Recommend gears for me! - JKowners.com : Jeep Wrangler JK Forum
post #1 of 22 Old 06-16-2011, 09:42 AM Thread Starter
dodge8604's Avatar
I've got an 08 unlimited X no tow package 6 speed so I'm pretty sure I've got the 3.21s and now that I own a sweet boat it really sucks towing and it actually sucks altogether. I'm about to leave my JK to my brother in law while I finish up my deployment in Afghanistan and while I'm gone I'm hoping to get some new gears put in. I was thinking 4.88s because I don't think I'm gonna go any bigger than the 33s I have now and don't wanna lose any gas mileage on the interstate because I'm on it alot on the weekends while I'm stateside.
I know theres a great chart out there somewhere to help me on gear ratio/tire size but I wanna know from some real world subject matter experts and what they think I should do in my situation. Any and all answers are appreciated!!!
08 JKU X - Flame Red w/ a few Doo Dads
dodge8604 is offline
post #2 of 22 Old 06-16-2011, 09:58 AM
pluke the 2's Avatar
depending on the amount of tow you're going to do, i'd look for people in your area who have different gearing.
if your towing less then 5% a month, i'd get 4:88's and you should be good with 33s.
if your towing more then 5% a month i'd prolly get 513s.
I got an auto with 37's and 513's and i wish i went with 538s
also depending on how much you tow, i'd look into a transmission cooler, even with the standard transmission.
Cali Crew
My Youtube Channel:
pluke the 2 is offline
post #3 of 22 Old 06-16-2011, 11:31 AM
4.88's would be too much for your 33's. I'd do 4.56 if I were you. If you had said you were going to run 35's then I'd recommend 4.88's. I have 4.88's and 35's on my 6 speed and the RPM's run really high on the highway (speed limit is 75 out here). At 75 I'm at about 3200 RPM's and that's hurting my fuel economy.
Sometimes I wish I would have gone 4.56 even with my 35's because I spend so much time on the highway at high speeds. 4.56 would be great for 33's and even give you the option of going to 35's in the future.
drgreybow is offline
post #4 of 22 Old 06-16-2011, 11:34 AM
jtrain's Avatar
33s and a 6spd=4.56, just do 35s and 4.88s at the same time!
Your Adventure and Off Road Outfitter since 2004.
jtrain is offline
post #5 of 22 Old 06-16-2011, 11:36 AM
Chuck Bullitt's Avatar
Yea, with 33's, I don't think I'd go any higher than 4.56. I'm 4.88 w/6 speed and 35's and it does zing on the highway above 70.
As for mileage, I lost on average 1.5 mpg going from 3.21 to 4.88 - just FYI
Chuck
2009 JK Unlimited X, mostly stock with a K&N filter.
Chuck Bullitt is offline
post #6 of 22 Old 06-24-2011, 04:41 AM Thread Starter
dodge8604's Avatar
Thanks for the input fellas, looks like I'll be looking alot more closely at any future tire upgrades although unlikely. 4.56s sounds like they'll be my answer! Thanks again for the input. As for having a 6spd, would I have to use a programmer at all after the install? I would need to redo the speedometer wouldn't I? Sry not real savvy on the gear thing thanks again guys
post #7 of 22 Old 06-24-2011, 07:09 AM
JIMBOX's Avatar
You've got the 4dr brick-You should only have to do a regear ONCE--
Since you have a 6spd-4.56 is a total waste, if you start with 33" tires, you still won't be able to use your O/D-
Get a set of 5.13s YUKON gears (complete) have put in then you can tow/off-road/cruise at 65/70 in O/D and get good mileage, then discover what really can happen in 4lo, for climbing-off-road or pulling a boat outta the water in 2wd 1st--
I'd suggest "lubelocker" gaskets /w YUKON gears-
Good luck
JIMBO
Man, you gotta have style
"YELLOW JEEP No. 683"
JIMBOX is offline
post #8 of 22 Old 06-24-2011, 07:35 AM
2k2wranglerx's Avatar
Good luck
JIMBO
i think you misread. the 6 speed is a manual. in 6th with 5.13's and 33's it's going to be SCREAMING down the highway lol.
2k2wranglerx is offline
post #9 of 22 Old 06-24-2011, 07:54 AM
JIMBOX's Avatar
Heh Heh, Nope no misread-what do you think the 6th gear is ???
O/D and 5.13s are only about 500 rpm higher than 3.73s--I have 5.38s and My '08 JKUR is, with 33.6" tire, is at 2650rpm/70mph, but gets the best mileage at 60 mph-2250 rpm (19mpg)-
It's a jungle out there
JIMBO
JIMBOX is offline
post #10 of 22 Old 06-24-2011, 08:02 AM
JIMBO
You must have an automatic. HUGE difference between manual O/D and automatic O/D. I have 4.88's with 35's and I'm turning 2800'ish RPM's @ 70 in 6th gear.
Chuck
post #11 of 22 Old 06-24-2011, 08:02 AM
JIMBO
if you say so
post #12 of 22 Old 06-24-2011, 08:07 AM
blownJK's Avatar
http://www.4wheelparts.com/Performan...n=EXPPC52001-1
This will most likely be one of your cheapest options as far as recalibration. Dealerships can flash as high as 32" tires and 4.10 gears, unless that has changed in the recent years.
Like us on
blownJK is offline
post #13 of 22 Old 06-24-2011, 08:12 AM
blownJK's Avatar
JIMBO
Sorry man, 6th gear s not "od"...it's 6th gear...your numbers with an auto trans will be completely different than a manual trans.
Stick with going 4.56, anything else will be screaming on the highway with 33" tires
Like us on
blownJK is offline
post #14 of 22 Old 06-24-2011, 08:23 AM
JIMBOX's Avatar
OK, if thats what you guys want then so beit-but
I have a 4spd auto-4th gear is O/D-
He has a 6spd manual-6th spd is O/D
You're right if his jeep is a daily driver, although theres an an awful lotta guys that DIDN"T change to the 5.13s and are really sorry-
Lets hear from the UNHAPPY 5.13 gear drivers !!
I'm not arguing-My 5.38s are the single best mod I've done to my JKUR-
All we can do is show the OP some opinions-not argue--RIGHT !!
Ciao
JIMBO
JIMBOX is offline
post #15 of 22 Old 06-24-2011, 08:57 AM
JPK
Manual Transmission Ratios for the JK's NSG370:
1st - 4.46
2nd - 2.61
3rd - 1.72
4th - 1.25
5th - 1.00
6th - 0.84
Auto Transmission Ratios for the JK's 42re:
1st - 2.740
2nd - 1.540
3rd - 1.000
4th - 0.690
Forthcoming 545rfe Auto Transmission Ratios for the 2012 JK's:
1st - 3.00
2nd - 1.67/1.50 - two ratios, the shorter when upshifting and the taller when downshifting, iirc.
3rd - 1.00
4th - 0.75
5th - 0.50 - but I have also read 0.67, which may be for pre-'08 trannys.
With the much steeper O/D the autos need lower gears than the manual, which is pretty common knowledge.
JPK
JPK is offline
post #16 of 22 Old 06-24-2011, 09:04 AM
This is exactly why my I want to go with 4.56's when I lift and put small 35's (duractracs) on my rig. If I was making a wheeling rig, I'd put 5.13's and not look back. But I spend way to much time on road driving and limited to any on the trail. I reserve the trails for my quad.
Koko is offline
post #17 of 22 Old 06-24-2011, 09:14 AM
JIMBOX's Avatar
I concede-but
Thanx JPK, for the exact figures-but Ya gotta think if you're gonna run your jeep every day at 75/80 mph, then there's no doubt !!
Ciao
JIMBO
JIMBOX is offline
post #18 of 22 Old 06-24-2011, 05:19 PM
5.13's on 37's and love it! cant wait to go to 5.38's when the d60's come into the picture!
-Marc
Coming up:
14 Bolt rear ARB w/ 5.38
EVO Long Arm
40/42 MTR's
17" Spyderlock Beadlocks
post #19 of 22 Old 06-24-2011, 05:36 PM
axsys's Avatar
I'm turning 2750 RPM on the highway in 6th at 75 with 4.88s and 37s. I would not go above 4.88s if you plan on staying with 33s.
axsys is offline
post #20 of 22 Old 06-24-2011, 06:29 PM
nootherride's Avatar
i have an 08 no tow and had 3:73..easier if you do id vote 5:13 or 5:38
i want 5:38 in my auto 35.13.50 might go to 37 or 40 in future.. what's your guys opinion? sorry for the jack
nootherride is offline
post #21 of 22 Old 06-24-2011, 06:39 PM
THECHAD's Avatar
I have 6.00s and 40s should be perfect
18 BRAVO
panama
kuwait
somalia
bosnia
cuba
now just kicking it as a civilian
I served so your lazy ass didnt have to
THECHAD is offline
post #22 of 22 Old 06-24-2011, 06:44 PM
hey man Ford 9's dont count and dont be sending any of those blow up dolls over here
