installing psc flares - JKowners.com : Jeep Wrangler JK Forum
post #1 of 16 Old 12-30-2011, 10:10 PM Thread Starter
vwang's Avatar
so been installing the psc flares these past few days and have a few specific questions that i couldn't find any answers to in all the threads i've looked up. hoping those who have already installed can help me out.
1. in step 16 for installing rear flares, how do you drill the upper most hole for the rear bracket? (on the back of the wheel well)
2. having trouble getting some of the 1 1/4" bolts on the fronts to thread into the metal clips on the sub bracket. just doesn't want to grab the thread and just keeps pushing the clip away from it. already stripped the head of one bolt..
Teraflex - Poly Performance - Poison Spyder - Off Road Hero's - Rugged Ridge - Superchips - Goodyear - aFe
vwang is offline
post #2 of 16 Old 01-01-2012, 09:02 AM
e-jeep's Avatar
Feedback: 12 reviews
This is a damn good question. I didn't. I drilled the ones I could get to, and with those it is very stout.
No idea ...mine went in smoothly.
My Build Thread ~
NE Trail Ride Thread ~
Adrenaline Offroad
e-jeep is offline
post #3 of 16 Old 01-01-2012, 09:50 AM
Nwapache's Avatar
Yeah, i skipped that one as well!
Strangely, i didnt have any problems with the clips either....
Sorry man, looks like you have to call PSC. Install was a PITA but well worth it, welcome to tue club
Nwapache is offline
post #4 of 16 Old 01-01-2012, 10:04 AM
GRIZZLY47's Avatar
Feedback: 13 reviews
Putting my rears on was relatively easy but the fronts made my quarter panels bow and I have no clue what to do about it. I guess armor over it but still it sucks
2010 4-DOOR MOUNTAIN
GRIZZLY47 is offline
post #5 of 16 Old 01-07-2012, 03:01 PM Thread Starter
vwang's Avatar
yeah install is definitely a PITO for sure. ended up leaving that top bolt out of the rear bracket. actually ended up leaving two bolts each out of the rear flares. that doesn't really bother me since its bolted in so well.
the front on the other hand is driving me nuts. guess i will just have to call PSC but still not seeing how that will really solve my issue, still going to have to remove the entire flare and hope the same thing doesn't happen again... seems like it'd be easier to install if the bolts had a point like a screw so that it could thread itself in... stupid clip on nuts really pissing me off.
vwang is offline
post #6 of 16 Old 01-07-2012, 03:03 PM
GRIZZLY47's Avatar
Does your quarter panels bow?
post #7 of 16 Old 01-07-2012, 03:05 PM Thread Starter
vwang's Avatar
mm no not that i have been able to tell.. however i haven't fully tightened all the front bolts down yet as i haven't been able to get two to thread. on either side...
vwang is offline
post #8 of 16 Old 01-07-2012, 03:06 PM
EMG006's Avatar
Can you just take the clip on nut off, use and nut and washer behind the panel?
River City Offroad
Metal Cloak
EMG006 is offline
post #9 of 16 Old 01-07-2012, 03:07 PM Thread Starter
vwang's Avatar
no the way the bracket is located you can't fit your hand up there to put the nut on
vwang is offline
post #10 of 16 Old 01-07-2012, 03:09 PM
EMG006's Avatar
How bout a wrench with tape on one side, nut placed on tape and put it up there?
I did that for my genright flares, but there was no bracket with those...
Edit...just read the instructions. That won't help either. Good luck.
River City Offroad
Metal Cloak
EMG006 is offline
post #11 of 16 Old 01-09-2012, 01:37 PM
2. I had the exact same issue with the front with getting some of the bolts to thread the speed clips. I had to remove the metal hoop that keeps the speed clips in place. They kept bending and not allowing the bolt to completely thread.
08 JKU
09GRNJK is offline
post #12 of 16 Old 01-10-2012, 02:04 AM Thread Starter
vwang's Avatar
well i'm glad i'm not the only one who had that problem. kind of wish PSC would just weld those bitches on or something. really really irritating dealing with that shit
vwang is offline
post #13 of 16 Old 01-14-2012, 11:30 AM
I had the same problem with my fronts. It took awhile, but I finally figured out the problem. The directions mention using longer bolts in some of the top center holes in the flare...don't! If you look inside you'll see the longer bolts go through the flares and clips, and then when tightened down they continue through the clip and hit a fender support. As they are tightened further they push against the fender support and push the flare outward. This pushing on the top center is what causes the fender to bow and not sit flush with the flare. This is also what causes problems with getting bolts into some of the other clips. As a temporary fix you can just loosen the longer bolts and try to get your fender to flatten out (mine woulnd't and was permanently bowed). As a more permanent fix you can pick up a few more of the shorter bolts.
The worst part is I described the problem to PSC and asked them to look into it and get back to me. They never got back to me, never changed their directions or their bolts, and people are still damaging their Jeep's front fenders.
Kay9Cop is offline
post #14 of 16 Old 01-17-2012, 08:52 PM
GRIZZLY47's Avatar
So you have bowed fenders as well? I'm contemplating selling the front flares and buying the ORE ones with armor to cover it up.
post #15 of 16 Old 01-17-2012, 09:47 PM Thread Starter
vwang's Avatar
how much gap are you guys having between the fender and the body? i'll get some pics tomorrow but there's a good amount on my fronts. have no idea how to close the gap. its large enough so that you can see the rubber liner flapping about between them.
vwang is offline
post #16 of 16 Old 01-17-2012, 10:10 PM
V8 dreams
jvandy50's Avatar
I didn't install my rubber liners and I have a fairly large gap. I've seen folks put a trim piece between flare and fender that looks pretty clean. And on the bolt problem, I started with the most problematic bolt first and the freaking stars aligned I guess. If I started at bottom bolt and moved toward front of jeep, nothing lined up. Weird
Vandy
2010 Silver JKU
jvandy50 is offline
