off and, ahem... customized the sheet metal by beating it flat at both wheel wells with a sledge hammer.
Kinda tough to do on a brand new rig...
Is there a better solution?
I could have cut them off (I have a fully equiped shop with a plasma arc, grinders, sawzalls whatever...)
But folding it over and painting the "fixed" sheet metal seemed like the best solution.
What have you done?
I'm having some minor hammer remorse...
NoQuarter#121 is offline
post #2 of 15 Old 01-07-2012, 12:24 AM
uhmmmmm I spent about 10 seconds each and cut off with sawzall
I finally ditched that "other" forum
and coming to wheel on the dark side
captjay is offline
post #3 of 15 Old 01-07-2012, 01:03 AM Thread Starter
I thought about that, but was concerned about creating a gap where moisture could enter the pinch seam.
The sheet metal was already damaged from the tire rubbing it in reverse.
I live the the northwest near Seattle.
It rains here.
Not saying what you did was wrong.
Did you seal it with mastic?
Did cutting it create a gap?
I could easily remove the bent/folded material with a cutting wheel on a 4" grinder.
But I won't...
Its done now.
And I'm lazy.
I was having hammer remorse.
I'm over it.
The flat black paint has erased my sins.
post #4 of 15 Old 01-07-2012, 04:22 AM
Rottenbelly's Avatar
I cut with plasma, refilled the burned up foam in gap with some fresh foam and sprayed some rattle can bedliner in the wheel wells.
You smell that?
Rottenbelly is offline
post #5 of 15 Old 01-07-2012, 07:48 AM
Got Mud's Avatar
try this post. I did the same thing and it worked out very well.
https://www.jkowners.com/forum/showthread.php?t=65328
Got Mud is offline
post #6 of 15 Old 01-07-2012, 07:54 AM
I used the BFH method my self and feel no remorse.
Sent from a place where there are no roads.
4DRedRock is offline
post #7 of 15 Old 01-09-2012, 03:05 PM
highwayman's Avatar
^ This....
highwayman is offline
post #8 of 15 Old 01-09-2012, 05:08 PM
SoK66's Avatar
I did the Sawzall method and filled the gap with some windshield adhesive. Some rattle can black, done.
SoK66 is offline
post #9 of 15 Old 01-10-2012, 05:58 AM
neoxxis's Avatar
Cutting is better.
Cut, apply epoxy or cement or whatever, and paint.
And cut like this:
neoxxis is offline
post #10 of 15 Old 01-10-2012, 05:18 PM
SubCultureNM's Avatar
Originally Posted by neoxxis View Post
Cutting is better.
Why?
1997 TJ with LOTS of stuff.
2011 2DR Rubicon with stuff.
2012 JK8 with some stuff.
SubCultureNM is offline
post #11 of 15 Old 01-10-2012, 08:13 PM
Cutting is better.
And cut like this:
In your opinion. For me I bent it over with a mini sledge. Hit it with some spray on bed liner I had handy and was done. That was 2 years ago. No sharp edges no rusting and it took a whole 2 min.
post #12 of 15 Old 01-10-2012, 08:16 PM
md_rubi's Avatar
I had mine cut twice and plate welded so I can leave the ride height low
md_rubi is offline
post #13 of 15 Old 01-11-2012, 04:29 AM
neoxxis's Avatar
I bent it first and it was not as clean as when it's cut.
It's just cleaner. Probably does the same job...
Plus you can cut a bigger chunk than what you get by bending the corner...
neoxxis is offline
post #14 of 15 Old 01-11-2012, 06:26 AM
TrailDuty.com
PhilD's Avatar
I cut a lot off (for when I had 40's) and filled it with Bondo Glass.
Not a great pic, but you get the idea:
PhilD is offline
post #15 of 15 Old 01-11-2012, 10:32 AM
Tail Rated's Avatar
cut mine on my last JK with a sawzall. filled the hole with JB weld putty. after it cured I sanded and painted. couldn;t really tell I even cut it.
going to do the same on our 2012.
2016 JKU
Tail Rated is offline
