Wheel Tec Specs - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 06-17-2011, 05:34 AM Thread Starter
Wheel Tec Specs
Gday Im looking at these wheels and just want to know If they fit a jk. They dont list wheels for them at all but i dont know if its just a website thing or if there is a difference in theses rims.
They are 17x9, 5 x 5.00, 4.75back spacing, non hub centric and a 60deg lug nut seat. I want to wrap them in 37s if that makes a difference.
http://www.summitracing.com/parts/PCW-7105-7973/
Thanks Shane
corrupt is offline
post #2 of 5 Old 06-17-2011, 06:06 AM
frankie945's Avatar
They will fit. But BS of 4.75 would bother me. I run aevs with that back spacing and I had to add wheel spacers to keep the 37s from rubbing the frame. Send Marcus at river city offroad a pm he can hook u up & get u lined out. I wouldn't order wheels from summit. Better deals can be had here.
Sent from a Android on Tapatalk..
frankie945 is offline
post #3 of 5 Old 06-23-2011, 04:28 AM Thread Starter
Thanks alot Frankie. So all thoses with 17x9s are running wheel spacers with 37s, Im having a hard time finding a black 17x9 with 4.5" backspacing.
corrupt is offline
post #4 of 5 Old 06-23-2011, 03:11 PM
Panamon Creel's Avatar
Yeah the -6mm offset of those wheels will likely be insufficient for 37X12.5" tires. Are you fixated on 17" Wheels? Maybe more options available that meet your requirements with 16" Wheels.
Panamon Creel is offline
post #5 of 5 Old 06-23-2011, 03:33 PM
I run a 17x9 with a -18mm offset with 37" mtrs on a 3" poly performance lift with no rubbing issues except for the flare on a really hard hit while turning. You will likely have issues with a -6mm offset
I'm also not using wheel spacers either..
Imkunfused is offline
