Whats a good CB radio????? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 15 Old 12-31-2011, 03:14 PM Thread Starter
ryanblack321's Avatar
Ok, looking for a CB, what is a good one to get that is around 150-175ish?
Also, I would need a short antenna if possible.
2011 Jeep JK Unlimited
Blessed is the man who perseveres under trial, because when he has stood the test, he will receive the crown of life that God has promised to those who love him. James 1:12
ryanblack321 is offline
post #2 of 15 Old 12-31-2011, 03:19 PM
Unfortunately the antenna length is usually more important than the actual CB. I've had a low end CB with a 102" whip keep up with a tweaked full size CB on a stubby firestik.
Are you trying to talk over long distances? Keep up with other guys on the trail?
post #3 of 15 Old 12-31-2011, 03:21 PM Thread Starter
The primary use will just be to keep up with the guys on the trails during excursions... Not planning on talking long ranges like a trucker would...
Thxs
post #4 of 15 Old 12-31-2011, 03:29 PM
Thxs
I, and many others have used a $35 WalMart Cobra 19 with no problems. I now have a Cobra 29 (mostly due to me getting it for cheap)...but it does not take a whole lot to keep up with a close pack of rigs. Just my opinion.
post #5 of 15 Old 12-31-2011, 03:29 PM
RookieJK's Avatar
Uniden and Cobra make good units. Like Goody said make sure you get a decent antenna and have it tuned properly.
Jersey
Crew
RookieJK is offline
post #6 of 15 Old 12-31-2011, 03:31 PM
oz97tj's Avatar
For that money, you can get a top of the line CB. Pick a name brand with the options you like and be done.
As stated already a properly tuned antenna is more important usually. You don't really need a short antenna either. You just need to mount it in a way so it doesn't stand 4 ft above the roof of your vehicle. Many people mount theirs someplace on or around the tire carrier so the antenna is centrally located and only sticks above the roof line about a ft or less. This keeps it from catching on most items. Also, consider an antenna that flexes like the Wilson Flex or comparable. This way, if it does catch on something, it'll just bend down and then back once you're past without breaking anything. A spring is another option, but a flexible antenna is better.
Support the sport. GLFWDA.org
oz97tj is offline
post #7 of 15 Old 12-31-2011, 03:32 PM
Joneszj's Avatar
I love my Cobra 75. I like that it's easily detachable and hidden...and the actual unit is perfect sized to fit in hand.
1972 Commando on Tons & 40s
Joneszj is offline
post #8 of 15 Old 12-31-2011, 05:25 PM Thread Starter
What do u mean , a antenna ?
post #9 of 15 Old 12-31-2011, 05:40 PM
oz97tj's Avatar
lol. Ok, you have more to learn than we thought.
A CB is just the part of the system that turns the radio waves to sound. Along with the CB, you'll need coax, and an antenna. You may need to ground your antenna as well, depending on the SWR which is the reading you get when you tune the CB. You want the SWR to be as low as possible.
In my rig, I have this radio because it's small and easy to find a place for...
http://www.rightchannelradios.com/co...radio-204.html
And this antenna in 3 ft length...
http://www.rightchannelradios.com/wi...tenna-363.html
You'll also need coax, which is the wire the for the antenna to radio...
http://www.rightchannelradios.com/co...-feet-501.html
An external speaker is also nice, especially with the above mentioned CB because the sound isn't very loud or clear in the speakers that come with CBs generally. An external speaker is especially nice when the top and doors are off...
http://www.rightchannelradios.com/cb...eaker-407.html
An SWR meter is how the whole system is tuned. You don't really need to buy one if you have a truck stop or radio place nearby as they can tune it for you, but here is one just for reference...
http://www.rightchannelradios.com/cb...meter-333.html
With all the above items, you have a complete CB system. Wire the CB direct to the battery to avoid interfence in the power line which cause wierd noises to be heard. Find a suitable place to mount the CB and the speaker inside the jeep and mount the antenna someplace outside, like the tire carrier as mentioned before.
Also, even though I directed you to Right Channel Radios, it should be mentioned that all of those parts are available at all sorts of places and generally can be found for cheaper as RCR is kind of pricey, but they do make getting everything you need easy. They even have kits.
oz97tj is offline
post #10 of 15 Old 12-31-2011, 07:46 PM Thread Starter
Yes, I know a good bit about Jeeps but not a lot about CB radios.
Thank you for your input, huge help!
post #11 of 15 Old 01-01-2012, 07:28 AM
pawj112's Avatar
x 2
pawj112 is offline
post #12 of 15 Old 01-01-2012, 08:30 AM
Davesrb's Avatar
I have been looking at this kit:
http://www.rightchannelradios.com/je...wx-st-419.html
$179.95 for a complete kit. You can probably save $15 or 20 bucks sourcing it individually else where....
Davesrb is offline
post #13 of 15 Old 01-01-2012, 08:34 AM
X2 - Wilson flexible antenna. I have seen many rigid sticks break on the trail.
4x4x4 is offline
post #14 of 15 Old 01-01-2012, 01:48 PM
JeepBobWinnipeg's Avatar
Mine failed on me after 8 uses. The "process" to get it resolved was rediculous, and took months.
Cobra said, uninstall the whole thing, mail it to us and we will fix it. Months later they mail it back to me saying CB broken and cannot be fixed, probably cable. I was furious after uninstalling/mailing/waiting that they would sent the unit back, not working.
I bought a Uniden while waiting for my Cobra to get fixed/replaced. Very happy with the Uniden.
The Cobra replacement now sits in it's original box in a cupboard. They would not work with me on a different model of equal or lesser value.
Mine is probably one bad experience, and may not be the same for everybody, but I am left unhappy with Cobra.
'12JK-U Rubi /Dynatrac ProRock 44 / 4:88's / 2.5 Old Man Emu Susp Lift /F&R JKS Trac Bars /OME Long Travel Shocks /BilstienSS /TereFlex Control Arms /Coast1310 /Eng Oil, Evap, Rear Diff Plates, LoD Rock Sliders /Duratracs - 35's /BlackRock Wheels /Zenon Wheel Flares /DetachFlaps /LoD Rear Bumper and Tire Carrier /K&N/Engo10,000S Winch/FloorLiners /Uniden 510
JeepBobWinnipeg is offline
post #15 of 15 Old 01-01-2012, 02:06 PM
oz97tj's Avatar
I have read a handful of issues with the 75, but have read issues with pretty much every part made for jeeps too. I've had mine for a few years now and it still works fine. With that said, I can't hardly recall ever reading anything bad about any of the larger units like the 29. I just like the 75 for ease of mounting. In all honesty, if I could find a suitable place to mount it, I'd have a 29 in my jeep, but I just can't find any place I like. Not to mention, I can unhook the cable of the 75 and remove it for when the doors are off so it doesn't walk off.
I also have one of the small handheld Midlands. It's similar to the 75, but with the option of removing the head unit and attaching a battery pack and antenna for completely mobile use when out on foot. However, I think my 75 works better, and on par with a 29. I do think it's a bit more delicate though.
oz97tj is offline
