Poly: 1, Jeep: 0 - another lesson learned - JKowners.com : Jeep Wrangler JK Forum
post #1 of 83 Old 06-19-2011, 08:43 PM Thread Starter
BADGER's Avatar
The rocker impact spot:
Nothing unusual, right? The result elsewhere:
-Milton Friedman
BADGER is offline
post #2 of 83 Old 06-19-2011, 08:51 PM Thread Starter
BADGER's Avatar
It's actually a bit worse than it looks in the pics. Needless to say, I'm a bit perturbed that the $600 rockers I bought to protect my rockers actually damaged them. Yeah, it was a hard hit, but no harder than happens to people all the time. And this is a pretty light 2-dr - fully loaded with passengers etc well below 5000 lbs. If this had been a 7000+ lb 4-dr, I can only imagine what it would have done.
It got me thinking that it's not necessarily a great idea to have rockers that strong attached to the body. Some people have bitched about bending their PSC rail, or their ACE rail caved....but it protected the body and didn't damage the tub. I would have much rather had that happen and have to just replace a rail. Hell, that's why we buy them.
My advice, use something that will bend or break before the Jeep tub. Using a nuke-proof rocker isn't as smart as I thought.
-Milton Friedman
BADGER is offline
post #3 of 83 Old 06-19-2011, 08:59 PM
EMG006's Avatar
Sucks, sorry to see it happen. I am with you though, you buy it to prevent that from happening.
River City Offroad
Metal Cloak
EMG006 is offline
post #4 of 83 Old 06-19-2011, 09:01 PM
binarypie's Avatar
That really sucks.
I haven't hit my PJ ones that hard yet but I'm curious to see what becomes of it.
Info:
binarypie is offline
post #5 of 83 Old 06-19-2011, 09:08 PM
I got the ace rails with the rubi rails under them. I went with the ace for the affordable price until I could decide what I really wanted, now rethinking the body mounted set ups now, damn dude that sucks! Sorry and good luck!
2008 JK 4Dr Rubicon
Stone white
Mygig W/Uconnect working.
Hard top/Auto tranny
First mod, dog slobber.
Painted hard top
Spidertraxx 1.5 spacers
Teraflex 3" lift
rob4607 is offline
post #6 of 83 Old 06-19-2011, 09:12 PM
nootherride's Avatar
And people give me shit cause my psc sliders have some give! I'm adding the body panels as well cause like you said I'd rather bend the rails than damage the body...I'm sure you'll get that all worked out..
nootherride is offline
post #7 of 83 Old 06-19-2011, 09:14 PM
BenFoo's Avatar
One of the reasons I went with a frame mounted.......Ive seen plenty of strong tub mounts but I've also seen tub mounted ones damage the tub/rocker more than once.
BenFoo is offline
post #8 of 83 Old 06-20-2011, 12:47 AM
Matt Wright's Avatar
Frame mounted sliders FTW
AKA: "American" on PBB
Matt Wright is offline
post #9 of 83 Old 06-20-2011, 03:11 AM
Hope you don't mind OP but I have shared the link on another forum.
This is the argument I have had for a while now. Body mounted protection worked great on the TJ but the JK is a more car like design and thinner metal etc.
ex: RHD JK 2dr CRD auto
CRDTom is offline
post #10 of 83 Old 06-20-2011, 04:22 AM
jeepnick's Avatar
Originally Posted by binarypie View Post
That really sucks.
Ive came down full load on my pj more then once
IMHO they are the most solid body mounted rockers you can buy
jeepnick is offline
post #11 of 83 Old 06-20-2011, 05:53 AM
Damn, thats terrible!
post #12 of 83 Old 06-20-2011, 07:47 AM Thread Starter
BADGER's Avatar
Yeah, this definitely gave me some pause. In addition to the body these are mounted on the underside using the two body mounts on each side. Obviously its not enough, as the slider was able to flex into the body hard enough to damage it. The freaking slider though.....not so much as a dent. I don't know what kind of magic pixie metal these guys are building these from.
Let's just say in the future I'm going with a proper frame-mount rail, and if it uses body support, it's going to be a larger plate to distribute the force ala Nemesis/PSC/etc. The Poly slider concentrates too much force along a pretty narrow strip of the tub and not enough support underneath.
Oh well, they say the wimmens like body damage.
-Milton Friedman
BADGER is offline
post #13 of 83 Old 06-20-2011, 08:36 AM
terrahawk's Avatar
Just playing devils advocate here, but i I have the same rails, have slammed them several times from the side and bottom, and not so much as a tiny dent.
terrahawk is offline
post #14 of 83 Old 06-20-2011, 08:51 AM
binarypie's Avatar
I think the one major difference between most JK tub mounted sliders and the TJ tub mounted sliders is the way they are attached.
It seems to me that most of the tub mounted sliders out there for the JK use nut-certs to attach them. While this makes the install easy it does put more force on a single panel.
Where as the TJ mounted sliders tended to be through-bolted with crush sleeves which creates a much more dent-resistant mounting point.
This is the only reason I went with my PJ sliders is because they are through-bolted.
Info:
post #15 of 83 Old 06-20-2011, 01:00 PM
This is definitely the reason I'm planning to use frame mounted sliders.
rha600 is offline
post #16 of 83 Old 06-20-2011, 01:13 PM
desert dog's Avatar
Yep, I try not to piss off the vendors here too much about this, but all the tub mounted jobs do this if you beat em hard enough. Seem several PSC sets and this is the 2nd Poly set Ive seen do it. My Pure Jeeps were holding out pretty well for a long time, but after my last trip to Ridgecrest, now I am getting body damage from those too.
All these vendors make fantastic products, its just the tin-can sheetmetal that Jeep used on the heavy suckers. That, and folks do things with daily-driver Jeeps now that buggies wouldn't touch 10 years ago.
Came to the conclusion (with several other folks that wheel in my circle) that the frame mounted is the way to go if you wheel like a maniac. Just sucks that you have to loose all that precious ground clearance with a low center of gravity build.
I guess you can't have it all
desert dog is offline
post #17 of 83 Old 06-20-2011, 01:22 PM
VKS Fab
JK Vick's Avatar
I know what ya mean. I had the same issues with tub mounted sliders. My end result \/ . I haven't had an issue ever since. I'm HARD on my sliders.
Handmade One At A Time
GIVE US A CALL 559-392-3145
JK Vick is offline
post #18 of 83 Old 06-20-2011, 01:38 PM
BenFoo's Avatar
Agreed about not wanting to pee in the vendors cheerios.
Though, I'm still not sure how much I agree with the "loosing ground clearance" They dont hang down lower than the frame. The lowest point is still the frame.....
BenFoo is offline
post #19 of 83 Old 06-20-2011, 01:46 PM
SONIC's Avatar
I have been saying this for years.
Body mounted sliders are a bad idea.
Period.
-Doc Holiday
SONIC is offline
post #20 of 83 Old 06-20-2011, 01:48 PM
desert dog's Avatar
I'm sitting pretty low on 40s. The lost 4-5" with frame mounted sliders would make frequent moves like this a little harder;
But, its what I'm going to have to end up doing. Once the body damage with tub-mounted sliders starts, it only gets worse from there.
post #21 of 83 Old 06-20-2011, 01:48 PM
VKS Fab
JK Vick's Avatar
X2
JK Vick is offline
post #22 of 83 Old 06-20-2011, 02:03 PM
Bubblegoose1's Avatar
^^^^^ yup
Bubblegoose1 is offline
post #23 of 83 Old 06-20-2011, 02:19 PM Thread Starter
BADGER's Avatar
Guys, I'm not trying to rile up the vendors either. Poly is great stand-up guys who make great stuff and are an asset to the Jeep community. These are at least as good as any other body-mounted sliders out there and probably better. ANYBODY'S would have suffered the same fate or worse in this situation. But hey, I'm a Jeeper and wheeling enthusiast first. If it comes down to being worried about riling the vendor who I'm helping keep in business with my own money, or helping out the rest of the Jeeping community with some information that could prove valuable....I share information in the community. I would expect the same of others and would be kinda ticked if they withheld something from the rest of us for that reason!
This was posted more as information the community could absorb and do with as they wish. Just sayin' these tubs aren't as strong or distribute the load as well as many of us have come to believe. From here on out for me, it's frame-mounted....and I too hate the ground clearance loss and hangup points. But, it's better than a cratered tub. Now for all, Poly included.
-Milton Friedman
BADGER is offline
post #24 of 83 Old 06-20-2011, 02:21 PM
BenFoo's Avatar
You are refering to 'outboard' ground clearance then....as in outside of the tube/frame itself. That'll agree with...as the frame is deffinately lower than the tub. But in that picture, you'd be pivoting on the frame mounted slider as apposed to clearing it (it looks like maybe? hard to tell). Pivoiting on sliders isnt a bad thing if they can support it. Also, your tires will still stick out further than the sliders......
BenFoo is offline
post #25 of 83 Old 06-20-2011, 03:23 PM
I'm surprised no one from poly has chimed in, but as you've stated anything that mounts directly to the body no matter how well built is still going to distribute absorbed energy to the body so there will always be a chance of something like this.
2008 JK 4Dr Rubicon
Stone white
Painted hard top
Teraflex 3" lift
rob4607 is offline
