Reverse triangulated 4 link - JKowners.com : Jeep Wrangler JK Forum
post #1 of 47 Old 01-04-2012, 12:32 PM Thread Starter
THECHAD's Avatar
Has anyone tried this on a 4dr? Other than Rancho
18 BRAVO
panama
kuwait
somalia
bosnia
cuba
now just kicking it as a civilian
I served so your lazy ass didnt have to
THECHAD is offline
post #2 of 47 Old 01-04-2012, 12:53 PM
cjcraig7's Avatar
Just do it!
cjcraig7 is offline
post #3 of 47 Old 01-04-2012, 04:39 PM Thread Starter
THECHAD's Avatar
Lol that's what I'm thinking
18 BRAVO
panama
kuwait
somalia
bosnia
cuba
THECHAD is offline
post #4 of 47 Old 01-04-2012, 05:01 PM
We tried a real Reverse Triangulated 4 Link Setup On our Victim if you want to check out the build thread on here!
RK
post #5 of 47 Old 01-04-2012, 05:13 PM Thread Starter
THECHAD's Avatar
I see you sell one for the 2 door, but not the 4 door, why is that?
18 BRAVO
panama
kuwait
somalia
bosnia
cuba
THECHAD is offline
post #6 of 47 Old 01-05-2012, 08:12 PM
Because the 4DR sucks.
Runs and hides.
2008 JK X 2DR NSG370
Time to build the TONS!
Long Island Off Road Club
NOVA4x4
Suffolk JK is offline
post #7 of 47 Old 01-05-2012, 09:50 PM
Impulse Off Road's Avatar
I have built 2 JK's with the rear triangulated 4-link. The first one was a silver 4 Door used by BFGoodrich in the 2008 Ultimate Adventure and the second was built for a customer. The rear has tons of anti squat so we changed how the links mounted on the 2nd one and it works perfectly. Rancho uses their flex bushing that really limits the amount of vertical travel of the center section in the rear suspension. I just barely modified a Rancho 3-link and put a heim joint in place of the Rancho bushing. I was able to get about 4" more down travel than I did with the stock rancho set up. I put limiter straps on the center section so the heim joint wouldn't bind. I had an additional 1.5" of down travel available at the wheel end when the axle was drooped all of the way out with the limiter straps tight.
you can see a picture of the modified rancho 3-Link here:
http://blogs.4wdandsportutility.com/...-jk/index.html
Impulse Off Road is offline
post #8 of 47 Old 01-06-2012, 08:09 AM Thread Starter
THECHAD's Avatar
cool thanks for the pic
18 BRAVO
panama
kuwait
somalia
bosnia
cuba
THECHAD is offline
post #9 of 47 Old 01-06-2012, 08:39 AM
Hey, I like that shit!
Jeepmods is offline
post #10 of 47 Old 01-06-2012, 08:40 AM
nootherride's Avatar
thats nutty...i Like it!
nootherride is offline
post #11 of 47 Old 01-06-2012, 08:48 AM
ScaleJK4x4's Avatar
What is the advantages of this over a regular triangulated 4 link?
-Scott S.-
'07 2Dr Silver Rubicon
ScaleJK4x4 is offline
post #12 of 47 Old 01-06-2012, 08:52 AM
ALASHA's Avatar
You dont have to relocate the gas tank.
ALASHA is offline
post #13 of 47 Old 01-06-2012, 09:00 AM
^ That just convinced me to put this down for a future mod.
Jeepmods is offline
post #14 of 47 Old 01-06-2012, 09:05 AM
ScaleJK4x4's Avatar
That is DEFINETLY a plus, but which one is better (gemoetry wise)?
-Scott S.-
post #15 of 47 Old 01-06-2012, 09:09 AM
ALASHA's Avatar
Im not expert and since you didnt specify "Experts Only" I will add my thought on it.
In my head, I cant figure out how this geometry is better because as the axles drops, the lower arms want to pull the axle forward while the reverse triangulated uppers want to pull the axle back so in my mind this design has to provide less droop than a normal triangulated four link design.
ALASHA is offline
post #16 of 47 Old 01-06-2012, 10:12 AM
redx08's Avatar
The gas tank would still have to be relocated.
08 jk unlimited X
1 ton axles
39.5 Iroks
redx08 is offline
post #17 of 47 Old 01-06-2012, 10:29 AM
TrailDuty.com
PhilD's Avatar
If you are talking about the whole axle drooping then you are most probably right, but if you just look at flex, ie: one side drooping as the other is compressed then no. The reverse link is just a pivot point and what really restricts one side drooping now is the lower control arms and shock length. You should be able to get quite a lot of flex out of a system setup this way.
I've been going back and fourth between this and a triangulated four link, but as already mentioned you need to move that gas tank to do the four link, so this may be an easier way of achieving a similar result and getting rid of the track bar too.
PhilD is offline
post #18 of 47 Old 01-06-2012, 10:30 AM
TrailDuty.com
PhilD's Avatar
Not with reverse link like pictured above, no need to move the gas tank.
PhilD is offline
post #19 of 47 Old 01-06-2012, 10:35 AM
If any of you plan to do the rear 4-link pm me and I will tell you what I learned so that you dont have to learn it for yourself and get it perfect the first time.
post #20 of 47 Old 01-06-2012, 12:37 PM
quaylefarmer's Avatar
John - Do you have any pics of the upper shock mounts on this rig?
quaylefarmer is offline
post #21 of 47 Old 01-06-2012, 01:06 PM
ScaleJK4x4's Avatar
Are those two suspension setups (triangulated and reverse tri...) any more stable in off camber situations than the regular 5 link? Or is that something completely different (dependent more on sway bars ect.)?
Just learnin'!
-Scott S.-
post #22 of 47 Old 02-21-2012, 07:00 AM
With this set up could you move the front arm mount to the top of the axle to get some extra ground clearance?
post #23 of 47 Old 02-21-2012, 08:38 AM
terrahawk's Avatar
Not unless you have a mounting bracket outside the frame (like RockKrawler) as opposed to right under it.
terrahawk is offline
post #24 of 47 Old 02-21-2012, 09:20 AM
cjcraig7's Avatar
Maybe someone can educate me further on this thinking.
Because the rotational force exerted by the axle normally transfers through the lower control arm to the frame (like a traction bar), wouldn't mounting the lower control arm joint (bolt center) above the center of the axle cause that rotational force to instead pull on the lower control arm?
I have seen this mount on several JKs of late - I would think it is a mistake, but I am no suspension engineer either.
cjcraig7 is offline
post #25 of 47 Old 02-21-2012, 09:30 AM
terrahawk's Avatar
Craig brought up another good point, my comment on how that would effect the geometry was concentrated on frame clearance (at the frame LCA mounting bracket).
