Pitman Arm rubbing against tranny lines - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 12-29-2011, 08:05 PM Thread Starter
sapppro's Avatar
I noticed today that the tranny line is being worn out by the pitman arm. I have a 3.5" Rock Krawler lift and trying to determine............ if this is the stock pitman arm?
It's the 3.5 RK Flex System and didn't see a aftermarket pitman arm so I'm assuming this is the stock one.
If so, I'm still under warranty and will take it to the dealership. Notice how the metal part of the line is pretty well worn.
3.5" RK Lift, 35" MTR/K's, RR Skid Kit.
sapppro is offline
post #2 of 4 Old 12-29-2011, 11:00 PM
The RK lift uses the stock pitman arm. On my 08 the pitman arm doesn't even come close to the lines. What year is your rig? I suspect that yours is newer and the lines may be routed differently. So dealer is your best bet since you are still covered.
post #3 of 4 Old 12-30-2011, 07:49 AM Thread Starter
sapppro's Avatar
Thanks! It's an 09, i will see what the dealership says.
sapppro is offline
post #4 of 4 Old 12-30-2011, 08:14 AM
There is a recall for the 08-09 JK trans cooler lines due to the crims failing.
My trackbar on the AEV lift was rubbing the lines, and I had a line fail at a crimp. I compared to stock suspensions, and they had the same problem. I would guess these parts touching caused the failure, however I got my lines replaced under the recall, and they rerouted them while they were at it to avoid the touching.
I am assuming the new lines and rerouting were covered in the warranty since most dealerships won't do something like this without direction from coporate.
Jon
08 Rubicon
JeepinJon is offline
