Proper Air Pressure for GY Duratrac's - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 12-29-2011, 05:48 PM Thread Starter
oaksmith's Avatar
I posted this on the Wheels and Tires Thread and got no replies and only 21 views!
I'm running Good Year Duratrac's 285 75 16 and was hoping to get some help on what pressure I should have in my tires. If it matters, 2 door JK Sport.
oaksmith is offline
post #2 of 4 Old 12-29-2011, 07:01 PM
EMG006's Avatar
Chalk test it, that's the best way to figure it out.
River City Offroad
Metal Cloak
EMG006 is offline
post #3 of 4 Old 12-29-2011, 07:12 PM
Apocalypse's Avatar
Even at optimal pressure you may not get the chalk to rub off on the outer edges depending on wheel width, etc. It should still give you a pretty good idea of how much pressure will allow the most tire possible touching pavement without being under inflated
08 2dr JK
Originally Posted by PIG View Post
All BJís are not the same manÖ I am sure you have had a good and a bad BJ in your time.
Apocalypse is offline
post #4 of 4 Old 12-29-2011, 07:18 PM
I run mine at 28lbs based on tests. I'm at 8000ft up in the mountins though so I recheck and adjust when going down to flat land.
Vince1 is offline
