Teraflex shock travel question - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 06-20-2011, 07:16 PM Thread Starter
b4tn's Avatar
Anyone know what the actual max lift the teraflex shocks that come with the 2.5" spring lift can handle? I know that the rear springs fall out without a guide.
2010 Surf Blue Unlimited
b4tn is offline
post #2 of 7 Old 06-20-2011, 07:24 PM
pluke the 2's Avatar
dont quote me but it should be good from 2-4" of travel.
Cali Crew
My Youtube Channel:
pluke the 2 is offline
post #3 of 7 Old 06-20-2011, 07:48 PM
austinjeepr's Avatar
There are separate teraflex shocks for 3.5-4".
you could run them with taller springs you may
lose wheel travel (droop) though.
What are you pondering????
Mat
austinjeepr is offline
post #4 of 7 Old 06-20-2011, 08:03 PM Thread Starter
b4tn's Avatar
I have a 1" spacer in the front to compensate for a rockhard front bumper and winch. I recently added a rockhard rear bumper and the rear is sagging. I am contemplating a rear 1" spacer or taller springs all around and shorter bumpstops.
b4tn is offline
post #5 of 7 Old 06-20-2011, 08:41 PM
charles's Avatar
If you're dropping and you add an inch, you'll be back to your starting point (more or less) so it's a non-issue. Either way, the shocks limit your down travel so the higher you go the less you can droop. No critical concerns.
charles is offline
post #6 of 7 Old 06-21-2011, 01:02 PM
TeraFlex's Avatar
Incorrect. The current 2.5" kits do not need rear coil guides. The original kits did because they used the longer 3"-4" shocks.
2.5" shock specs
ext travel compressed
Front: 24.880 9.470 15.410
Rear: 24.990 9.360 15.630
801-713-3314
TeraFlex is offline
post #7 of 7 Old 06-21-2011, 04:35 PM Thread Starter
b4tn's Avatar
2.5" shock specs
Thanks, I must have the older kit. They dont actually fall out but come back severely misaligned and would fall out if they where not screwed to the bottom perch. Do you have the numbers for the 3-4" shocks?
What I am debating is getting adjustable spacer/bumpstops and fine tuning articulation. Or just getting a rear 1" spacer to level it out.
b4tn is offline
