Hinge for tire carrier? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 06-14-2011, 06:13 PM Thread Starter
14ers
toadontheroad's Avatar
Anyone of yous guys build your own tire carrier? What did you use for a hinge? I found this:
http://www.tmrcustoms.com/store/inde...70c24e0f080b0f
But I thought it was $$. Thought about going the chevy front spindle route or going to a trailer builder for the spindle setup. Any thoughts?
2008 Rescue Green UJK Rubicon 6 spd with a bunch of super cheap mods!
toadontheroad is offline
post #2 of 11 Old 06-14-2011, 06:20 PM
Cod
Cod's Avatar
Send a message via MSN to Cod
Cod is offline
post #3 of 11 Old 06-14-2011, 06:57 PM
BumpInTheRoad's Avatar
+1 on the A-to-Z hardware. Plus Zach is a great guy and actually wheels his stuff, both on trails and competitions. He doesn't sell crap and his prices are hard to beat.
I'm a JKO Reject
BumpInTheRoad is offline
post #4 of 11 Old 06-14-2011, 07:32 PM
frankie945's Avatar
Check out comp4x4 as well. They come with a sleeve. That was the buying point for me.
Sent from a Android on Tapatalk..
frankie945 is offline
post #5 of 11 Old 06-14-2011, 09:54 PM
VADERJKU's Avatar
http://diy4x.com/cart/index.php?rout...product_id=166
Great company to deal with too, Kert ROCKS!!!!
VADERJKU is offline
post #6 of 11 Old 06-14-2011, 10:17 PM
dconnole's Avatar
got beat to the punch... 50 bucks can't be beat
dconnole is offline
post #7 of 11 Old 06-15-2011, 12:38 AM Thread Starter
14ers
Thanks for the links. Very cool.
I wasn't super impressed with the roll pin in the sleeve from comp4x4. Is it that big of a problem to set the height of the carrier? The double shear bracket takes care of that, right?
post #8 of 11 Old 06-15-2011, 04:12 AM
I got the double sheer set up from com4x4, very beefy! Haven't had the time to finish my tire carrier but it looks like it'll hold up very well.
With the comp set up you weld the sleeve in then drop the spindle in the sleeve and use the roll pin and gusset to keep it from coming out. The idea being that you don't have to weld to the spindle, I guess this is a common failure point, the spindle actually breaks at the weld. Plus if for what ever reason you need to take your tire carrier off you just pull the role pin and all that's left behind is the whole where the spindle drops in.
HOT_DAMN is offline
post #9 of 11 Old 06-15-2011, 05:26 AM
frankie945's Avatar
^ exactly the comp4x4 spindle is designed to be removed. I never even tack welded the spindle to the sleeve. And if you are making your own base. The sleeve makes it much easier to do. Another benifit is if the carrier were to ever break. The whole carrier can be easily removed.
post #10 of 11 Old 06-15-2011, 03:17 PM
PIG
PIG's Avatar
Some other options...
Latch Assembly
1.75" Spindle
PIG is offline
post #11 of 11 Old 06-15-2011, 09:56 PM
75bnco is offline
